[Swift-devel] CPU usage with provider-deef
Ioan Raicu iraicu at cs.uchicago.edu
Sat Jun 16 15:16:32 CDT 2007
Great!  Then I'll plan to have a clean-up version in SVN by then :)
Ioan
Mihael Hategan wrote:
> On Sat, 2007-06-16 at 14:47 -0500, Ioan Raicu wrote:
>> Yes, I know I need to clean up the code, and remove unused (dead)
>> code.  Can this wait for the next version I am working on, so I don't
>> do this clean-up twice?  The version that is out there in testing
>> currently is v0.8.  My development version is v0.9.  I have been
>> distracted lately from finishing up v0.9, but its not far from being
>> complete.  Mihael, when do you get back in town?
> I should be in Chicago on 23rd.
> Mihael
>> If this is something more urgent, then perhaps I can get you a
>> clean-up version of v0.8 in the coming week.
>> Ioan
>>> On Sat, 2007-06-16 at 12:03 -0500, Mike Wilde wrote:
>>>> This should be fun, and a nice break from the I2U2 work that you've
>>>> been immersed in, Mihael.
>>> I've already looked at the Falkon code and it's... a lot of code that
>>> does stuff that I understand only in principle. What you want isn't
>>> easy, and I have my reservations towards the amount of fun it involves.
>>> That being said, Ioan, would it be possible to have a cleaned up version
>>> of the code where there are no duplicate classes? It's hard for me to
>>> figure what's relevant or not in that case. And perhaps dead
>>> code/comments removed?
>>> Mihael
>>>> Want to do a read-through soon, and send out comments for discussion
>>>> that can turn into a list of code improvements to bugzilize?
>>>> What I think is important about Falkon is that its working, its
>>>> proving out the value of the provisioned direct-scheduling approach
>>>> with numbers, and that its working for Ioan as a vehicle for his
>>>> research.
>>>> What we want to get from the effort is a) Ioan progresses towards
>>>> his PhD; b) the immediate needs of our app-users get met; and c) we
>>>> learn whats needed in architecture, protocol and algorithm for a
>>>> successful long-term approach to running swift programs efficiently.
>>>> Point is that everyone is open to changes and towards an eventual
>>>> re-design and re-write. This, Mihael, would be where you can
>>>> propose, design and implement the ideas you've expressed about
>>>> implementing provisioned direct-scheduling using Karajan's remote
>>>> execution mechanisms.
>>>> - Mike
>>>> Ian Foster wrote, On 6/16/2007 10:59 AM:
>>>>> It seems important that Ioan sit down with Mihael and work through the
>>>>> Falkon code to see where it can be simplified, improved, etc. I am sure
>>>>> that this will result in problems being identified and fixed that will
>>>>> otherwise cost us time later.
>>>>>> Yourkit (www.yourkit.com) has free licenses for open source projects for
>>>>>> their profiler. Point them to a globus web page that has your name, and
>>>>>> they'll send you the license. Alternatively, there are other profilers
>>>>>> out there, and I strongly recommend using them on such issues.
>>>>>> Mihael
>>>>>> On Sat, 2007-06-16 at 10:00 -0500, Ioan Raicu wrote:
>>>>>>> Nope, I think this is a different problem, or at least a subset of the
>>>>>>> problems we were having before.
>>>>>>> Since we fixed the CPU utilization, and we moved to a bigger box (4
>>>>>>> CPUs with 2GB of memory), everything is happening in a timely fashion
>>>>>>> (a few ms per notification delivery throughout the experiment).  Plus,
>>>>>>> I believe the view is consistent (the same tasks look complete on both
>>>>>>> ends) between Falkon and Swift, but we are still checking on this as
>>>>>>> the run was made just last night for the 100 mol run.  We'll keep you
>>>>>>> posted with what we find.
>>>>>>> Ioan
>>>>>>> Ben Clifford wrote:
>>>>>>>> On Sat, 16 Jun 2007, Ioan Raicu wrote:
>>>>>>>>> having problems with the 100 molecule run in MolDyn.  Its not clear where the
>>>>>>>>> problem is, on the surface Falkon looks fine... we are looking into where
>>>>>>>>> everything breaks to cause Swift to not continue with the workflow to
>>>>>>>>> completion!
>>>>>>>> The same problem that you showed me the other day or different?
>>>>>>>> with 'the same problem' being that falkon thinks all the jobs are done;
>>>>>>>> but that falkon's measure response time for sending completion
>>>>>>>> notifications gets approximately linearly longer over time and the swift
>>>>>>>> JVM uses ~100% and doesn't inidicate job completion at all after a certain
>>>>>>>> period.
>>>>>>>> or different symptoms now?
>>>>>>> Ioan Raicu
>>>>>>> Ph.D. Student
>>>>>>> Distributed Systems Laboratory
>>>>>>> Computer Science Department
>>>>>>> University of Chicago
>>>>>>> 1100 E. 58th Street, Ryerson Hall
>>>>>>> Chicago, IL 60637
>>>>>>> Email: iraicu at cs.uchicago.edu
>>>>>>> Web:   http://www.cs.uchicago.edu/~iraicu
>>>>>>>        http://dsl.cs.uchicago.edu/
>>>>>    Ian Foster, Director, Computation Institute
>>>>> Argonne National Laboratory & University of Chicago
>>>>> Argonne: MCS/221, 9700 S. Cass Ave, Argonne, IL 60439
>>>>> Chicago: Rm 405, 5640 S. Ellis Ave, Chicago, IL 60637
>>>>> Tel: +1 630 252 4619.  Web: www.ci.uchicago.edu.
>>>>>       Globus Alliance: www.globus.org.
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> Ioan Raicu
>> Ph.D. Student
>> Chicago, IL 60637
Ioan Raicu
Ph.D. Student
Chicago, IL 60637
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070616/da2c0527/attachment.html>
