[Swift-devel] script that returns bad parameter error
Michael Wilde
wilde at mcs.anl.gov
Thu Dec 6 12:42:04 CST 2007
MikeK, did you see this message and adjust your code accordingly?
I suspect this is the problem.
- MikeW
On 12/5/07 5:47 PM, Michael Wilde wrote:
> I need to take a close look later when I get a chance, but i'm a bit
> suspicious of the use of the file type variables receptor_file and
> ligand_file without the @ or @filename inside your app{} construct in
> run_fred().
> Will check later if thats what gives this message.
> you want to say:
> app {
> run_fred "-rec" @receptor_file "-dbase"
> @ligand_file "-prefix" ligand_prefix;> }
> See the users guide at
> http://www.ci.uchicago.edu/swift/guides/userguide.php
> sec 2.3.1
> and the tutorial example, Mike.
> - MikeW
> On 12/5/07 2:56 PM, Mike Kubal wrote:
>> Any thoughts on what might cause?
>> type file {}
>> (file score, file docked) run_fred (string
>> ligand_prefix, file ligand_file, file receptor_file){
>> app {
>> run_fred "-rec" receptor_file "-dbase"
>> string receptor_prefix = "1beh";
>> file receptor_file
>> <single_file_mapper;file=@strcat(receptor_prefix,".oeb.gz")>;
>> file
>> fls[]<filesys_mapper;pattern="Marsha_lig_*.mol2",location=".">;
>> foreach ligand_file in fls{
>> string ligand_prefix =
>> @strcut(@ligand_file,"\.\/(.*)\.mol2");
>> string score_file_name =
>> @strcat(ligand_prefix,"_chemgauss3_scores.txt");
>> string docked_file_name =
>> @strcat(ligand_prefix,"_chemgauss3_docked.mol2");
>> file score_file
>> <single_file_mapper;file=@strcat(ligand_prefix,"_chemgauss3_scores.txt")>;
>> file docked_file
>> <single_file_mapper;file=@strcat(ligand_prefix,"_chemgauss3_docked.mol2")>;
>> (score_file,docked_file) =
>> run_fred(ligand_prefix,ligand_file,receptor_file);
>> Thanks,
>> Mike Kubal
>> ____________________________________________________________________________________
>> Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
