[Swift-devel] how to increment int?
Ben Clifford
benc at hawaga.org.uk
Tue Dec 18 06:16:27 CST 2007
> In the swift code loop below I need to increment the
> start_job variable by 1, however I get the error that
> start_job is already assigned, how should I do it?
> while( start_job < 10000998){
Don't use while - it shouldn't even be in the language, in my opinion,
given that I've never seen a successful use of it.
Here are two ways of saying what I think you want:
THere's an 'iterate' statement that will give you a counter for each loop.
Section 2.6.4 in here:
http://www.ci.uchicago.edu/swift/guides/userguide.php#id2663424
something like
iterate i {
int job_number = i + 10000000;
} until(job_number >= 1000098)
You could also express it as this, which perhaps better expresses the
parallelism (though I think both the iterate use above and the foreach use
below will behave about the same).
foreach job_number in [1000000:10000098] {
