[Swift-devel] Re: Falkon code and logs
Ben Clifford
benc at hawaga.org.uk
Wed Jul 25 12:03:20 CDT 2007
ja I saw that. Easy to move, which I am doing now. Please wait.
On Wed, 25 Jul 2007, Mihael Hategan wrote:
> Aaargh! It's being imported into the root not the falkon directory!
> On Wed, 2007-07-25 at 16:13 +0000, Ben Clifford wrote:
> > On Mon, 16 Jul 2007, Ioan Raicu wrote:
> > > Hey Ben,
> > > Here is the latest Falkon code base, including all compiled classes, scripts,
> > > libraries, 1.4 JRE, ploticus binaries, GT4 WS-core container, web server,
> > > etc... its the entire branch that is needed containing all the different
> > > Falkon components. I would have preffered to clean things up a bit, but here
> > > it is, and I'll do the clean-up later...
> > > http://people.cs.uchicago.edu/~iraicu/research/Falkon/Falkon_v0.8.1.tgz
> > I just imported this into the vdl2 subversion repo.
> > Type:
> > svn co https://svn.ci.uchicago.edu/svn/vdl2/falkon
> > to get the checkout.
> > I removed the embedded JRE (putting aside issues of whether we should big
> > binaries like that in the SVN, a quick glance at the JRE redistribution
> > licence looked like it was not something acceptable)
> > If you edit files, you can commit them with:
> > svn commit
> > which will require you to feed in your CI password.
> > Type svn update in the root directory of your checkout to pull down
> > changes that other people have made since your last checkout/update
> > (probably you'll find me making a bunch of those to tidy some things up)
> > If you add files, you will need to:
> > svn add myfile.java
> > before committing it.
> > This is the tarball as I received it, so has lots of built cruft in there
> > (.class files and things).
> > I'll help work on tidying that up in the repository.
> > Please commit any changes you have made since this tarball, and begin
> > making your releases from committed SVN code rather than from your own
> > private codebase - that way, people can talk about 'falkon built from
> > r972' and then everyone can look at the exact code version from SVN.
