[Swift-devel] Q about MolDyn
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Aug  6 12:19:58 CDT 2007
On Mon, 2007-08-06 at 11:51 -0500, Ioan Raicu wrote:
> If there are no leftover directories, it could mean one of two things:
> 1) the job submission failed and the job never made it out to a remote
> resource to create directories and execute
> 2) the job went through to the remote resource, created directories,
> executed, finished with an exit code of 0, cleaned up directories, ...
> In both instances, there are no directories at the end.  What we are
> missing is the logs to determine which of the two cases from above
> happened.
There would be the wrapper log.
>   Note that there were absolutely no Exceptions thrown in the
> Falkon logs, so I would be cautious to rule out (2) from above.
> Just for a sanity check, can you run those two molecules manually, just
> to double check that they work!  Could we do a 2 molecule run through
> Swift with just the two suspect molecules to see if those 2 molecules
> complete OK?  Then, let's try another run with 244 molecules soon, as
> most of ANL/UC is free!
> Ioan
> Veronika Nefedova wrote:
> > m050 worked just fine last time we ran 244 molecules. And it doesn't
> > look like an application failure but rather a job submission failure
> > (no leftover directories).
> > m179 failed the last time we ran it but I thought it was fixed? Yuqing
> > - could you please verify that I am using the right antechamber code
> > on tg-uc.
> > Nika
> > On Aug 6, 2007, at 11:34 AM, Ben Clifford wrote:
> >> have you tried running those molecules individually?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
