[Swift-devel] jobchart
Yong Zhao yongzh at cs.uchicago.edu
Sat Mar 10 23:02:13 CST 2007
I see, so this does not involve stage-in and outs. Why did postprocessing
take that much time in the other two graphs, where in this case it is
minimal?
Yong.
On Sat, 10 Mar 2007, Mihael Hategan wrote:
> Preprocessing is the time between "Running job..." log message in
> vdl-int.k and when the task status gets changed to "Submitted".
> Postprocessing is between when the task status is changed to "Completed"
> and the "Completed job" log message in vdl-int.k, and includes the check
> for the exit code file.
> Mihael
> On Sat, 2007-03-10 at 22:51 -0600, Yong Zhao wrote:
> > nice graph, what's preprocessing and postprocessing involved in this case?
> > Yong.
> > > There's a new tool in bin.
> > > It's a spin off Jens' "show-id" tool.
> > > After careful analysis of show-id, it became apparent that a lot of the
> > > difficulty was in gathering and organizing the data, rather than in
> > > generating the plots. This one's written in python and lacks the command
> > > line options to control sizes, but includes the logic in Jens' tool that
> > > automatically scale things.
> > > It does not show individual stage-ins and stage-outs. I'll have to think
> > > of a way to represent those on the plot without making it messy.
> > > It needs the logs to contain debugging info from individual tasks:
> > > log4j.logger.org.globus.cog.abstraction.impl.common.task.TaskImpl=DEBUG
> > > I've updated this in SVN, but if you want to run it on older builds, you
> > > need the above in log4j.properties.
> > > I attached a sample output.
> > > Mihael
