[Swift-devel] Re: test v0.1rc1
    Veronika  V. Nefedova
    nefedova at mcs.anl.gov
    Mon Feb 26 14:26:40 CST 2007
And now its getting interesting!
I have now the same failure (as below) with 070219 as I had on localhost
with v0.1rc1 *BUT* when running on TG. Failed at the same point (while
trying to run the last app in the workflow), with the same exceptions.
Strange that 070219 worked on localhost (and still working).
The log is on wiggum: /sandbox/ydeng/alamines/swift-MolDyn-690y7r1skc8z0.log
2007-02-26 14:10:16,543 INFO  vdl:execute2 Running job chrm-rmnoet7i chrm
with arguments [system:solv_m001, title:solv, stitle:m001,
rtffile:parm03_gaff_all.rtf, paramfile:parm03_gaffnb_all.prm,
gaff:m001_am1, nwater:400, ligcrd:lyz, rforce:0, iseed:3131887, rwater:15,
nstep:100, minstep:100, skipstep:100, startstep:10000] in
swift-MolDyn-690y7r1skc8z0/chrm-rmnoet7i on TG-NCSA
2007-02-26 14:11:18,586 DEBUG vdl:execute2 Application exception: Job chrm
failed with an exit code of 174
<snip>
All input files are staged in...
Nika
At 02:17 PM 2/26/2007, Veronika  V. Nefedova wrote:
>You can try to run my application, or look in the logs. I ran it all on
>wiggum. The log is:
>/sandbox/ydeng/alamines/swift-MolDyn-8q6ygr7cy15c2.log
>the dtm file I am running is /sandbox/ydeng/alamines/swift-MolDyn.dtm
>Nika
>At 01:39 PM 2/26/2007, Mihael Hategan wrote:
>>That doesn't sound good. How do I reproduce this?
>>Mihael
>>On Mon, 2007-02-26 at 13:21 -0600, Veronika V. Nefedova wrote:
>> > The one Ben asked us all to test:
>> > >http://www.ci.uchicago.edu/swift/tests/vdsk-0.1rc1.tar.gz
>> > At 01:15 PM 2/26/2007, Mihael Hategan wrote:
>> > >On Mon, 2007-02-26 at 13:05 -0600, Veronika V. Nefedova wrote:
>> > > > When I tried to run my working workflow with a new version, it
>> gave me an
>> > > > exception:
>> > >Which new version?
>> > >Mihael
>> > > > Warning: Task handler throws exception but does not set status
>> > > > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
>> > > > TaskHandler can only handle unsubmitted tasks
>> > > >          at
>> org.globus.cog.abstraction.impl.common.task.CachingFileOperationTaskHandler.submit(CachingFileOperationTaskHandler.java:20)
>> > > >          at
>> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:78)
>> > > >          at java.lang.Thread.run(Thread.java:534)
>> > > > [349] wiggum /sandbox/ydeng/alamines > \\
>> > > > I do not have this happening with 070219 built.
>> > > > Nika
>> > > > At 06:12 AM 2/26/2007, Ben Clifford wrote:
>> > > > >On Mon, 26 Feb 2007, Ben Clifford wrote:
>> > > > > > v0.1rc1 was built at the end of last week. please spend some time
>> > > testing
>> > > > >here's the URL for download:
>> > > > _______________________________________________
>> > > > Swift-devel mailing list
>> > > > Swift-devel at ci.uchicago.edu
>> > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
