[Swift-devel] CPU usage with provider-deef
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Mon Jun 18 16:37:48 CDT 2007
There is a diagram in the SC paper that has the flow of messages, and
what each does; these messages also map to the WSDL of the Falkon
service.  Mihael, Ben, or whoever else wants to start digging through
the Falkon code, maybe a meeting might be good to go over the
organization of the code, the message flow diagram, configuration
options, etc...  I would prefer a meeting over drafting up more
documents, I think it would be more time effective for me for now.
Ioan
Ben Clifford wrote:
> The WSDL should describe part of the web services bit of the protocol.
> That might be a good place to start. The WSDL should already describe the
> messages that go over the wire in something vaguely readable to a human.
> Probably what would be needed would be the extra info to say which order
> messages are sent.
> On Sat, 16 Jun 2007, Mike Wilde wrote:
>> I think a nice clean message sequence chart describing Falkon's various
>> activities would be very useful, as its the backbone of its logic.
>> I tried to create this for the SC paper by asking Ioan to describe the
>> protocol to me, but I dod not succeed.
>> I think this would be a very useful description to maintain, as a UML sequence
>> chart, and that Ioan this would be a very important part of your thesis or of
>> future papers.
>> Its up to you and Ian to weigh whether this would be valuable to your
>> research.  I think its invaluable for design, review and debugging.
>> - Mike
>> Mihael Hategan wrote, On 6/16/2007 3:15 PM:
>>> On Sat, 2007-06-16 at 19:52 +0000, Ian Foster wrote:
>>>> I wasn't suggesting (at least in the first instance) that Mihael take the
>>>> prototype and turn it into production, but that Mihael and Ioan sit down
>>>> together and do a code walkthrough. I think that this would likely
>>>> identify bugs and opportunities for simplification.
>>> It's somewhat on the same in level of fun :). From the experience I've
>>> accumulated so far, design is hard. Understanding prototype design is
>>> probably even harder (not only do you need to understand the problem,
>>> you also need to understand why many non-obvious things are done the way
>>> they are done).
>>> Mihael
>>>> Ian
>>>> Sent via BlackBerry from T-Mobile
>>>> -----Original Message-----
>>>> From: Ben Clifford <benc at hawaga.org.uk>
>>>> Date: Sat, 16 Jun 2007 19:36:17 To:Mihael Hategan <hategan at mcs.anl.gov>
>>>> Cc:swift-devel at ci.uchicago.edu
>>>> Subject: Re: [Swift-devel] CPU usage with provider-deef
>>>> On Sat, 16 Jun 2007, Mihael Hategan wrote:
>>>>> On Sat, 2007-06-16 at 12:03 -0500, Mike Wilde wrote:
>>>>>> This should be fun, and a nice break from the I2U2 work that you've
>>>>>> been immersed in, Mihael.
>>>>> I have my reservations towards the amount of fun it involves.
>>>> Right, taking prototypes and turning them into production isn't
>>>> necessarily fun - in fact, a lot of the fun already happened with the
>>>> making of the prototype and the rest is some what drugery. (to an extent
>>>> that's the same situation i2u2 cosmic was/is in).
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070618/8e8c5522/attachment.html>
