[Swift-devel] the big red swift site
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Mar  1 10:19:20 CST 2007
On Thu, 2007-03-01 at 10:09 -0600, Beth Cerny Patino wrote:
> Hi Mihael,
> Do you altered the site to scale in the main content area?
Yes. Made it larger since things were too squeezed in.
> If so, it
> does not display properly on my screen (I've attached a screen grab) -
> the side content goes below the main content.
Yes. A narrow enough browser window will cause that. Do you know a way
that keeps things relative as much as possible, yet the right side
properly positioned even on smaller windows?
> It will be best to switch it back or use style2.css  so that it looks
> like this http://www.ci.uchicago.edu/test/swift/index2.php. But you will
> want to let Ian know that you prefer the page to scale.
> Beth
> Mihael Hategan wrote:
> > On Wed, 2007-02-28 at 13:06 -0600, Mihael Hategan wrote:
> >> I'm going to change a few things, like remove certain sentences and
> >> links opening in new windows. I find the latter justified in too few
> >> cases and annoying in most.
> >> I'll also try to integrate the docs.
> >> So if it's ok with everybody, lock on www in about 45 minutes.
> > Done.
> >> Mihael
> >>> is beth on this list, btw?
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
