[Swift-devel] Re: [Swft] Q about throttling
Mihael Hategan hategan at mcs.anl.gov
Sat Jun 23 15:42:52 CDT 2007
On Fri, 2007-06-22 at 09:06 -0500, Ioan Raicu wrote:
> No, I didn't keep track of this info, unless Swift does this through
> some of its logs.
> Over the last week, my observations have been the following: Swift is
> more than capable and willing to send out many tasks as long as they
> are independent (as can be seen in this graph where probably 6800
> tasks got submitted), but thereafter, it had no other burst of task
> submission, although I believe it could have send out more.  For
> example, there were 2500+ tasks that failed in the middle of those
> 6800 tasks (which were all independent), why were 2500 tasks not
> resubmitted all at once... they were each about 200 seconds long, so
> most of them should have certainly showed up in the wait queue.
That's probably interpreter lag. It needs to do some work before
resubmitting all those jobs.
> Ioan
> Ben Clifford wrote:
> > > kept busy, and the Falkon queue length was relatively at 0... so this means
> > > that Swift was not submitting fast enough to keep all the executors busy.
> > interesting. though around t=1000 there is a rapid burst of submission
> > getting the queue length up to about 6000 in a few minutes.
> > Do you know what the cpu time usage of the swift submitting JVM was over
> > that time period?
> Ioan Raicu
> Ph.D. Student
> Distributed Systems Laboratory
> Computer Science Department
> University of Chicago
> 1100 E. 58th Street, Ryerson Hall
> Chicago, IL 60637
> Email: iraicu at cs.uchicago.edu
> Web:   http://www.cs.uchicago.edu/~iraicu
>        http://dsl.cs.uchicago.edu/
