[Swift-devel] recent karajan changes causing trouble
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Thu Jul  5 13:55:51 CDT 2007
my workflow doesn't work with recent changes. It worked fine for 1
molecule, but fails for 244 (right after compilation step, before
submitting it to the grid). These are the errors:
2007-07-05 13:37:51,294 DEBUG VDL2ExecutionContext Missing argument
s11 for sys:element(out1, out2, out3, out4, in1, in2, in3, in4, in5,
in6, in7, in8, s1, s2, s3, s4, s5, s6, s7, s8, s9, s10, s11)
Missing argument s11 for sys:element(out1, out2, out3, out4, in1,
in2, in3, in4, in5, in6, in7, in8, s1, s2, s3, s4, s5, s6, s7, s8,
s9, s10, s11)
         CHARMM3 @ MolDyn-244.kml, line: 209
         vdl:mains @ MolDyn-244.kml, line: 583910
         at
org.globus.cog.karajan.workflow.nodes.user.UserDefinedElement.prepareIns
tanceArguments(UserDefinedElement.java:196)
         at
org.globus.cog.karajan.workflow.nodes.user.UserDefinedElement.startBody(
UserDefinedElement.java:170)
         at
org.globus.cog.karajan.workflow.nodes.user.SequentialImplicitExecutionUD
E.startBody(SequentialImplicitExecutionUDE.java:55)
         at
E.childCompleted(SequentialImplicitExecutionUDE.java:82)
         at
org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent
(Sequential.java:33)
         at org.globus.cog.karajan.workflow.nodes.FlowNode.event
(FlowNode.java:334)
         at org.globus.cog.karajan.workflow.events.EventBus.send
(EventBus.java:123)
         at org.globus.cog.karajan.workflow.events.EventBus.sendHooked
(EventBus.java:97)
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent
(FlowNode.java:172)
         at org.globus.cog.karajan.workflow.nodes.FlowNode.complete
(FlowNode.java:298)
         at org.globus.cog.karajan.workflow.nodes.FlowContainer.post
(FlowContainer.java:58)
         at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.ch
ildCompleted(AbstractSequentialWithArguments.java:192)
         at
(FlowNode.java:334)
(EventBus.java:123)
(EventBus.java:97)
         at
(FlowNode.java:172)
(FlowNode.java:298)
         at
org.globus.cog.karajan.workflow.nodes.Parallel.notificationEvent
(Parallel.java:90)
(FlowNode.java:334)
<snip>
a complete log is on terminable in ~nefedova/MolDyn-244-
zvhy3me4scm61.log
the MolDyn-244.* files are also there. Please note that this is
exactly the same file (dtm) that worked before.
Nika
On Jul 2, 2007, at 9:23 PM, Mihael Hategan wrote:
> Yup. Try now.
> On Tue, 2007-07-03 at 06:38 +0530, Ben Clifford wrote:
>> I get the below when I try to run a hello world workflow
>> (examples/tutorial/q1.swift).
>> I think Nika also saw something that looks similar, with a different
>> workflow.
>> This is with cog r1655.
>> I reverted my checkout to cog r1650 (svn merge -r1655:1650 .) and
>> hello
>> world runs ok (r1650 being before the most recent set of cog
>> commits).
>> $ swift -debug q1.swift
>> Recompilation suppressed.
>> null
>>         kernel:cache @ sys.xml, line: 3
>> Caused by: java.lang.UnsupportedOperationException
>>         at java.util.AbstractMap.put(AbstractMap.java:228)
>>         at
>> org.globus.cog.karajan.workflow.nodes.CacheNode.getTrackingArguments(
>> CacheNode.java:153)
>>         at
>> org.globus.cog.karajan.workflow.nodes.CacheNode.post
>> (CacheNode.java:77)
>>         at
>> .childCompleted(AbstractSequentialWithArguments.java:192)
>>         at
>> org.globus.cog.karajan.workflow.nodes.PartialArgumentsContainer.nonAr
>> gChildCompleted(PartialArgumentsContainer.java:90)
>>         at
>> org.globus.cog.karajan.workflow.nodes.PartialArgumentsContainer.child
>> Completed(PartialArgumentsContainer.java:85)
>>         at
>>         at
>> org.globus.cog.karajan.workflow.nodes.CacheNode.notificationEvent
>> (CacheNode.java:111)
>>         at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:
>> 334)
>>         at
>> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:
>> 123)
>>         at
>> (EventBus.java:97)
>>         at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(
>> FlowNode.java:172)
>>         at
>> (FlowNode.java:298)
>>         at
>>         at
>> org.globus.cog.karajan.workflow.nodes.Namespace.post
>> (Namespace.java:40)
>>         at
>>         at
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
