[Swift-devel] jobchart
Mihael Hategan hategan at mcs.anl.gov
Sat Mar 10 22:55:13 CST 2007
Preprocessing is the time between "Running job..." log message in
vdl-int.k and when the task status gets changed to "Submitted".
Postprocessing is between when the task status is changed to "Completed"
and the "Completed job" log message in vdl-int.k, and includes the check
for the exit code file.
Mihael
On Sat, 2007-03-10 at 22:51 -0600, Yong Zhao wrote:
> nice graph, what's preprocessing and postprocessing involved in this case?
> Yong.
> On Sat, 10 Mar 2007, Mihael Hategan wrote:
> > There's a new tool in bin.
> > It's a spin off Jens' "show-id" tool.
> > After careful analysis of show-id, it became apparent that a lot of the
> > difficulty was in gathering and organizing the data, rather than in
> > generating the plots. This one's written in python and lacks the command
> > line options to control sizes, but includes the logic in Jens' tool that
> > automatically scale things.
> > It does not show individual stage-ins and stage-outs. I'll have to think
> > of a way to represent those on the plot without making it messy.
> > It needs the logs to contain debugging info from individual tasks:
> > log4j.logger.org.globus.cog.abstraction.impl.common.task.TaskImpl=DEBUG
> > I've updated this in SVN, but if you want to run it on older builds, you
> > need the above in log4j.properties.
> > I attached a sample output.
> > Mihael
