[Swift-devel] LQCD meeting at Fermi
    Yong Zhao
    yongzh at cs.uchicago.edu
    Fri Jun  1 21:10:28 CDT 2007
It is case (i), they want to read some paramenter settings from db. But I
do not think the two cases are very different, we are to map something
from database into in-memory data structures.
Yong.
On Fri, 1 Jun 2007, Ben Clifford wrote:
> On Fri, 1 Jun 2007, Veronika Nefedova wrote:
> > - DB-mapper: users have an elaborate input data structures, keep it in the DB,
> > so it would be nice to have a mapper that would read the input from the DB.
> > This feature is in the works (?)
> (i) The *data* in a DB, or
> (ii) paths to datafiles in the DB with actual data
> stored in disk files?
> (i) is much harder than (ii)
> > - Dealing with absolute path:
> >  LQCD uses dcache, which requires copying to/from some absolute path.
> By this do you mean that their input/output files are stored in the unix
> filesystem on the submit node, but in some directory that is not the pwd,
> and that that directory causes files to be accessed from dcache?
> dcache has other access methods, such as gridftp (I think). Do you know if
> they use that? in some cases, but maybe not this case, staging from dcache
> ftp server to site workspace without going via submit node.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
