[Swift-devel] file declaration inside foreach
    Veronika  V. Nefedova
    nefedova at mcs.anl.gov
    Tue Apr 24 16:53:57 CDT 2007
Well, I also need to run one small program inside that loop that doesn't
have that data dependency. Basically what that program does is modifies the
input file for the main application at every loop step:
original=modify(original,i);
I am sure this one wouldn't work (; and I'd have to create an array of
input files (one for each i) ?
Nika
At 04:45 PM 4/24/2007, Yong Zhao wrote:
>Right, if there is data dependency, then it is not necessary.
>Yong.
>On Tue, 24 Apr 2007, Mihael Hategan wrote:
> > Why if we can actually express the problem?
> > On Tue, 2007-04-24 at 16:30 -0500, Yong Zhao wrote:
> > > There was a sequential option for 'foreach', and maybe we can translate
> > > that into a sequential for in karajan.
> > > Yong.
> > > On Tue, 24 Apr 2007, Ben Clifford wrote:
> > > > On Tue, 24 Apr 2007, Veronika  V. Nefedova wrote:
> > > > > The main problem: it submitted 2 jobs at once (foreach loop is
> for i=1,2). And
> > > > > since the jobs were supposed to run one after another - they all
> failed
> > > > > (application failure)
> > > > ok. That's expected, or at least, I expect it.
> > > > foreach is a parallel map-like operation for running some action on
> each
> > > > element in an array independent of the other elements.
> > > > I think you probably can't express that kind of iteration in
> SwiftScript
> > > > at the moment (unless 'while' happens to work for you) though I'm
> poking
> > > > round with ways to express that. (in functional programming terms,
> you're
> > > > trying to do a fold rather than a map, I think).
> > > > _______________________________________________
> > > > Swift-devel mailing list
> > > > Swift-devel at ci.uchicago.edu
> > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
