[Swift-devel] loops and strings
Mihael Hategan
hategan at mcs.anl.gov
Fri Jul 27 10:46:06 CDT 2007
Variables in swift are single assignment. You can't assign to a variable
twice. What, in your opinion, should the error message be instead of the
current one?
On Fri, 2007-07-27 at 10:22 -0500, Veronika Nefedova wrote:
> I am not sure if its possible to do string operations inside the loop
> in swift?
> I have a versy simple test code that doesn't work no matter what.
> Obviously, I am missing something.
> This is the code:
> file fls[]<filesys_mapper;pattern="*.prt",location=".">;
> string wham_string = "#";
> foreach prt_file in fls
> wham_string = @strcat (wham_string, ", wham");
> print (wham_string);
> basically I expect to have this as an output:
> #,wham,wham,wham,wham,... (its a test code (-;)
> instead I have these errors:
> wham_string is already assigned with a value of #
> vdl:assign @ test.kml, line: 46
> vdl:mains @ test.kml, line: 39
> Caused by: java.lang.IllegalArgumentException: wham_string is already
> at org.griphyn.vdl.mapping.AbstractDataNode.setValue
> (AbstractDataNode.java:255)
> at org.griphyn.vdl.karajan.lib.Assign.function(Assign.java:70)
> <snip>
> In any case -- if I can't construct the string by using the loop -
> how else could it be done?
> I use the constructed string then to map an array (I understand I
> can't map individual array elements):
> file whamfiles_$s[] <fixed_array_mapper;files="$wham_string">; //it
> was in the wrapper script before)
> Nika
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
