[Swift-devel] (no subject)
Ian Foster
foster at mcs.anl.gov
Wed Dec 5 12:03:17 CST 2007
should/could we generate warnings for such things?
> Also, you have a bug in your SwiftScript program:
>> (file ofile)hostname() {
>> app { hostname; }
> You need to specify that the output from hostname goes into ofile. For
> example, say:
> app { hostname stdout=@filename(ofile); }
>> at
>> org.globus.cog.abstraction.impl.execution.gt2.CallbackHandlerManager.decreas
>> eUsageCount(CallbackHandlerManager.java:33)
>> at
>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.clean
>> up(JobSubmissionTaskHandler.java:482)
>> at
>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statu
>> sChanged(JobSubmissionTaskHandler.java:475)
>> at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>> at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>> at java.lang.Thread.run(Thread.java:619)
>> Failed to clean up job
>> java.lang.IllegalStateException: No registered callback handler for
>> org.globus.gsi.gssapi.GlobusGSSCredentialImpl at 11b92ef
>> at
>> at
>> at
>> at
>> at
>> at
>> hostname failed
>> Execution failed:
>> Exception in hostname:
>> Arguments: []
>> Host: data
>> Directory: hostname-20071204-2116-xvhkcj88/hostname-vg2dq1li
>> stderr.txt:
>> stdout.txt: data.uniparthenope.it
>> Caused by:
>> The following output files were not created by the application:
>> hostname.txt
>> What do you think about it?
>> Do you have some suggestions?
>> I attached to this mail both files on floater-245 and data.
>> Thank you in advance.
>> Raffaele
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20071205/1d86b94f/attachment.html>
