[Swift-devel] on the semantics of 'array closing'
Ian Foster foster at mcs.anl.gov
Mon Jun 18 21:54:21 CDT 2007
Interesting issue, as raised by Mike: it seems that we want to define a
"map" function that can specify various "conditions" on the map, e.g.,
the length of time to wait for results, what to do if not all results
are returned, etc. I wonder if others have done that before?
Ian Foster wrote:
> I like the notion of having a "map" function. If that could entirely
> replace the current element assignments, that would be a wonderful
> simplification, it seems to me.
> Ian.
> Ben Clifford wrote:
>> There's a different approach, which is to asay that 'a' is a variable and
>> can be assigned to once. Thus assignemnt syntax like a[0]=something
>> becomes illegal and we need more functional language constructs. So
>> instead of writing:
>> for e,i in input_array {
>>   output_array[i] = p(e);
>> we would write:
>> output_array = foreach i in input_array {
>>   return p(i);
>> (its a haskell map in different syntax!)
>> That means that, at the language level, output_array is now properly
>> single assignment.
>> On Fri, 15 Jun 2007, Ian Foster wrote:
>>> Hi,
>>> For:
>>>  a[0] = p()
>>>  a[1] = q()
>>>  b = s(a)
>>> I think there are two distinct issues.
>>> a) Determining the size of the array. This could presumably be done by
>>> declaring it, e.g.:
>>>  a[2] or some similar notion
>>>  a[0] = p()
>>>  a[1] = q()
>>>  b = s(a)
>>> or by some "closing" concept.
>>> b) Whether or not each element of an array is a separate single-assignment
>>> variable. If they are, then the code above should work just fine. If they are
>>> not, then we have a couple of behaviors we could define. One would be that
>>> b=s(a) blocks until all elements in "a" are defined. The other is that we have
>>> a way of "closing" (once again). In that case, we have to define what happens
>>> if b=s(a) accesses an element that is not defined.
>>> Ian.
>>> Ben Clifford wrote:
>>>> There is a problem that has been called the 'array closing problem'.
>>>> It manifests itself in the tutorial in that certain bits of code that
>>>> intuitively can either in a procedure or in the top level can, in practice,
>>>> only go in to a procedure.
>>>> In that context, I tried to think about better ways to explain/document the
>>>> behaviour than "mumble mumble move that code into a procedure".
>>>> In Swift we claim to have 'single assignment variables'.
>>>> >From single assignment variables we get our grid job ordering:
>>>>   a = p()
>>>>   b = s(a)
>>>> causes first grid job p to run, and when that has completed, then grid job s
>>>> will run.
>>>> This is the same as if we had written:
>>>>   b = s(a)
>>>>   a = p()
>>>> The ordering comes from the use of a as an 'output' for p and an 'input' for
>>>> s, not from source text ordering.
>>>> In that model, its meaningless to assign two different things ta a, like
>>>> this:
>>>>   a = p()
>>>>   b = s(a)
>>>>   a = t()
>>>> Note that I've omitted the data types from the above. This works in the
>>>> implementation for simple types such as a datafile marker type.
>>>> What is important is that each variable is either unassigned or has its
>>>> single value - whenever we refer to that variable, we can either use the
>>>> value it has, or defer evaluation of that expression until the variable has
>>>> its value.
>>>> Now consider arrays. In the present syntax, arrays can be passed as single
>>>> (complex) values to/from procedures, like before:
>>>>   a = p()
>>>>   b = s(a)
>>>> Here a and b are array types.
>>>> That's fine. a is assigned to by the first statement, and b is assigned to
>>>> by the second statement.
>>>> But we also support a different assignment syntax for arrays, that looks
>>>> like this:
>>>>   a[0] = p()
>>>>   a[1] = q()
>>>>   b = s(a)
>>>> This fails at the moment (specifically, I think the execution engine will
>>>> hang).
>>>> Why? Because the is no one point at which we assign a value to 'a' - the
>>>> assignment is split over multiple statements, which can be in various places
>>>> (and inside loops etc).
>>>> There is nothing in the implementation that detects that a has been assigned
>>>> its value.
>>>> So there is this notion in the karajan intermediate code of 'closing an
>>>> array'.  This is an assertion made in the object code that all assignments
>>>> to pieces of an array have been made - that, in affect, the array has its
>>>> value.
>>>> The suggested hack/workaround for this is to move the array element
>>>> assignments into a procedure:
>>>>  (file f[]) z() {
>>>>    f[0] = p();
>>>>    f[1] - q();
>>>>  a = z()
>>>>  b = s(a)
>>>> This works. (which is sort-of a violation of referential transparency)
>>>> It works because Swift implicitly marks arrays returned from compound
>>>> procedures as closed (which may or may not be correct).
>>>> So in most variable scopes, arrays behave like single-assignment variables,
>>>> but each array can have one specific scope in which members can be assigned
>>>> to. In that scope, the array cannot be treated as a whole variable.
>>>> In the z() example above, that special scope is the body of z(). In the
>>>> previous example, that scope is the global scope, and the program is invalid
>>>> by the rule above that the array cannot be referred to as a whole in the
>>>> same place that its members are individually assigned to.
>>>> That's my explanation of what's going on now. I think it matches reality. I
>>>> don't like that this is reality, but it is what we have.
>>>> Comments appreciated.
>    Ian Foster, Director, Computation Institute
> Argonne National Laboratory & University of Chicago
> Argonne: MCS/221, 9700 S. Cass Ave, Argonne, IL 60439
> Chicago: Rm 405, 5640 S. Ellis Ave, Chicago, IL 60637
> Tel: +1 630 252 4619.  Web: www.ci.uchicago.edu.
>       Globus Alliance: www.globus.org.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070618/4953383d/attachment.html>
