[Swift-devel] CPU usage with provider-deef
Ben Clifford benc at hawaga.org.uk
Sat Jun 16 15:01:48 CDT 2007
At some point you need to switch to developing in SVN so that others can
play along. Freezing your development, sending me a tarball, waiting for
me to import to SVN, and then unfreezing your development and continuing
from an SVN checkout is approximately the easiest I can make it for you.
On Sat, 16 Jun 2007, Ioan Raicu wrote:
> Yes, I know I need to clean up the code, and remove unused (dead) code.  Can
> this wait for the next version I am working on, so I don't do this clean-up
> twice?  The version that is out there in testing currently is v0.8.  My
> development version is v0.9.  I have been distracted lately from finishing up
> v0.9, but its not far from being complete.  Mihael, when do you get back in
> town?
> If this is something more urgent, then perhaps I can get you a clean-up
> version of v0.8 in the coming week.
> Ioan
> Mihael Hategan wrote:
> > On Sat, 2007-06-16 at 12:03 -0500, Mike Wilde wrote:
> > > This should be fun, and a nice break from the I2U2 work that you've been
> > > immersed in, Mihael.
> > I've already looked at the Falkon code and it's... a lot of code that
> > does stuff that I understand only in principle. What you want isn't
> > easy, and I have my reservations towards the amount of fun it involves.
> > That being said, Ioan, would it be possible to have a cleaned up version
> > of the code where there are no duplicate classes? It's hard for me to
> > figure what's relevant or not in that case. And perhaps dead
> > code/comments removed?
> > Mihael
> > > Want to do a read-through soon, and send out comments for discussion that
> > > can turn into a list of code improvements to bugzilize?
> > > What I think is important about Falkon is that its working, its proving
> > > out the value of the provisioned direct-scheduling approach with numbers,
> > > and that its working for Ioan as a vehicle for his research.
> > > What we want to get from the effort is a) Ioan progresses towards his PhD;
> > > b) the immediate needs of our app-users get met; and c) we learn whats
> > > needed in architecture, protocol and algorithm for a successful long-term
> > > approach to running swift programs efficiently.
> > > Point is that everyone is open to changes and towards an eventual
> > > re-design and re-write. This, Mihael, would be where you can propose,
> > > design and implement the ideas you've expressed about implementing
> > > provisioned direct-scheduling using Karajan's remote execution mechanisms.
> > > - Mike
> > > Ian Foster wrote, On 6/16/2007 10:59 AM:
> > > > It seems important that Ioan sit down with Mihael and work through the
> > > > Falkon code to see where it can be simplified, improved, etc. I am sure
> > > > that this will result in problems being identified and fixed that will
> > > > otherwise cost us time later.
> > > > > Yourkit (www.yourkit.com) has free licenses for open source projects
> > > > > for
> > > > > their profiler. Point them to a globus web page that has your name,
> > > > > and
> > > > > they'll send you the license. Alternatively, there are other profilers
> > > > > out there, and I strongly recommend using them on such issues.
> > > > > Mihael
> > > > > On Sat, 2007-06-16 at 10:00 -0500, Ioan Raicu wrote:
> > > > > > Nope, I think this is a different problem, or at least a subset of
> > > > > > the
> > > > > > problems we were having before.
> > > > > > Since we fixed the CPU utilization, and we moved to a bigger box (4
> > > > > > CPUs with 2GB of memory), everything is happening in a timely
> > > > > > fashion
> > > > > > (a few ms per notification delivery throughout the experiment).
> > > > > > Plus,
> > > > > > I believe the view is consistent (the same tasks look complete on
> > > > > > both
> > > > > > ends) between Falkon and Swift, but we are still checking on this as
> > > > > > the run was made just last night for the 100 mol run.  We'll keep
> > > > > > you
> > > > > > posted with what we find.
> > > > > > Ioan
> > > > > > > > having problems with the 100 molecule run in MolDyn.  Its not
> > > > > > > > clear where the
> > > > > > > > problem is, on the surface Falkon looks fine... we are looking
> > > > > > > > into where
> > > > > > > > everything breaks to cause Swift to not continue with the
> > > > > > > > workflow to
> > > > > > > > completion!
> > > > > > > The same problem that you showed me the other day or different?
> > > > > > > with 'the same problem' being that falkon thinks all the jobs are
> > > > > > > done; but that falkon's measure response time for sending
> > > > > > > completion notifications gets approximately linearly longer over
> > > > > > > time and the swift JVM uses ~100% and doesn't inidicate job
> > > > > > > completion at all after a certain period.
> > > > > > > or different symptoms now?
> > > > > > Ioan Raicu
> > > > > > Ph.D. Student
> > > > > > Distributed Systems Laboratory
> > > > > > Computer Science Department
> > > > > > University of Chicago
> > > > > > 1100 E. 58th Street, Ryerson Hall
> > > > > > Chicago, IL 60637
> > > > > > Email: iraicu at cs.uchicago.edu
> > > > > > Web:   http://www.cs.uchicago.edu/~iraicu
> > > > > >        http://dsl.cs.uchicago.edu/
> > > >    Ian Foster, Director, Computation Institute
> > > > Argonne National Laboratory & University of Chicago
> > > > Argonne: MCS/221, 9700 S. Cass Ave, Argonne, IL 60439
> > > > Chicago: Rm 405, 5640 S. Ellis Ave, Chicago, IL 60637
> > > > Tel: +1 630 252 4619.  Web: www.ci.uchicago.edu.
> > > >       Globus Alliance: www.globus.org.
> > > > _______________________________________________
> > > > Swift-devel mailing list
> > > > Swift-devel at ci.uchicago.edu
> > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
