[Swift-commit] r8367 - SwiftApps/ematter/galaxy
ketan at ci.uchicago.edu
Tue Jan 20 13:41:32 CST 2015
Author: ketan
Date: 2015-01-20 13:41:32 -0600 (Tue, 20 Jan 2015)
New Revision: 8367
Added:
SwiftApps/ematter/galaxy/genfdf.swift
SwiftApps/ematter/galaxy/pasta.swift
SwiftApps/ematter/galaxy/swiftgenfdf.py
SwiftApps/ematter/galaxy/swiftpasta.py
Modified:
SwiftApps/ematter/galaxy/genfdf.xml
SwiftApps/ematter/galaxy/pasta.xml
Log:
adding galaxy components for ematter
Added: SwiftApps/ematter/galaxy/genfdf.swift
--- SwiftApps/ematter/galaxy/genfdf.swift (rev 0)
+++ SwiftApps/ematter/galaxy/genfdf.swift 2015-01-20 19:41:32 UTC (rev 8367)
@@ -0,0 +1,19 @@
+type file;
+/* == App function definitions == */
+/* == Lammps app definition == */
+app (file _outfdf) genfdf_app (file _src, float _v, file _infdf)
+ bash @_src _v @_infdf stdout=@_outfdf;
+file src <single_file_mapper; file=arg("src")>;
+float v = toFloat(arg("v"));
+file infdf <single_file_mapper; file=arg("infdf")>;
+file outfdf <single_file_mapper; file=arg("outfdf")>;
+(outfdf) = genfdf_app (src, v, infdf);
Modified: SwiftApps/ematter/galaxy/genfdf.xml
--- SwiftApps/ematter/galaxy/genfdf.xml 2015-01-20 16:34:53 UTC (rev 8366)
+++ SwiftApps/ematter/galaxy/genfdf.xml 2015-01-20 19:41:32 UTC (rev 8367)
@@ -1,59 +1,35 @@
-<tool id="swiftjumpdsp" name="dsp swift">
+<tool id="swiftgenfdf" name="genfdf swift">
ToDo:
- 1. Option if the counter should be an argument, first one or last one.
- 2. Option to add files (in Galaxy dataset format) as arguments. These files then be added to Swift app as arguments.
- 3. Allow the tool to select another tool and run it.
- 4. Allow user to add more than one resource to run a job for load balancing.
- 5. Add ability to run Swift/T.
- 6. Let the localhost option be selected by default
+ 1.
+ 2.
+ 3.
- <description>A Galaxy tool to run Dsp parameter sweeps via Swift foreach parallel construct</description>
+ <description>A Galaxy tool to run genfdf via Swift</description>
<command interpreter="python">
- swiftjumpdsp.py
- "${inlocation}"
- "${a}"
- "${n}"
- "${p}"
- "${I}"
+ swiftgenfdf.py
+ "${_src}"
+ "${_r}"
+ "${_infdf}"
"${local_or_compute}"
- "${resloc}"
- "${outlist}"
- "${outlogfile}"
+ "${outfdf}"
</command>
<inputs>
- <param name="inlocation" size="60" type="text" label="inlocation" value="/home/ketan/SwiftApps/dsp-swift/dcap" help="Enter the path of the directory containing input data, eg. /home/ketan/farmer" />
- <param name="a" size="30" type="text" label="aval" value="1" help="Enter the value of a" />
- <param name="n" size="30" type="text" label="nval" value="1" help="Enter the value of n" />
- <param name="p" size="30" type="text" label="pval" value="1" help="Enter the value of p" />
- <param name="I" size="30" type="text" label="Ival" value="10" help="Enter the value of I" />
+ <param name="_src" size="30" type="data" label="genfdf source" help="Select data for genfdf source" />
+ <param name="_r" size="10" type="text" label="Value of voltage" help="Add value for voltage" />
+ <param name="_infdf" size="30" type="data" label="input fdf" help="Select data for input fdf" />
<param name="local_or_compute" type="select" display="radio" label="choose target execution location">
<option value="local" selected="true">local</option>
<option value="compute">compute</option>
</param>
- <param name="resloc" size="60" type="text" label="Location for results" value="/tmp/outdir" help="Enter the path to a directory to put results in, eg. /tmp/outdir"/>
</inputs>
<outputs>
- <data format="txt" name="outlist" type="data" label="Output List" />
- <data format="txt" name="outlogfile" type="data" label="Swift Progress" />
+ <data format="txt" name="outfdf" type="data" label="Output fdf" />
</outputs>
<help>
-**What is this?**
-A tool to run dsp in parallel parameter sweeps.
-**What it does?**
-Runs dsp in parallel over a user provided input dataset and parameters.
-**How does it do?**
-The user provides input to the tool which is then delivered to the
-underlying Swift script. The script is then invoked on local/login or
-compute nodes as selected by the user. Once the tool has run, the output is
-produced in the directory location provided by the user.
More description to come.
</help>
</tool>
Added: SwiftApps/ematter/galaxy/pasta.swift
--- SwiftApps/ematter/galaxy/pasta.swift (rev 0)
+++ SwiftApps/ematter/galaxy/pasta.swift 2015-01-20 19:41:32 UTC (rev 8367)
@@ -0,0 +1,16 @@
+type file;
+app (file _outfdf) pasta_app (file _src, file _xyz, file _infdf)
+ bash @_src @_xyz @_infdf @_outfdf;
+file xyz <single_file_mapper; file=arg("xyz")>;
+(outfdf) = pasta_app (src, xyz, infdf);
Modified: SwiftApps/ematter/galaxy/pasta.xml
--- SwiftApps/ematter/galaxy/pasta.xml 2015-01-20 16:34:53 UTC (rev 8366)
+++ SwiftApps/ematter/galaxy/pasta.xml 2015-01-20 19:41:32 UTC (rev 8367)
@@ -1,68 +1,36 @@
+<tool id="swiftpasta" name="pasta swift">
ToDo:
+ 1.
+ <description>A Galaxy tool to run the pasta tool via Swift</description>
- swiftjumpdsp.py
- "${inlocation}"
- "${a}"
- "${n}"
- "${p}"
- "${I}"
+ swiftpasta.py
+ "${_src}"
+ "${_xyz}"
+ "${_infdf}"
+ "${_outfdf}"
- "${resloc}"
- "${outlist}"
- "${outlogfile}"
</command>
<inputs>
+ <param name="_src" size="30" type="data" label="in.lammps" help="Select source for pasta" />
+ <param name="_xyz" size="30" type="data" label="geo" help="Select data for xyz" />
+ <param name="_infdf" size="30" type="data" label="eam" help="Select data for input fdf" />
</param>
</inputs>
<outputs>
+ <data format="txt" name="_outfdf" type="data" label="pasta output" />
</outputs>
-<help>
-**What is this?**
+ <help>
-**What it does?**
</help>
</tool>
-type file;
-/* == Pasta app definition == */
-app (file _fdf) pasta_app (file _pasta_src, file _xyz, file _fdf_tmp)
- bash @_pasta_src @_xyz @_fdf_tmp @_fdf;
Added: SwiftApps/ematter/galaxy/swiftgenfdf.py
--- SwiftApps/ematter/galaxy/swiftgenfdf.py (rev 0)
+++ SwiftApps/ematter/galaxy/swiftgenfdf.py 2015-01-20 19:41:32 UTC (rev 8367)
@@ -0,0 +1,63 @@
+#!/usr/bin/env python
+This is the Swift driver for Galaxy. It receives inputs from the Swift
+Galaxy tool and depending on the options specified, builds a
+canonical Swift/K or Swift/T script and runs over specified computational
+environment.
+ swiftgenfdf.py
+ "${_src}"
+ "${_r}"
+ "${_infdf}"
+ "${local_or_compute}"
+ "${outfdf}"
+import subprocess
+import sys
+import os
+import distutils.spawn
+import traceback
+import fnmatch
+import re
+from os.path import expanduser
+def setwdir():
+ return subprocess.check_output(["mktemp", "-d", "/tmp/swift-gal.XXXX"])
+def genargs(args):
+ for a in args:
+ yield a
+def main():
+ myargs = genargs(sys.argv)
+ try:
+ this=next(myargs)
+ src = next(myargs)
+ v = next(myargs)
+ infdf = next(myargs)
+ local_or_compute = next(myargs)
+ outfdf = next(myargs)
+ except:
+ traceback.print_exc()
+ sys.exit(1)
+ homedir = expanduser("~")
+ baseloc = homedir+"/SwiftApps/ematter/galaxy"
+ #which swift
+ swift = homedir+"/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift"
+ swiftargs="-src="+src+" -v="+v+" -infdf="+infdf+" -outfdf="+outfdf
+ siteval=baseloc+"/sites.local.xml"
+ if local_or_compute == "compute":
+ siteval=baseloc+"/sites.blues.xml"
+ #Invocation
+ exitcode=subprocess.check_call([swift, "-sites.file", siteval, "-tc.file", baseloc+"/apps", "-config", baseloc+"/cf", baseloc+"/genfdf.swift", swiftargs])
+ #print exitcode
+if __name__=='__main__':
+ main()
Property changes on: SwiftApps/ematter/galaxy/swiftgenfdf.py
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/ematter/galaxy/swiftpasta.py
--- SwiftApps/ematter/galaxy/swiftpasta.py (rev 0)
+++ SwiftApps/ematter/galaxy/swiftpasta.py 2015-01-20 19:41:32 UTC (rev 8367)
@@ -0,0 +1,61 @@
+environment.
+swiftpasta.py
+ "${_src}"
+ "${_xyz}"
+ "${_infdf}"
+ "${_outfdf}"
+import subprocess
+import sys
+import os
+import traceback
+import fnmatch
+import re
+def genargs(args):
+ for a in args:
+ yield a
+def main():
+ try:
+ this=next(myargs)
+ xyz = next(myargs)
+ except:
+ sys.exit(1)
+ #which swift
+ swiftargs="-src="+src+" -xyz="+xyz+" -infdf="+infdf+" -outfdf="+outfdf
+ #Invocation
+ exitcode=subprocess.check_call([swift, "-sites.file", siteval, "-tc.file", baseloc+"/apps", "-config", baseloc+"/cf", baseloc+"/pasta.swift", swiftargs])
+ #print exitcode
+ main()
Property changes on: SwiftApps/ematter/galaxy/swiftpasta.py
More information about the Swift-commit
