[Swift-devel] file declaration inside foreach
Yong Zhao yongzh at cs.uchicago.edu
Tue Apr 24 16:45:00 CDT 2007
Right, if there is data dependency, then it is not necessary.
Yong.
On Tue, 24 Apr 2007, Mihael Hategan wrote:
> Why if we can actually express the problem?
> On Tue, 2007-04-24 at 16:30 -0500, Yong Zhao wrote:
> > There was a sequential option for 'foreach', and maybe we can translate
> > that into a sequential for in karajan.
> > Yong.
> > On Tue, 24 Apr 2007, Ben Clifford wrote:
> > > On Tue, 24 Apr 2007, Veronika  V. Nefedova wrote:
> > > > The main problem: it submitted 2 jobs at once (foreach loop is for i=1,2). And
> > > > since the jobs were supposed to run one after another - they all failed
> > > > (application failure)
> > > ok. That's expected, or at least, I expect it.
> > > foreach is a parallel map-like operation for running some action on each
> > > element in an array independent of the other elements.
> > > I think you probably can't express that kind of iteration in SwiftScript
> > > at the moment (unless 'while' happens to work for you) though I'm poking
> > > round with ways to express that. (in functional programming terms, you're
> > > trying to do a fold rather than a map, I think).
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
