[Swift-devel] on the semantics of 'array closing'
Mike Wilde wilde at mcs.anl.gov
Sat Jun 16 12:14:20 CDT 2007
I have to say for the record that I'm ready to concede victory to
the functional camp in this discussion. (This is like conceding
defeat but with a positive spin. If you cant beat 'em join 'em ;)
I've previously felt that functional programming would be too hard
to sell to our user base.
But clearly Ben, Mihael and Ian are all in the f-camp.
As long as we take it all the way, and work through all our existing
docs, tutorials and application codes to make sure that the
functional way of expressing things has clean elegant semantics, is
clean to write and efficient to reliably implement, I think we're on
a good path.
The first criteria of a successful programming tool is that its
implementers love it and use it effectively.  If they do, the user
community is likely to follow along, grow and be successful. And as
long as we meet that criteria I am happy that we are on the right track.
So lets function-away, do it right and make it work. Lets try keep
the syntax close to its current c-like form to make the language
"look" more palatable to the imperative hordes. I.e.  where you
*can* express things in a c-like form, do so, for comfort and
readability.
Ben, Mihael: you have the green light to move the language in that
direction.
Any objections - speak now!
- Mike
Ian Foster wrote, On 6/16/2007 11:01 AM:
> I like the notion of having a "map" function. If that could entirely
> replace the current element assignments, that would be a wonderful
> simplification, it seems to me.
> Ian.
> Ben Clifford wrote:
>> There's a different approach, which is to asay that 'a' is a variable and
>> can be assigned to once. Thus assignemnt syntax like a[0]=something
>> becomes illegal and we need more functional language constructs. So
>> instead of writing:
>> for e,i in input_array {
>>   output_array[i] = p(e);
>> we would write:
>> output_array = foreach i in input_array {
>>   return p(i);
>> (its a haskell map in different syntax!)
>> That means that, at the language level, output_array is now properly
>> single assignment.
>> On Fri, 15 Jun 2007, Ian Foster wrote:
>>> Hi,
>>> For:
>>>  a[0] = p()
>>>  a[1] = q()
>>>  b = s(a)
>>> I think there are two distinct issues.
>>> a) Determining the size of the array. This could presumably be done by
>>> declaring it, e.g.:
>>>  a[2] or some similar notion
>>>  a[0] = p()
>>>  a[1] = q()
>>>  b = s(a)
>>> or by some "closing" concept.
>>> b) Whether or not each element of an array is a separate single-assignment
>>> variable. If they are, then the code above should work just fine. If they are
>>> not, then we have a couple of behaviors we could define. One would be that
>>> b=s(a) blocks until all elements in "a" are defined. The other is that we have
>>> a way of "closing" (once again). In that case, we have to define what happens
>>> if b=s(a) accesses an element that is not defined.
>>> Ian.
>>> Ben Clifford wrote:
>>>> There is a problem that has been called the 'array closing problem'.
>>>> It manifests itself in the tutorial in that certain bits of code that
>>>> intuitively can either in a procedure or in the top level can, in practice,
>>>> only go in to a procedure.
>>>> In that context, I tried to think about better ways to explain/document the
>>>> behaviour than "mumble mumble move that code into a procedure".
>>>> In Swift we claim to have 'single assignment variables'.
>>>> >From single assignment variables we get our grid job ordering:
>>>>   a = p()
>>>>   b = s(a)
>>>> causes first grid job p to run, and when that has completed, then grid job s
>>>> will run.
>>>> This is the same as if we had written:
>>>>   b = s(a)
>>>>   a = p()
>>>> The ordering comes from the use of a as an 'output' for p and an 'input' for
>>>> s, not from source text ordering.
>>>> In that model, its meaningless to assign two different things ta a, like
>>>> this:
>>>>   a = p()
>>>>   b = s(a)
>>>>   a = t()
>>>> Note that I've omitted the data types from the above. This works in the
>>>> implementation for simple types such as a datafile marker type.
>>>> What is important is that each variable is either unassigned or has its
>>>> single value - whenever we refer to that variable, we can either use the
>>>> value it has, or defer evaluation of that expression until the variable has
>>>> its value.
>>>> Now consider arrays. In the present syntax, arrays can be passed as single
>>>> (complex) values to/from procedures, like before:
>>>>   a = p()
>>>>   b = s(a)
>>>> Here a and b are array types.
>>>> That's fine. a is assigned to by the first statement, and b is assigned to
>>>> by the second statement.
>>>> But we also support a different assignment syntax for arrays, that looks
>>>> like this:
>>>>   a[0] = p()
>>>>   a[1] = q()
>>>>   b = s(a)
>>>> This fails at the moment (specifically, I think the execution engine will
>>>> hang).
>>>> Why? Because the is no one point at which we assign a value to 'a' - the
>>>> assignment is split over multiple statements, which can be in various places
>>>> (and inside loops etc).
>>>> There is nothing in the implementation that detects that a has been assigned
>>>> its value.
>>>> So there is this notion in the karajan intermediate code of 'closing an
>>>> array'.  This is an assertion made in the object code that all assignments
>>>> to pieces of an array have been made - that, in affect, the array has its
>>>> value.
>>>> The suggested hack/workaround for this is to move the array element
>>>> assignments into a procedure:
>>>>  (file f[]) z() {
>>>>    f[0] = p();
>>>>    f[1] - q();
>>>>  a = z()
>>>>  b = s(a)
>>>> This works. (which is sort-of a violation of referential transparency)
>>>> It works because Swift implicitly marks arrays returned from compound
>>>> procedures as closed (which may or may not be correct).
>>>> So in most variable scopes, arrays behave like single-assignment variables,
>>>> but each array can have one specific scope in which members can be assigned
>>>> to. In that scope, the array cannot be treated as a whole variable.
>>>> In the z() example above, that special scope is the body of z(). In the
>>>> previous example, that scope is the global scope, and the program is invalid
>>>> by the rule above that the array cannot be referred to as a whole in the
>>>> same place that its members are individually assigned to.
>>>> That's my explanation of what's going on now. I think it matches reality. I
>>>> don't like that this is reality, but it is what we have.
>>>> Comments appreciated.
>    Ian Foster, Director, Computation Institute
> Argonne National Laboratory & University of Chicago
> Argonne: MCS/221, 9700 S. Cass Ave, Argonne, IL 60439
> Chicago: Rm 405, 5640 S. Ellis Ave, Chicago, IL 60637
> Tel: +1 630 252 4619.  Web: www.ci.uchicago.edu.
>       Globus Alliance: www.globus.org.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Mike Wilde
Computation Institute, University of Chicago
Math & Computer Science Division
Argonne, IL   60439    USA
tel 630-252-7497 fax 630-252-1997
