[Swift-devel] Re: [Swft] Q about throttling
    Ben Clifford
    benc at hawaga.org.uk
    Sat Jun 23 20:34:22 CDT 2007
On Sat, 23 Jun 2007, Mihael Hategan wrote:
> JobThrottle is a site score scaling factor. It limits the initial set of
> jobs sent to sites in order to achieve better load balancing in the long
> run. This could be a cause for low number of concurrent jobs. Set it to
> large numbers if you want to get rid of it.
the scaling factor gives a restriction in job load that is not dependent
on the presence of other sites?
the use of the word 'factor' has a subtle implication that it is a
relative load and so in the case of a single site will have no effect
