[Swift-devel] Re: Karajan problem?
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Fri Jul  6 13:33:59 CDT 2007
Yep! Thanks for the tip (;
On Jul 6, 2007, at 1:29 PM, Mihael Hategan wrote:
> I'm assuming you see the problem with that.
> On Fri, 2007-07-06 at 13:20 -0500, Veronika Nefedova wrote:
>> Yes, I am:
>> file outfiles <fixed_array_mapper;files="solv_chg.out, solv_disp.out,
>> solv_repu_0_0.2.out, solv_repu_0.2_0.3.out, solv_repu_0.3_0.4.out,
>> solv_repu_0.4_0.5.out, solv_repu_0.5_0.6.out, solv_repu_0.6_0.7.out,
>> solv_repu_0.7_0.8.out, solv_repu_0.8_0.9.out, solv_repu_0.9_1.out">;
>> outfiles [0] = CHARMM4 (solv_chg, whaminp, s1, "input:solv_chg");
>> <snip>
>> On Jul 6, 2007, at 1:18 PM, Mihael Hategan wrote:
>>> Are you trying to access a file as an array? As in
>>> file x;
>>> x[1]
>>> On Fri, 2007-07-06 at 12:38 -0500, Veronika Nefedova wrote:
>>>> Hi, Mihael:
>>>> I am testing now my new code (with loops and various string
>>>> operations!) but I am getting some Karajan errors. I am
>>>> wondering if
>>>> you could point me to a possible reason for these errors? I do not
>>>> see any reference to my code so I am not sure where to start
>>>> looking...
>>>> org.griphyn.vdl.mapping.InvalidPathException: Invalid path (1) for
>>>> type file
>>>> type file
>>>> Caused by: org.griphyn.vdl.mapping.InvalidPathException: Invalid
>>>> path
>>>> (1) for type file
>>>>          at org.griphyn.vdl.karajan.lib.GetField.function
>>>> (GetField.java:33)
>>>>          at org.griphyn.vdl.karajan.lib.VDLFunction.post
>>>> (VDLFunction.java:58)
>>>>          at
>>>> org.globus.cog.karajan.workflow.nodes.Sequential.startNext
>>>> (Sequential.java:51)
>>>>          at
>>>> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren
>>>> (Sequential.java:27)
>>>>          at
>>>> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute
>>>> (FlowContainer.java:63)
>>>>          at org.globus.cog.karajan.workflow.nodes.FlowNode.restart
>>>> (FlowNode.java:239)
>>>>          at org.globus.cog.karajan.workflow.nodes.FlowNode.start
>>>> (FlowNode.java:280)
>>>>          at
>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent
>>>> (FlowNode.java:392)
>>>>          at org.globus.cog.karajan.workflow.nodes.FlowNode.event
>>>> (FlowNode.java:331)
>>>>          at
>>>> org.globus.cog.karajan.workflow.FlowElementWrapper.event
>>>> (FlowElementWrapper.java:227)
>>>>          at org.globus.cog.karajan.workflow.events.EventBus.send
>>>> (EventBus.java:123)
>>>>          at
>>>> org.globus.cog.karajan.workflow.events.EventBus.sendHooked
>>>> (EventBus.java:97)
>>>>          at org.globus.cog.karajan.workflow.events.EventWorker.run
>>>> (EventWorker.java:69)
>>>> path
>>>> (1) for type file
>>>>          at org.griphyn.vdl.mapping.AbstractDataNode.getFields
>>>> (AbstractDataNode.java:139)
>>>> (AbstractDataNode.java:114)
>>>> (GetField.java:25)
>>>>          ... 12 more
>>>> Execution failed:
>>>> (1) for type file
>>>> Thanks!
>>>> Nika
