[Swift-devel] Re: email for Mike and Ian
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Jun 20 05:22:24 CDT 2007
On Wed, 2007-06-20 at 00:27 +0000, Ben Clifford wrote:
> On Tue, 19 Jun 2007, Veronika Nefedova wrote:
> > I did update *many* times along the course of last couple of weeks, I
> > just didn't recompile my dtm files. And they worked just fine, btw.
> ok.
> Its probably a good idea from a swift testing perspective to be doing
> clean builds of the swiftscript programs (cleaning away the .xml and
> karajan files) regularly, even though it shouldn't affect the application
> side of things.
I think an even better idea would be for swift to recompile files if the
swift version has changed. That we can achieve by having a timestamp on
the swift build. If the kml files are older than that, a recompilation
should be forced.
Mihael
> > I do not know how it happened that I ended up with the old version of
> > swfit script -- it might've happened during those submit host-to-submit
> > host moves, and obviously it was not intentional to discard any new bug
> > fixes.
> You might stick stuff in version control and use that rather than copying
> files between machines - that can alleviate overwriting problems
> sometimes. Tibi's been keeping at least one of his apps in the SwiftApps/
> directory in the swift SVN.
