[Swift-devel] latest Falkon code is in SVN!
Ioan Raicu
iraicu at cs.uchicago.edu
Thu Aug 30 00:22:24 CDT 2007
Thats fine... the current build scripts are more than enough for me at
the moment. If this changes in the future, I am sure I or someone else
will adapt them accordingly.
Ioan
Mihael Hategan wrote:
> On Wed, 2007-08-29 at 10:01 -0500, Ioan Raicu wrote:
>> Right, it should have warned the user that the build failed. I don't
>> know how to use the ant build language, and I don't have time right now
>> to learn it. If anyone wants to take a stab at reworking my compile
>> scripts into ant build scripts, I think that would be great!
> Great, but unlikely. I doubt that any of us have appreciably more time
> than you do. It is probably a bit unwise to count on the adoption of
> Falkon if you rely on people understanding its internal details, and
> doing many little things here and there. The little things tend to add
> up to a lot. In our case the choice would boil down to the amount of
> time we spend on Swift vs. the amount of time we spend on non-Swift.
> Should Swift be perfect, the choice would be easy. But it, too, needs
> many little things done here and there. And while there is undeniable
> value in what Falkon does, it is not a blank check.
> Mihael
>> BTW, about the particular error you saw, the C Executor is a new
>> experimental implementation that could replace the Java based worker
>> code and WS-based communication protocol. If you simply remove the
>> -static option, it will likely compile; the static option is generally
>> helpful when you want to compile on one machine and take the binary
>> elsewhere. By default, the Java executor code base is used, so even if
>> the C Executor didn't compile, Falkon could still work from the Java
>> code base.
>> Ioan
>> Ben Clifford wrote:
>>> During ./make-falkon.sh I noticed this:
>>> Compiling GramClient
>>> Compiling C Executor
>>> /usr/bin/ld: can't locate file for: -lcrt0.o
>>> collect2: ld returned 1 exit status
>>> It didn't halt the build. It probably should. Probably better to use make
>>> and/or ant as build language.
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dsl.cs.uchicago.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070830/ecd0b494/attachment.html>
