[Swift-devel] Re: 244 MolDyn run was successful!
    Ben Clifford
    benc at hawaga.org.uk
    Mon Aug 27 04:41:21 CDT 2007
On Thu, 16 Aug 2007, Ioan Raicu wrote:
> (if the consensus is that you want the latest changes in SVN, then
> perhaps I can do this on a weekly basis)
One model for what you should put in the trunk of the SVN is code that you
think works well enough for a user to be making regular use of for their
work (eg Nika). approximately equivalently, you shouldn't be pointing
users to anything other than the SVN trunk (or some snapshot of trunk)) to
obtain code.
