[Swift-devel] LQCD mapping
    itf at mcs.anl.gov
    itf at mcs.anl.gov
    Tue May  1 02:47:03 CDT 2007
In this case, it seems that you know the number oif files to be created
ahead of time. Should that information be specified in the definition (the
first line)?
> yesterday evening I played some with Nika trying to get her LQCD workflow
> running some more.
> It involved one code change to swift:
> I put a 'create' option on the filesys_mapper so that one can do this:
>   file lattice[] <filesys_mapper;prefix="lattice.",create=true>;
>   foreach i in range {
>     int j=i-1;
>     lattice[i] = lqcd_exec(test_in,lattice[j]);
> where lattice.* files don't exist, so that lattice[5] will map to
> "lattice.5". With create=false (the default) then the mapper behaves as
> before, which seems to be essentially an input-only mode where it creates
> an array based on existing files.
> I think this is the mapping functionality that I want, but its not clear
> to me whether filesys_mapper is the place for it, whether one of the other
> mappers already does this, or if it should go in a different place
> (another mapper or a new mapper). comments?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
