[Swift-devel] swift in SVN is broken
    Veronika  V. Nefedova
    nefedova at mcs.anl.gov
    Fri Apr 27 13:23:25 CDT 2007
I tried to use swift from svn trunk and the build has failed with these
errors. Please fix! Its a blocker for me...
Thanks!
Nika
compile:
      [echo] [vdsk]: COMPILE
     [mkdir] Created dir: /sandbox/nefedova/SWIFT/cog/modules/vdsk/build
     [javac] Compiling 165 source files to
     [javac]
/sandbox/nefedova/SWIFT/cog/modules/vdsk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java:35:
cannot resolve symbol
     [javac] symbol  : constructor IllegalArgumentException
(java.lang.String,org.griphyn.vdl.mapping.InvalidMapperException)
     [javac] location: class java.lang.IllegalArgumentException
     [javac]                     throw new
IllegalArgumentException(e.getMessage(), e);
     [javac]                               ^
     [javac]
/sandbox/nefedova/SWIFT/cog/modules/vdsk/src/org/griphyn/vdl/mapping/RootDataNode.java:38:
     [javac]                     throw new
IllegalArgumentException(e.getMessage(),e);
     [javac]                               ^
     [javac] 2 errors
BUILD FAILED
/sandbox/nefedova/SWIFT/cog/modules/vdsk/build.xml:69: The following error
occurred while executing this line:
/sandbox/nefedova/SWIFT/cog/mbuild.xml:463: The following error occurred
/sandbox/nefedova/SWIFT/cog/mbuild.xml:227: Compile failed; see the
compiler error output for details.
