[Swift-commit] r8271 - SwiftApps/subjobs/dock
    ketan at ci.uchicago.edu
    Fri Oct 10 13:41:32 CDT 2014
Author: ketan
Date: 2014-10-10 13:41:31 -0500 (Fri, 10 Oct 2014)
New Revision: 8271
Added:
   SwiftApps/subjobs/dock/1VRT.rec.bmp
   SwiftApps/subjobs/dock/1VRT.rec.nrg
   SwiftApps/subjobs/dock/dock_infiles/
   SwiftApps/subjobs/dock/rec.10A.sph
   SwiftApps/subjobs/dock/runswift.sh
Modified:
   SwiftApps/subjobs/dock/dock.swift
Log:
add dock input files and swift wrapper
Added: SwiftApps/subjobs/dock/1VRT.rec.bmp
(Binary files differ)
Property changes on: SwiftApps/subjobs/dock/1VRT.rec.bmp
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: SwiftApps/subjobs/dock/1VRT.rec.nrg
Property changes on: SwiftApps/subjobs/dock/1VRT.rec.nrg
Modified: SwiftApps/subjobs/dock/dock.swift
--- SwiftApps/subjobs/dock/dock.swift	2014-10-09 22:30:29 UTC (rev 8270)
+++ SwiftApps/subjobs/dock/dock.swift	2014-10-10 18:41:31 UTC (rev 8271)
@@ -1,21 +1,30 @@
 type file;
 // Dock
-app (file _dockoutfile, file out, file err) dock (file _dockinfile)
+app (file _dockoutfile, file out, file err) dock (file _dockinfile, file _mol2, file _defn, file _flexdefn, file _tbl, file _nrg, file _sph, file _bmp)
-   bgsh "/home/ketan/dock6/bin/dock" "-i" @_dockinfile "-o" @_dockoutfile stdout=@out stderr=@err;
+   bgsh "/home/ketan/dock6/bin/dock6" "-i" @_dockinfile "-o" @_dockoutfile stdout=@out stderr=@err;
 // Files
-file infiles[] <filesys_mapper; location="dock_infiles", suffix=".in">;
+file infiles[] <filesys_mapper; location=".", suffix=".in">;
 file logs[];
+file mol2<"zinc_nci_0010.mol2">;
+file defn<"vdw_AMBER_parm99.defn">;
+file flexdefn<"flex.defn">;
+file tbl<"flex_drive.tbl">;
+file nrg<"1VRT.rec.nrg">;
+file sph<"rec.10A.sph">;
+file bmp<"1VRT.rec.bmp">;
 // Run scaling tests
 foreach infile,i in infiles {
-   file dock_output <single_file_mapper; file=strcat("logs/dock.", i, ".out")>;
-   file dock_error <single_file_mapper; file=strcat("logs/dock.", i, ".err")>;
-   file dockoutfile <single_file_mapper; file=strcat("dock.",i, ".sc")>;
-   (dockoutfile, dock_output, dock_error) = dock(pdb, 2);
+   file dock_output <single_file_mapper; file=strcat("logs/dock.", i, ".stdout")>;
+   file dock_error <single_file_mapper; file=strcat("logs/dock.", i, ".stderr")>;
+   file dockoutfile <single_file_mapper; file=strcat("dock.",i, ".out")>;
+   (dockoutfile, dock_output, dock_error) = dock(infile, mol2, defn, flexdefn, tbl, nrg, sph, bmp);
    logs[i] = dock_output;
Added: SwiftApps/subjobs/dock/rec.10A.sph
--- SwiftApps/subjobs/dock/rec.10A.sph	                        (rev 0)
+++ SwiftApps/subjobs/dock/rec.10A.sph	2014-10-10 18:41:31 UTC (rev 8271)
@@ -0,0 +1,59 @@
+cluster     1   number of spheres in cluster    58
+    1   4.22300 -36.12100  22.78400   0.700    1
+    2   3.08000 -36.36800  23.25800   0.700    2
+    3   2.22500 -37.57000  21.98500   0.700    3
+    4   2.40900 -38.19300  21.32800   0.700    4
+    5   5.22700 -35.11900  22.89100   0.700    5
+    6   2.19200 -38.17200  21.36700   0.700    6
+    7   5.07700 -34.91600  23.36200   0.700    7
+    8   1.98300 -38.04700  21.26800   0.700    8
+    9   1.35800 -37.37500  21.82100   0.700    9
+   10   2.78200 -35.19800  24.29500   0.700   10
+   11   6.35400 -38.13000  20.72000   0.700   11
+   12   1.86600 -38.00700  20.16300   0.700   12
+   13   3.42600 -34.64500  24.63100   0.700   13
+   14   1.95000 -39.52600  21.59300   0.700   14
+   15   2.24600 -37.94100  19.45100   0.700   15
+   16   1.73100 -35.33700  24.31200   0.700   16
+   17   2.86700 -40.23100  21.97100   0.700   17
+   18   0.76400 -35.97900  23.31800   0.700   18
+   19   0.90200 -35.60200  23.80600   0.700   19
+   20   6.67000 -38.95100  20.26800   0.700   20
+   21   2.71900 -38.09700  18.79000   0.700   21
+   22   2.77600 -34.90300  25.34000   0.700   22
+   23   3.54100 -34.82100  25.54000   0.700   23
+   24   2.07600 -40.53100  21.19600   0.700   24
+   25   3.29000 -34.92600  25.88900   0.700   25
+   26   2.61200 -34.80200  25.84200   0.700   26
+   27  -0.33700 -35.77200  22.99600   0.700   27
+   28   2.15600 -34.72000  25.79800   0.700   28
+   29   5.21400 -38.26700  17.85800   0.700   29
+   30   3.76100 -38.12300  17.60800   0.700   30
+   31   1.88200 -34.66000  25.89800   0.700   31
+   32   1.75500 -40.73000  20.10000   0.700   32
+   33  -0.32700 -36.31700  19.25200   0.700   33
+   34  -0.74300 -35.61200  24.16600   0.700   34
+   35  -0.59300 -36.21100  19.44600   0.700   35
+   36   7.89500 -40.62500  20.65000   0.700   36
+   37   0.04700 -35.30400  18.57400   0.700   37
+   38  -1.43700 -35.50300  21.59600   0.700   38
+   39  -1.29300 -36.83600  17.99600   0.700   39
+   40  -2.83600 -35.85400  22.90100   0.700   40
+   41   9.75400 -41.11000  23.90500   0.700   41
+   42  -3.20500 -36.15900  22.46900   0.700   42
+   43  11.75500 -35.01400  25.70900   0.700   43
+   44  11.58600 -34.63300  26.00300   0.700   44
+   45  10.98100 -40.05000  25.25600   0.700   45
+   46  11.72000 -38.85500  25.12300   0.700   46
+   47   0.48800 -33.58900  32.74200   0.700   47
+   48   8.59900 -43.82600  18.54100   0.700   48
+   49  -7.47000 -40.16500  22.80500   0.700   49
+   50  -1.56100 -33.95700  31.03400   0.700   50
+   51   8.10800 -44.69700  18.46400   0.700   51
+   52   1.82200 -33.81100  33.32600   0.700   52
+   53   4.28700 -40.85600  13.64200   0.700   53
+   54   9.92000 -41.90200  24.30400   0.700   54
+   55   7.56400 -44.63900  19.68900   0.700   55
+   56  10.72800 -41.39300  24.94700   0.700   56
+   57   7.05300 -27.88000  24.84000   0.700   57
+   58  10.01800 -41.78300  24.42400   0.700   58
Added: SwiftApps/subjobs/dock/runswift.sh
--- SwiftApps/subjobs/dock/runswift.sh	                        (rev 0)
+++ SwiftApps/subjobs/dock/runswift.sh	2014-10-10 18:41:31 UTC (rev 8271)
@@ -0,0 +1,10 @@
+#! /bin/sh
+#Old method
+#qsub -A ATPESC2014 -n 512 -t 15 --mode script runswift_script.sh -config cf -tc.file apps -sites.file localcoast.xml "$@"
+export COBALT_PROJ=ExM
+#New method
+/home/ketan/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift -sites.file cobalt.xml -config cf -tc.file apps dock.swift
+#A testblock run
+#qsub -A ATPESC2013 -n 32 -t 5 -q low --mode c16 --mode script testblock.sh # --disable_preboot
Property changes on: SwiftApps/subjobs/dock/runswift.sh
Added: svn:executable
More information about the Swift-commit
