[Swift-devel] Re: [VDL2-user] GridFTP timeout exception
    Tiberiu Stef-Praun
    tiberius at ci.uchicago.edu
    Mon Feb 26 14:01:02 CST 2007
On 2/26/07, Ben Clifford <benc at hawaga.org.uk> wrote:
> On Mon, 26 Feb 2007, Tiberiu Stef-Praun wrote:
> > BTW, the NCSA problem is a non-issue, I solved it.
> how?
tiberius at tp-login2:~/scratch> cat ~/.globus/cog.properties
ip=128.135.158.222
> > The only other
> > small issue is taking full advantage of all the sites in the
> > sites.xml.
> For 0.1, each site needs to be usable as the single site to run everything
> one. It doesn't matter so much (at all) that you can't use all sites in
> the same run...
Tiberiu (Tibi) Stef-Praun, PhD
Research Staff, Computation Institute
5640 S. Ellis Ave, #405
University of Chicago
http://www-unix.mcs.anl.gov/~tiberius/
