[Swift-devel] (no subject)
Ben Clifford benc at hawaga.org.uk
Wed Dec 5 11:57:49 CST 2007
Two problems - the IllegalStateException exception you see is something
that I've seen one other person get but have been unable to recreate
myself. I think Mihael probably also hasn't been able to recreate it.
What machine is floater-245? Is it your own personal machine?
> Failed to clean up job
> java.lang.IllegalStateException: No registered callback handler for
> org.globus.gsi.gssapi.GlobusGSSCredentialImpl at 11b92ef
Also, you have a bug in your SwiftScript program:
> (file ofile)hostname() {
>   app { hostname; }
You need to specify that the output from hostname goes into ofile. For
example, say:
    app { hostname stdout=@filename(ofile); }
>         at
> org.globus.cog.abstraction.impl.execution.gt2.CallbackHandlerManager.decreas
> eUsageCount(CallbackHandlerManager.java:33)
>         at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.clean
> up(JobSubmissionTaskHandler.java:482)
>         at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statu
> sChanged(JobSubmissionTaskHandler.java:475)
>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>         at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>         at java.lang.Thread.run(Thread.java:619)
>         at
>         at
>         at
>         at
>         at
>         at
> hostname failed
> Execution failed:
>         Exception in hostname:
> Arguments: []
> Host: data
> Directory: hostname-20071204-2116-xvhkcj88/hostname-vg2dq1li
> stderr.txt:
> stdout.txt: data.uniparthenope.it
> Caused by:
>         The following output files were not created by the application:
> hostname.txt
> What do you think about it?
> Do you have some suggestions?
> I attached to this mail both files on floater-245 and data.
> Thank you in advance.
>   Raffaele
