[Swift-devel] generated java code for schema
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Mar  4 20:39:19 CST 2007
On Sat, 2007-03-03 at 14:16 -0500, Ben Clifford wrote:
> The .java files for org.griphyn.vdl.model look like they are compiled
> from VDL.xsd by the compileSchema build target. Unless there's compelling
> reason not to, these .java files shouldn't be in the SVN, and that build
> target should get called as part of the build.
I thought you removed them from SVN. I'm pretty sure I didn't add them
back.
