[Swift-devel] script that returns bad parameter error
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Dec  5 17:47:41 CST 2007
I need to take a close look later when I get a chance, but i'm a bit
suspicious of the use of the file type variables receptor_file and
ligand_file without the @ or @filename inside your app{} construct in
run_fred().
Will check later if thats what gives this message.
you want to say:
         app {
              run_fred "-rec" @receptor_file "-dbase"
  @ligand_file "-prefix" ligand_prefix;>         }
See the users guide at http://www.ci.uchicago.edu/swift/guides/userguide.php
sec 2.3.1
and the tutorial example, Mike.
- MikeW
On 12/5/07 2:56 PM, Mike Kubal wrote:
> Any thoughts on what might cause?
> type file {}
> (file score, file docked) run_fred (string
> ligand_prefix, file ligand_file, file receptor_file){
>         app {
>              run_fred "-rec" receptor_file "-dbase"
> string receptor_prefix = "1beh";
> file receptor_file
> <single_file_mapper;file=@strcat(receptor_prefix,".oeb.gz")>;
> file
> fls[]<filesys_mapper;pattern="Marsha_lig_*.mol2",location=".">;
> foreach ligand_file in fls{
>         string ligand_prefix =
> @strcut(@ligand_file,"\.\/(.*)\.mol2");
>         string score_file_name =
> @strcat(ligand_prefix,"_chemgauss3_scores.txt");
>         string docked_file_name =
> @strcat(ligand_prefix,"_chemgauss3_docked.mol2");
>         file score_file
> <single_file_mapper;file=@strcat(ligand_prefix,"_chemgauss3_scores.txt")>;
>         file docked_file
> <single_file_mapper;file=@strcat(ligand_prefix,"_chemgauss3_docked.mol2")>;
>         (score_file,docked_file) =
> run_fred(ligand_prefix,ligand_file,receptor_file);
> Thanks,
> Mike Kubal
>       ____________________________________________________________________________________
> Never miss a thing.  Make Yahoo your home page.
> http://www.yahoo.com/r/hs
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
