[Swift-devel] Re: Falkon code and logs
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Jul 25 12:01:33 CDT 2007
Aaargh! It's being imported into the root not the falkon directory!
On Wed, 2007-07-25 at 16:13 +0000, Ben Clifford wrote:
> On Mon, 16 Jul 2007, Ioan Raicu wrote:
> > Hey Ben,
> > Here is the latest Falkon code base, including all compiled classes, scripts,
> > libraries, 1.4 JRE, ploticus binaries, GT4 WS-core container, web server,
> > etc... its the entire branch that is needed containing all the different
> > Falkon components.  I would have preffered to clean things up a bit, but here
> > it is, and I'll do the clean-up later...
> > http://people.cs.uchicago.edu/~iraicu/research/Falkon/Falkon_v0.8.1.tgz
> I just imported this into the vdl2 subversion repo.
> Type:
>    svn co https://svn.ci.uchicago.edu/svn/vdl2/falkon
> to get the checkout.
> I removed the embedded JRE (putting aside issues of whether we should big
> binaries like that in the SVN, a quick glance at the JRE redistribution
> licence looked like it was not something acceptable)
> If you edit files, you can commit them with:
>  svn commit
> which will require you to feed in your CI password.
> Type svn update in the root directory of your checkout to pull down
> changes that other people have made since your last checkout/update
> (probably you'll find me making a bunch of those to tidy some things up)
> If you add files, you will need to:
>  svn add myfile.java
> before committing it.
> This is the tarball as I received it, so has lots of built cruft in there
> (.class files and things).
> I'll help work on tidying that up in the repository.
> Please commit any changes you have made since this tarball, and begin
> making your releases from committed SVN code rather than from your own
> private codebase - that way, people can talk about 'falkon built from
> r972' and then everyone can look at the exact code version from SVN.
