[Swift-devel] generated java code for schema
    Ben Clifford
    benc at hawaga.org.uk
    Mon Mar  5 11:18:47 CST 2007
In r542 I removed lib/vdldefinitions.jar from the svn, because I saw that
the compileSchema target was modifying that.
On Mon, 5 Mar 2007, Yong Zhao wrote:
> right, there is also a library generated from the VDL.xsd and renamed and
> put in lib. We need to automate these carefully if we decide to take them
> out.
> Yong.
> On Mon, 5 Mar 2007, Ben Clifford wrote:
> > On Sun, 4 Mar 2007, Mihael Hategan wrote:
> > > On Sat, 2007-03-03 at 14:16 -0500, Ben Clifford wrote:
> > > > The .java files for org.griphyn.vdl.model look like they are compiled
> > > > from VDL.xsd by the compileSchema build target. Unless there's compelling
> > > > reason not to, these .java files shouldn't be in the SVN, and that build
> > > > target should get called as part of the build.
> > > I thought you removed them from SVN. I'm pretty sure I didn't add them
> > > back.
> > I think that was the stuff that ANTLR generated - this was a different
> > set, generated from the XML - the same but for the next language along the
> > pipeline...
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
