[Swift-devel] swift in SVN is broken
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Apr 27 13:25:11 CDT 2007
Note: that constructor has only been added in java 1.5. It's not
available in 1.4.
On Fri, 2007-04-27 at 13:23 -0500, Veronika V. Nefedova wrote:
> Hi,
> I tried to use swift from svn trunk and the build has failed with these
> errors. Please fix! Its a blocker for me...
> Thanks!
> Nika
> compile:
>       [echo] [vdsk]: COMPILE
>      [mkdir] Created dir: /sandbox/nefedova/SWIFT/cog/modules/vdsk/build
>      [javac] Compiling 165 source files to
>      [javac]
> /sandbox/nefedova/SWIFT/cog/modules/vdsk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java:35:
> cannot resolve symbol
>      [javac] symbol  : constructor IllegalArgumentException
> (java.lang.String,org.griphyn.vdl.mapping.InvalidMapperException)
>      [javac] location: class java.lang.IllegalArgumentException
>      [javac]                     throw new
> IllegalArgumentException(e.getMessage(), e);
>      [javac]                               ^
>      [javac]
> /sandbox/nefedova/SWIFT/cog/modules/vdsk/src/org/griphyn/vdl/mapping/RootDataNode.java:38:
>      [javac]                     throw new
> IllegalArgumentException(e.getMessage(),e);
>      [javac]                               ^
>      [javac] 2 errors
> BUILD FAILED
> /sandbox/nefedova/SWIFT/cog/modules/vdsk/build.xml:69: The following error
> occurred while executing this line:
> /sandbox/nefedova/SWIFT/cog/mbuild.xml:463: The following error occurred
> /sandbox/nefedova/SWIFT/cog/mbuild.xml:227: Compile failed; see the
> compiler error output for details.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
