[Swift-devel] Cant get Falkon provider connected to Swift
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Thu Aug 30 20:09:44 CDT 2007
I was commenting on these errors:
WARN   - Failed to configure log file name
DEBUG  - Booting Falkon
If you have this, it means your logging is completely screwed up (no
log file). It could be fixed in log4j.properties.
On Aug 30, 2007, at 8:02 PM, Mihael Hategan wrote:
> On Thu, 2007-08-30 at 19:44 -0500, Veronika Nefedova wrote:
>> You need to fix log4j.properties, I had the same problem some time
>> ago. SVN update somehow messes it up.
> Irrespective of how logging is set up. When I run, seemingly the same
> thing as Mike, it works and it finds the deef provider.
> So the problem of finding deef is probably not in the build, but in
> something else, unless this is nondeterministic. But from what I
> understand, Mike repeatedly got this. Or no?
> Mihael
>> Nika
>> On Aug 30, 2007, at 7:35 PM, Mihael Hategan wrote:
>>> Hmm. Strange:
>>> hategan at tg-viz-login1:~> swift -d -sites.file ./sites.xml
>>> -tc.file ./tc.data test.swift
>>> hategan at tg-viz-login1:~> which swift
>>> /home/wilde/swift1139f/vdsk-0.2-dev/bin/swift
>>> Mihael
>>> On Thu, 2007-08-30 at 18:47 -0500, Michael Wilde wrote:
>>>> I'm using trunk (release 1139) and getting the following error
>>>> when I
>>>> run swift:
>>>> Execution failed:
>>>>          No security context can be found or created for service
>>>> (provider deef): No 'deef' provider or alias found. Available
>>>> providers: [gt2ft, gsiftp, condor, pbs, ssh, gt4ft, cobalt, local,
>>>> dcache, gt4, gsiftp-old, http, gt2, ftp, webdav]. Aliases:
>>>> local <-> file; pbs <-> pbslocal; gsiftp-old <-> gridftp-old;
>>>> gsiftp <->
>>>> gridftp; cobalt <-> cobaltlocal; gt4 <-> gt3.9.5, gt4
>>>> .0.2, gt4.0.1, gt4.0.0;
>>>> I did what I think was a clean Swift build (ant dist after clean
>>>> and
>>>> distclean); then from the modules/provider-deef dir did a ant
>>>> distclean
>>>> and ant dist pointing to my swift vdsk dir that was built in the
>>>> prior
>>>> step).
>>>> I have a cog-provider-deef-1.0.jar file in the lib dir of my dist,
>>>> and
>>>> my libexec/vds-sc.k file has:
>>>>                          element(execution, [provider, url]
>>>>                                  service(type="execution",
>>>> provider=provider, url=url)
>>>> which should match the pool entry in my sites.xml:
>>>> <pool handle="UC" sysinfo="INTEL32::LINUX">
>>>>      <gridftp url="gsiftp://tg-gridftp.uc.teragrid.org"
>>>> storage="/home/wilde/swift/tmp/UC" major="2" minor="2" />
>>>>      <jobmanager universe="vanilla"
>>>> url="tg-grid.uc.teragrid.org/jobmanager-pbs" major="2" minor="2"/>
>>>>      <workdirectory>/home/wilde/swift/tmp/UC</workdirectory>
>>>> </pool>
>>>> Does anyone know what I missed to messed up here in wiring things
>>>> together?
>>>> Ive asked Ioan, but he's stumped because this is on the swift
>>>> provider
>>>> side of things.
>>>> Thanks,
>>>> Mike
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
