[Swift-devel] Re: [VDL2-user] GridFTP timeout exception
    Ben Clifford
    benc at hawaga.org.uk
    Mon Feb 26 13:57:51 CST 2007
On Mon, 26 Feb 2007, Tiberiu Stef-Praun wrote:
> BTW, the NCSA problem is a non-issue, I solved it.
how?
> The only other
> small issue is taking full advantage of all the sites in the
> sites.xml.
For 0.1, each site needs to be usable as the single site to run everything
one. It doesn't matter so much (at all) that you can't use all sites in
the same run...
