[Swift-devel] loops and strings
Veronika Nefedova
nefedova at mcs.anl.gov
Fri Jul 27 10:50:51 CDT 2007
So how else then I construct a string in swift ?
On Jul 27, 2007, at 10:46 AM, Mihael Hategan wrote:
> Variables in swift are single assignment. You can't assign to a
> variable
> twice. What, in your opinion, should the error message be instead
> of the
> current one?
> On Fri, 2007-07-27 at 10:22 -0500, Veronika Nefedova wrote:
>> I am not sure if its possible to do string operations inside the loop
>> in swift?
>> I have a versy simple test code that doesn't work no matter what.
>> Obviously, I am missing something.
>> This is the code:
>> file fls[]<filesys_mapper;pattern="*.prt",location=".">;
>> string wham_string = "#";
>> foreach prt_file in fls
>> wham_string = @strcat (wham_string, ", wham");
>> print (wham_string);
>> basically I expect to have this as an output:
>> #,wham,wham,wham,wham,... (its a test code (-;)
>> instead I have these errors:
>> wham_string is already assigned with a value of #
>> vdl:assign @ test.kml, line: 46
>> vdl:mains @ test.kml, line: 39
>> Caused by: java.lang.IllegalArgumentException: wham_string is already
>> at org.griphyn.vdl.mapping.AbstractDataNode.setValue
>> (AbstractDataNode.java:255)
>> at org.griphyn.vdl.karajan.lib.Assign.function
>> (Assign.java:70)
>> <snip>
>> In any case -- if I can't construct the string by using the loop -
>> how else could it be done?
>> I use the constructed string then to map an array (I understand I
>> can't map individual array elements):
>> file whamfiles_$s[] <fixed_array_mapper;files="$wham_string">; //it
>> was in the wrapper script before)
>> Nika
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
