[Swift-devel] Re: test v0.1rc1
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Feb 26 14:33:14 CST 2007
Wait, because I'm missing something. Wasn't the error supposed to be
"TaskHandler can only handle unsubmitted tasks"?
On Mon, 2007-02-26 at 14:26 -0600, Veronika V. Nefedova wrote:
> And now its getting interesting!
> I have now the same failure (as below) with 070219 as I had on localhost
> with v0.1rc1 *BUT* when running on TG. Failed at the same point (while
> trying to run the last app in the workflow), with the same exceptions.
> Strange that 070219 worked on localhost (and still working).
> The log is on wiggum: /sandbox/ydeng/alamines/swift-MolDyn-690y7r1skc8z0.log
> 2007-02-26 14:10:16,543 INFO  vdl:execute2 Running job chrm-rmnoet7i chrm
> with arguments [system:solv_m001, title:solv, stitle:m001,
> rtffile:parm03_gaff_all.rtf, paramfile:parm03_gaffnb_all.prm,
> gaff:m001_am1, nwater:400, ligcrd:lyz, rforce:0, iseed:3131887, rwater:15,
> nstep:100, minstep:100, skipstep:100, startstep:10000] in
> swift-MolDyn-690y7r1skc8z0/chrm-rmnoet7i on TG-NCSA
> 2007-02-26 14:11:18,586 DEBUG vdl:execute2 Application exception: Job chrm
> failed with an exit code of 174
> <snip>
> All input files are staged in...
> Nika
> At 02:17 PM 2/26/2007, Veronika  V. Nefedova wrote:
> >You can try to run my application, or look in the logs. I ran it all on
> >wiggum. The log is:
> >/sandbox/ydeng/alamines/swift-MolDyn-8q6ygr7cy15c2.log
> >the dtm file I am running is /sandbox/ydeng/alamines/swift-MolDyn.dtm
> >Nika
> >At 01:39 PM 2/26/2007, Mihael Hategan wrote:
> >>That doesn't sound good. How do I reproduce this?
> >>Mihael
> >>On Mon, 2007-02-26 at 13:21 -0600, Veronika V. Nefedova wrote:
> >> > The one Ben asked us all to test:
> >> > >http://www.ci.uchicago.edu/swift/tests/vdsk-0.1rc1.tar.gz
> >> > At 01:15 PM 2/26/2007, Mihael Hategan wrote:
> >> > >On Mon, 2007-02-26 at 13:05 -0600, Veronika V. Nefedova wrote:
> >> > > > When I tried to run my working workflow with a new version, it
> >> gave me an
> >> > > > exception:
> >> > >Which new version?
> >> > >Mihael
> >> > > > Warning: Task handler throws exception but does not set status
> >> > > > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> >> > > >          at
> >> org.globus.cog.abstraction.impl.common.task.CachingFileOperationTaskHandler.submit(CachingFileOperationTaskHandler.java:20)
> >> > > >          at
> >> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:78)
> >> > > >          at java.lang.Thread.run(Thread.java:534)
> >> > > > [349] wiggum /sandbox/ydeng/alamines > \\
> >> > > > I do not have this happening with 070219 built.
> >> > > > Nika
> >> > > > At 06:12 AM 2/26/2007, Ben Clifford wrote:
> >> > > > >On Mon, 26 Feb 2007, Ben Clifford wrote:
> >> > > > > > v0.1rc1 was built at the end of last week. please spend some time
> >> > > testing
> >> > > > >here's the URL for download:
> >> > > > _______________________________________________
> >> > > > Swift-devel mailing list
> >> > > > Swift-devel at ci.uchicago.edu
> >> > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
