[Swift-devel] generated java code for schema
    Yong Zhao
    yongzh at cs.uchicago.edu
    Mon Mar  5 11:12:33 CST 2007
right, there is also a library generated from the VDL.xsd and renamed and
put in lib. We need to automate these carefully if we decide to take them
out.
Yong.
On Mon, 5 Mar 2007, Ben Clifford wrote:
> On Sun, 4 Mar 2007, Mihael Hategan wrote:
> > On Sat, 2007-03-03 at 14:16 -0500, Ben Clifford wrote:
> > > The .java files for org.griphyn.vdl.model look like they are compiled
> > > from VDL.xsd by the compileSchema build target. Unless there's compelling
> > > reason not to, these .java files shouldn't be in the SVN, and that build
> > > target should get called as part of the build.
> > I thought you removed them from SVN. I'm pretty sure I didn't add them
> > back.
> I think that was the stuff that ANTLR generated - this was a different
> set, generated from the XML - the same but for the next language along the
> pipeline...
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
