[Swift-devel] CPU usage with provider-deef
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Jun 16 03:58:26 CDT 2007
That can either be good or bad. If the CPU is used doing meaningful
stuff, then it's good. In other words, I'm guessing that the job
throughput is also higher with Falkon.
Mihael
On Fri, 2007-06-15 at 16:48 +0000, Ben Clifford wrote:
> Yesterday, I was playing a bit with Ioan and Nika - they submitted a 68
> node / 15 minute workflow through provider-deef & falkon and saw the swift
> JVM on the submit node using about 100% CPU; then the same workflow
> running through the GT2 GRAM provider rather than provider-deef and falkon
> appeared to use significantly less.
> I wandered off at that point so don't know if any interesting results came
> after.
