[Swift-devel] generated java code for schema
    Ben Clifford
    benc at hawaga.org.uk
    Mon Mar  5 05:46:25 CST 2007
On Sun, 4 Mar 2007, Mihael Hategan wrote:
> On Sat, 2007-03-03 at 14:16 -0500, Ben Clifford wrote:
> > The .java files for org.griphyn.vdl.model look like they are compiled
> > from VDL.xsd by the compileSchema build target. Unless there's compelling
> > reason not to, these .java files shouldn't be in the SVN, and that build
> > target should get called as part of the build.
> I thought you removed them from SVN. I'm pretty sure I didn't add them
> back.
I think that was the stuff that ANTLR generated - this was a different
set, generated from the XML - the same but for the next language along the
pipeline...
