[Swift-devel] how to increment int?
Mike Kubal
mikekubal at yahoo.com
Tue Dec 18 08:03:30 CST 2007
Thanks Ben,
I tried both approaches, but I get the following
errors:
Could not compile SwiftScript source: line 9:11:
unexpected token: {
with the line:
iterate i {
I get a similar error
Could not compile SwiftScript source: line 12:23:
unexpected token: [
with the line
foreach job_number in [1000000:10000098]
Mike
--- Ben Clifford <benc at hawaga.org.uk> wrote:
> > In the swift code loop below I need to increment
> the
> > start_job variable by 1, however I get the error
> that
> > start_job is already assigned, how should I do it?
> > while( start_job < 10000998){
> Don't use while - it shouldn't even be in the
> language, in my opinion,
> given that I've never seen a successful use of it.
> Here are two ways of saying what I think you want:
> THere's an 'iterate' statement that will give you a
> counter for each loop.
> Section 2.6.4 in here:
http://www.ci.uchicago.edu/swift/guides/userguide.php#id2663424
> something like
> iterate i {
> int job_number = i + 10000000;
> } until(job_number >= 1000098)
> You could also express it as this, which perhaps
> better expresses the
> parallelism (though I think both the iterate use
> above and the foreach use
> below will behave about the same).
> foreach job_number in [1000000:10000098] {
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
