[Swift-commit] r8270 - in SwiftApps/subjobs: . dock rosetta
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Oct 9 17:30:29 CDT 2014
Author: ketan
Date: 2014-10-09 17:30:29 -0500 (Thu, 09 Oct 2014)
New Revision: 8270
Added:
   SwiftApps/subjobs/dock/
   SwiftApps/subjobs/dock/apps
   SwiftApps/subjobs/dock/cf
   SwiftApps/subjobs/dock/cobalt.xml
   SwiftApps/subjobs/dock/dock.swift
   SwiftApps/subjobs/dock/dock_mpi.in
   SwiftApps/subjobs/dock/flex.defn
   SwiftApps/subjobs/dock/flex_drive.tbl
   SwiftApps/subjobs/dock/vdw_AMBER_parm99.defn
   SwiftApps/subjobs/dock/zinc_nci_0010.mol2
Modified:
   SwiftApps/subjobs/rosetta/rosetta.swift
Log:
add dock and a small change to rosetta
Added: SwiftApps/subjobs/dock/apps
--- SwiftApps/subjobs/dock/apps	                        (rev 0)
+++ SwiftApps/subjobs/dock/apps	2014-10-09 22:30:29 UTC (rev 8270)
@@ -0,0 +1,3 @@
+localhost cat /bin/cat null null null
+cluster bgsh /home/ketan/SwiftApps/subjobs/bg.sh null null null
Added: SwiftApps/subjobs/dock/cf
--- SwiftApps/subjobs/dock/cf	                        (rev 0)
+++ SwiftApps/subjobs/dock/cf	2014-10-09 22:30:29 UTC (rev 8270)
@@ -0,0 +1,6 @@
+use.provider.staging=false
+wrapperlog.always.transfer=false
+execution.retries=0
+provider.staging.pin.swiftfiles=false
+sitedir.keep=false
+use.wrapper.staging=false
Added: SwiftApps/subjobs/dock/cobalt.xml
--- SwiftApps/subjobs/dock/cobalt.xml	                        (rev 0)
+++ SwiftApps/subjobs/dock/cobalt.xml	2014-10-09 22:30:29 UTC (rev 8270)
@@ -0,0 +1,30 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+<pool handle="cluster">
+<execution provider="coaster" jobmanager="local:cobalt" />
+<profile namespace="globus" key="slots">2</profile>
+<profile namespace="globus" key="mode">script</profile>
+<profile namespace="karajan" key="jobThrottle">2.99</profile>
+<profile namespace="karajan" key="initialScore">10000</profile>
+<profile namespace="globus" key="maxwalltime">00:40:00</profile>
+<profile namespace="globus" key="walltime">2050</profile>
+<profile namespace="globus" key="maxnodes">256</profile>
+<profile namespace="globus" key="nodegranularity">256</profile>
+<profile key="SUBBLOCK_SIZE" namespace="env">16</profile>
+<profile key="WORKER_LOGGING_LEVEL" namespace="env">DEBUG</profile>
+<profile key="ENABLE_WORKER_LOGGING" namespace="env">TRUE</profile>
+<profile key="ENABLE_WORKER_LOGGING" namespace="env">ON</profile>
+<profile key="WORKER_LOG_DIR" namespace="env">/home/ketan/workerlogs</profile>
+<profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
+<profile namespace="globus" key="workerLoggingDirectory">/home/ketan/workerlogs</profile>
+<profile namespace="globus" key="jobsPerNode">16</profile>
+<workdirectory>/home/ketan/swiftwork</workdirectory>
+<filesystem provider="local"/>
+</pool>
+</config>
Added: SwiftApps/subjobs/dock/dock.swift
--- SwiftApps/subjobs/dock/dock.swift	                        (rev 0)
+++ SwiftApps/subjobs/dock/dock.swift	2014-10-09 22:30:29 UTC (rev 8270)
@@ -0,0 +1,21 @@
+type file;
+// Dock
+app (file _dockoutfile, file out, file err) dock (file _dockinfile)
+   bgsh "/home/ketan/dock6/bin/dock" "-i" @_dockinfile "-o" @_dockoutfile stdout=@out stderr=@err;
+// Files
+file infiles[] <filesys_mapper; location="dock_infiles", suffix=".in">;
+file logs[];
+// Run scaling tests
+foreach infile,i in infiles {
+   file dock_output <single_file_mapper; file=strcat("logs/dock.", i, ".out")>;
+   file dock_error <single_file_mapper; file=strcat("logs/dock.", i, ".err")>;
+   file dockoutfile <single_file_mapper; file=strcat("dock.",i, ".sc")>;
+   (dockoutfile, dock_output, dock_error) = dock(pdb, 2);
+   logs[i] = dock_output;
Added: SwiftApps/subjobs/dock/dock_mpi.in
--- SwiftApps/subjobs/dock/dock_mpi.in	                        (rev 0)
+++ SwiftApps/subjobs/dock/dock_mpi.in	2014-10-09 22:30:29 UTC (rev 8270)
@@ -0,0 +1,66 @@
+ligand_atom_file                                             zinc_nci_0010.mol2
+limit_max_ligands                                            no
+skip_molecule                                                no
+read_mol_solvation                                           no
+calculate_rmsd                                               no
+use_database_filter                                          no
+orient_ligand                                                yes
+automated_matching                                           yes
+receptor_site_file                                           rec.10A.sph
+max_orientations                                             500
+critical_points                                              no
+chemical_matching                                            no
+use_ligand_spheres                                           no
+use_internal_energy                                          yes
+internal_energy_rep_exp                                      12
+flexible_ligand                                              yes
+user_specified_anchor                                        no
+limit_max_anchors                                            no
+min_anchor_size                                              40
+pruning_use_clustering                                       yes
+pruning_max_orients                                          100
+pruning_clustering_cutoff                                    100
+pruning_conformer_score_cutoff                               25.0
+use_clash_overlap                                            no
+write_growth_tree                                            no
+bump_filter                                                  no
+score_molecules                                              yes
+contact_score_primary                                        no
+contact_score_secondary                                      no
+grid_score_primary                                           yes
+grid_score_secondary                                         no
+grid_score_rep_rad_scale                                     1
+grid_score_vdw_scale                                         1
+grid_score_es_scale                                          1
+grid_score_grid_prefix                                       1VRT.rec
+multigrid_score_secondary                                    no
+dock3.5_score_secondary                                      no
+continuous_score_secondary                                   no
+descriptor_score_secondary                                   no
+gbsa_zou_score_secondary                                     no
+gbsa_hawkins_score_secondary                                 no
+SASA_descriptor_score_secondary                              no
+amber_score_secondary                                        no
+minimize_ligand                                              yes
+minimize_anchor                                              yes
+minimize_flexible_growth                                     yes
+use_advanced_simplex_parameters                              no
+simplex_max_cycles                                           1
+simplex_score_converge                                       0.1
+simplex_cycle_converge                                       1.0
+simplex_trans_step                                           1.0
+simplex_rot_step                                             0.1
+simplex_tors_step                                            10.0
+simplex_anchor_max_iterations                                500
+simplex_grow_max_iterations                                  500
+simplex_grow_tors_premin_iterations                          0
+simplex_random_seed                                          0
+simplex_restraint_min                                        no
+atom_model                                                   all
+vdw_defn_file                                                vdw_AMBER_parm99.defn
+flex_defn_file                                               flex.defn
+flex_drive_file                                              flex_drive.tbl
+ligand_outfile_prefix                                        1VRT
+write_orientations                                           no
+num_scored_conformers                                        1
+rank_ligands                                                 no
Added: SwiftApps/subjobs/dock/flex.defn
--- SwiftApps/subjobs/dock/flex.defn	                        (rev 0)
+++ SwiftApps/subjobs/dock/flex.defn	2014-10-09 22:30:29 UTC (rev 8270)
@@ -0,0 +1,288 @@
+5/98 te
+11/98 kb, ags, mll
+3/0 kb
+______________________________________________________________________
+name		sp3-sp3
+drive_id	3
+minimize	1
+definition	.3 [ 3 H ]
+name		sp3-sp2
+drive_id	6
+minimize	1
+definition	.2 [ 2 H ]
+name		sp3-aromatic
+drive_id	6
+minimize	1
+definition	.ar
+name		sp3-n4
+drive_id	3
+minimize	1
+definition	N.4 [ 3 H ]
+name		sp3-npl
+drive_id	6
+minimize	1
+definition	N.pl3
+name		sp3-n_amide
+drive_id	6
+minimize	1
+definition	N.am
+name		sp3-sp1
+drive_id	3
+minimize	1
+definition	.1 ( . )
+name		sp2-sp2
+drive_id	2
+minimize	0
+name		sp2-aromatic
+drive_id	2
+minimize	0
+definition	.ar
+name		sp2-n4
+drive_id	6
+minimize	1
+name		sp2-npl
+drive_id	2
+minimize	0
+definition	N.pl3
+name		sp2-n_amide
+drive_id	2
+minimize	0
+definition	N.am
+SPECIAL CASES COME LAST TO SUPERCEDE GENERAL DEFINITIONS
+name		npl3-aromatic
+drive_id	2
+minimize	0
+definition	N.pl3 [ 2 H ] [ 2 O ]
+definition	.ar
+name		n_amide-n_amide
+drive_id	2
+minimize	0
+definition	N.am
+definition	N.am
+name		n_amide-aromatic
+drive_id	2
+minimize	0
+definition	N.am
+definition	.ar
+name		acetyl-sp2
+drive_id	2
+minimize	1
+definition	C.2 ( O.2 ) ( C.3 )
+name		ccat-n
+drive_id	2
+minimize	0
+definition	C.cat
+definition	N [ 2 H ]
+name		carboxyl-sp3
+drive_id	62
+minimize	1
+definition	C.2 ( 2 O.co2 )
+name		arom-oxygen
+drive_id	2
+minimize	1
+definition	O.3 [ H ]
+definition	C.ar
+name		conj-oxygen
+drive_id	2
+minimize	0
+name		arom-sulfur
+drive_id	2
+minimize	1
+definition	S.3 [ H ]
+definition	C.ar
+name		conj-sulfur
+drive_id	2
+minimize	0
+name		ester
+drive_id	2
+minimize	0
+definition	O.3 ( . )
+name		sulfyl-ester
+drive_id	2
+minimize	0
+definition	C.2 ( S.2 )
+definition	S.3 ( . )
+name		arom-hydroxyl
+drive_id	2
+minimize	1
+definition	O.3 ( H )
+definition	C.ar
+name		conj-hydroxyl
+drive_id	2
+minimize	1
+definition	.2
+name		arom-hydrosulfyl
+drive_id	2
+minimize	1
+definition	S.3 ( H )
+definition	C.ar
+name		conj-hydrosulfyl
+drive_id	2
+minimize	1
+name		phosph-ester
+drive_id	62
+minimize	1
+definition	P.3 ( 2 O.co2 )
+definition	O.3
+name		sulfate-ester
+drive_id	62
+minimize	1
+definition	S ( 4 O )
+definition	O.3
+name		sulfonate-arom
+drive_id	63
+minimize	1
+definition	S ( 3 O [ * ] )
+definition	C.ar
+name		sulfonate-sp2
+drive_id	63
+minimize	0
+name		sulfonamide
+drive_id	3
+minimize	1
+definition	S ( 2 O [ * ] )
+definition	N
+name		aromatic_sulfonamide
+drive_id	32
+minimize	1
+definition	S ( 2 O [ * ] ) ( C.ar )
+name		sulfone-sp3
+drive_id	3
+minimize	1
+name		sulfone-sp2
+drive_id	6
+minimize	1
+name		sulfone-aromatic
+drive_id	122
+minimize	1
+definition	C.ar [ 2 H ]
+name		silicon-sp3
+drive_id	6
+minimize	1
+definition	Si [ 3 H ]
+name		silicon-oxygen
+drive_id	3
+minimize	1
+definition	O.3
+name            amide
+drive_id        1
+minimize        0
+definition      N.am ( H )
Added: SwiftApps/subjobs/dock/flex_drive.tbl
--- SwiftApps/subjobs/dock/flex_drive.tbl	                        (rev 0)
+++ SwiftApps/subjobs/dock/flex_drive.tbl	2014-10-09 22:30:29 UTC (rev 8270)
@@ -0,0 +1,41 @@
+drive_id	1
+positions	1
+torsions	180
+drive_id	2
+positions	2
+torsions	0 180
+drive_id	3
+positions	3
+torsions	-60 60 180
+drive_id	32
+positions	2
+torsions	-60 60
+drive_id	4
+positions	4
+torsions	-90 0 90 180
+drive_id	6
+positions	6
+torsions	-150 -90 -30 30 90 150
+drive_id	62
+positions	3
+torsions	-90 -30 30
+drive_id	63
+positions	2
+torsions	-30 30
+drive_id	8
+positions	8
+torsions	-135 -90 -45 0 45 90 135 180
+drive_id	122
+positions	6
+torsions	-120 -90 -60 60 90 120
Added: SwiftApps/subjobs/dock/vdw_AMBER_parm99.defn
--- SwiftApps/subjobs/dock/vdw_AMBER_parm99.defn	                        (rev 0)
+++ SwiftApps/subjobs/dock/vdw_AMBER_parm99.defn	2014-10-09 22:30:29 UTC (rev 8270)
@@ -0,0 +1,472 @@
+___________________________________________________________________________
+ AMBER99-based Lennard-Jones parameters for van der Waals
+ energy potential.
+ The radius corresponds to half the equilibrium distance
+ (in Angstroms) between atoms.
+ The well depth corresponds to the energy (in kcal/mol)
+ at the equilibrium distance.
+ Lennard-Jones parameters are derived as follows:
+ sqrt(A) = sqrt [e * b/(a-b) * (2r)^a]
+ sqrt(B) = sqrt [e * a/(a-b) * (2r)^b]
+ where:
+        r = radius
+        e = well depth
+        a = repulsive exponent
+        b = attractive exponent
+ P. Therese Downing (07/02)
+ Robert Rizzo (06/05)  added radii for GB calculations
+ P. Therese Lang (07/06):  added full list of Aqvist ions
+			   (J. Phys. Chem. v94 p8021).
+name            Carbon
+atom_model      either
+radius          1.908
+well_depth      0.086
+heavy_flag      1
+valence         4
+gbradii		1.70
+gbscale		0.72
+definition      C
+name            Carbon_All_sp3
+atom_model      all
+radius          1.908
+well_depth      0.1094
+heavy_flag      1
+valence         4
+gbradii		1.70
+gbscale		0.72
+definition      C.3
+name            Hydrogen
+atom_model      either
+radius          0.600
+well_depth      0.0157
+heavy_flag      0
+valence         1
+gbradii		1.30
+gbscale		0.85
+definition      H
+name            Hydrogen_hydroxyl
+atom_model      either
+radius          0.1
+well_depth      0.001
+heavy_flag      0
+valence         1
+gbradii		0.80
+gbscale		0.85
+definition      H ( O )
+name		Hydrogen_thiol
+atom_model	all
+radius		0.600
+well_depth	0.0157
+heavy_flag	0
+valence		1
+gbradii		0.80
+gbscale		0.85
+definition	H ( S )
+name            Hydrogen_Aliphatic
+atom_model      all
+radius          1.487
+well_depth      0.0157
+heavy_flag      0
+valence         1
+gbradii		1.30
+gbscale		0.85
+definition      H ( C.3 )
+name            Hydrogen_Semipolar
+atom_model      all
+radius          1.387
+well_depth      0.0157
+heavy_flag      0
+valence         1
+gbradii		1.30
+gbscale		0.85
+definition      H ( C.3 ( O ) )
+definition      H ( C.3 ( N ) )
+definition      H ( C.3 ( S ) )
+definition      H ( C.3 ( F ) )
+definition      H ( C.3 ( Cl ) )
+definition      H ( C.3 ( Br ) )
+name            Hydrogen_2_Semipolar
+atom_model      all
+radius          1.287
+well_depth      0.0157
+heavy_flag      0
+valence         1
+gbradii		1.30
+gbscale		0.85
+definition      H ( C.3 ( 2 O) )
+definition      H ( C.3 ( 2 N) )
+definition      H ( C.3 ( 2 S) )
+definition      H ( C.3 ( N ) ( O ) )
+definition      H ( C.3 ( S ) ( O ) )
+definition      H ( C.3 ( S ) ( N ) )
+definition      H ( C.3 ( 2 F ) )
+definition      H ( C.3 ( 2 Cl ) )
+definition      H ( C.3 ( 2 Br ) )
+name            Hydrogen_1-3_Charged
+atom_model      all
+radius          1.100
+well_depth      0.0157
+heavy_flag      0
+valence         1
+gbradii		1.30
+gbscale		0.85
+definition      H ( C.3 ( N.4 ) )
+name            Hydrogen_sp2
+atom_model      all
+radius          1.459
+well_depth      0.0150
+heavy_flag      0
+valence         1
+gbradii		1.30
+gbscale		0.85
+definition      H ( C.ar )
+definition      H ( C.2 )
+name            Hydrogen_Ar_Sp
+atom_model      all
+radius          1.409
+well_depth      0.0150
+heavy_flag      0
+valence         1
+gbradii		1.30
+gbscale		0.85
+definition      H ( C.ar ( O ) )
+definition      H ( C.ar ( N ) )
+definition      H ( C.2 ( O ) )
+definition      H ( C.2 ( N ) )
+name            Hydrogen_Ar_2_Sp
+atom_model      all
+radius          1.359
+well_depth      0.0150
+heavy_flag      0
+valence         1
+gbradii		1.30
+gbscale		0.85
+definition      H ( C.ar ( 2 O ) )
+definition      H ( C.ar ( 2 N ) )
+definition      H ( C.ar ( N ) ( O ) )
+definition      H ( C.2 ( 2 O ) )
+definition      H ( C.2 ( 2 N ) )
+definition      H ( C.2 ( N ) ( O ) )
+name		Hydrogen_alkyne
+atom_model	all
+radius		1.459
+well_depth	0.015
+heavy_flag	0
+valence		1
+gbradii		1.30
+gbscale		0.85
+definition	H ( C.1 )
+name            Nitrogen
+atom_model      either
+radius          1.824
+well_depth      0.170
+heavy_flag      1
+valence         4
+gbradii		1.55
+gbscale		0.79
+definition      N
+name            Oxygen
+atom_model      either
+radius          1.6612
+well_depth      0.210
+heavy_flag      1
+valence         2
+gbradii		1.50
+gbscale		0.85
+definition      O
+name            Oxygen_ether
+atom_model      either
+radius          1.6837
+well_depth      0.170
+heavy_flag      1
+valence         2
+gbradii		1.50
+gbscale		0.85
+definition      O.3
+name            Oxygen_alcohol
+atom_model      either
+radius          1.721
+well_depth      0.2104
+heavy_flag      1
+valence         2
+gbradii		1.50
+gbscale		0.85
+name		Oxygen_TIP3_water
+atom_model	all
+radius		1.7683
+well_depth	0.1520
+heavy_flag	1
+valence		2
+gbradii		1.50
+gbscale		0.85
+definition	O.3 ( 2 H )
+name            Sulfur
+atom_model      either
+radius          2.000
+well_depth      0.250
+heavy_flag      1
+valence         6
+gbradii		1.80
+gbscale		0.96
+definition      S
+name            Phosphorus
+atom_model      either
+radius          2.100
+well_depth      0.200
+heavy_flag      1
+valence         5
+gbradii		1.85
+gbscale		0.86
+definition      P
+name            Fluorine
+atom_model      either
+radius          1.750
+well_depth      0.061
+heavy_flag      1
+valence         1
+gbradii		1.50
+gbscale		0.88
+definition      F
+name            Chlorine
+atom_model      either
+radius          1.948
+well_depth      0.265
+heavy_flag      1
+valence         1
+gbradii		1.70
+gbscale		0.80
+definition      Cl
+name            Bromine
+atom_model      either
+radius          2.220
+well_depth      0.320
+heavy_flag      1
+valence         4
+gbradii		1.85
+gbscale		0.80
+definition      Br
+name            Silicon
+atom_model      either
+radius          2.220
+well_depth      0.320
+heavy_flag      1
+valence         4
+gbradii		2.10
+gbscale		0.80
+definition      Si
+name            Iodine
+atom_model      either
+radius          2.350
+well_depth      0.400
+heavy_flag      1
+valence         1
+gbradii		1.98
+gbscale		0.80
+definition      I
+name            Potassium+
+atom_model      either
+radius          2.658
+well_depth      0.000328
+heavy_flag      1
+valence         0
+gbradii		2.75
+gbscale		0.80
+definition      K
+name            Sodium+
+atom_model      either
+radius          1.868
+well_depth      0.00277
+heavy_flag      1
+valence         1
+gbradii		2.27
+gbscale		0.80
+definition      Na
+name            Mg++
+atom_model      either
+radius          0.787
+well_depth      0.875
+heavy_flag      1
+valence         6
+gbradii		1.73
+gbscale		0.80
+definition      Mg
+name            Li+
+atom_model      either
+radius          1.137
+well_depth      0.0183
+heavy_flag      1
+valence         0
+gbradii		1.82
+gbscale		0.80
+definition      Li
+name		Rubidium
+atom_model	all
+radius		2.956
+well_depth	0.00017
+heavy_flag	1
+valence		1
+gbradii		0.000
+gbscale		0.000
+definition 	Rb
+name		Cesium
+atom_model	all
+radius		3.395
+well_depth	0.0000806
+heavy_flag	1
+valence		1
+gbradii		0.000
+gbscale		0.000
+definition	Cs
+name		Calcium2+
+atom_model	all
+radius		1.326
+well_depth	0.4497
+heavy_flag	1
+valence		10
+gbradii		1.70
+gbscale		0.72
+definition	Ca
+name		Zinc
+atom_model	all
+radius		1.10
+well_depth	0.0125
+heavy_flag	1
+valence		8
+gbradii		1.39
+gbscale		0.80
+definition 	Zn
+name 		Iron
+atom_model	all
+radius 		1.2
+well_depth	0.05
+heavy_flag	1
+valence		8
+gbradii		1.50
+gbscale		0.80
+definition      Fe
+name 		Strontium++
+atom_model	all
+radius 		1.742
+well_depth	0.118
+heavy_flag	1
+valence		8
+gbradii		0.00
+gbscale		0.00
+definition      Sr
+name 		Barium++
+atom_model	all
+radius 		2.124
+well_depth	0.047
+heavy_flag	1
+valence		8
+gbradii		0.00
+gbscale		0.00
+definition      Ba
+name            Vanadium
+atom_model      either
+radius          2.100
+well_depth      0.320
+heavy_flag      1
+valence         6
+gbradii		1.50
+gbscale		0.80
+definition      V
+name            Dummy
+atom_model      either
+radius          0.000
+well_depth      0.000
+heavy_flag      0
+valence         10
+gbradii		0.000
+gbscale		0.000
+definition      Du
Added: SwiftApps/subjobs/dock/zinc_nci_0010.mol2
--- SwiftApps/subjobs/dock/zinc_nci_0010.mol2	                        (rev 0)
+++ SwiftApps/subjobs/dock/zinc_nci_0010.mol2	2014-10-09 22:30:29 UTC (rev 8270)
@@ -0,0 +1,542 @@
+@<TRIPOS>MOLECULE
+ZINC00000710
+23 25 1 0 0
+SMALL
+USER_CHARGES
+@<TRIPOS>ATOM
+      1 C1          3.6040   -7.7640    1.0160 C.ar    1     ****   -0.0750
+      2 C2          2.5980   -6.9700    1.5670 C.ar    1     ****   -0.1480
+      3 C3          2.1600   -5.8360    0.8840 C.ar    1     ****    0.1420
+      4 C4          2.7110   -5.5140   -0.3680 C.ar    1     ****   -0.2000
+      5 C5          3.7130   -6.3090   -0.9250 C.ar    1     ****   -0.0370
+      6 C6          4.1590   -7.4300   -0.2220 C.ar    1     ****   -0.0200
+      7 CL1         5.3970   -8.4210   -0.8950 Cl      1     ****   -0.0790
+      8 C7          2.1640   -4.3570   -1.1170 C.2     1     ****    0.6730
+      9 O1          2.4380   -4.1620   -2.2920 O.2     1     ****   -0.5400
+     10 N1          1.3230   -3.6270   -0.3480 N.am    1     ****   -0.2540
+     11 C8          1.1900   -3.7320    1.0710 C.3     1     ****    0.2280
+     12 O2          1.1510   -5.1030    1.4700 O.3     1     ****   -0.3320
+     13 C9         -0.1290   -3.0540    1.3390 C.3     1     ****   -0.1130
+     14 C10        -0.0990   -1.9710    0.2770 C.3     1     ****    0.1020
+     15 O3          0.6070   -2.5290   -0.8500 O.3     1     ****   -0.2360
+     16 H1          3.9460   -8.6420    1.5590 H       1     ****    0.1550
+     17 H2          2.1650   -7.2360    2.5270 H       1     ****    0.1600
+     18 H3          4.1380   -6.0670   -1.8960 H       1     ****    0.1740
+     19 H4          1.9990   -3.2160    1.6140 H       1     ****    0.0970
+     20 H5         -0.9620   -3.7440    1.1580 H       1     ****    0.0880
+     21 H6         -0.2310   -2.6680    2.3560 H       1     ****    0.0770
+     22 H7         -1.1020   -1.6680   -0.0340 H       1     ****    0.0670
+     23 H8          0.4530   -1.0880    0.6170 H       1     ****    0.0700
+@<TRIPOS>BOND
+     1  2 1 ar
+     2  3 2 ar
+     3  4 3 ar
+     4  5 4 ar
+     5  6 1 ar
+     6  6 5 ar
+     7  7 6 1
+     8  8 4 1
+     9  9 8 2
+    10 10 8 1
+    11 11 10 1
+    12 12 3 1
+    13 12 11 1
+    14 13 11 1
+    15 14 13 1
+    16 15 10 1
+    17 15 14 1
+    18 16 1 1
+    19 17 2 1
+    20 18 5 1
+    21 19 11 1
+    22 20 13 1
+    23 21 13 1
+    24 22 14 1
+    25 23 14 1
+@<TRIPOS>SUBSTRUCTURE
+1     ****    1
+@<TRIPOS>MOLECULE
+ZINC00000896
+14 15 1 0 0
+SMALL
+USER_CHARGES
+@<TRIPOS>ATOM
+      1 C1          4.6780    3.1510    2.9860 C.2     1     ****    0.3820
+      2 C2          4.4150    2.7990    4.3160 C.2     1     ****   -0.3710
+      3 C3          3.0960    2.4110    4.3300 C.2     1     ****    0.1640
+      4 N1          2.6540    2.5460    3.0490 N.pl3   1     ****    0.0030
+      5 N2          3.6020    2.9990    2.2020 N.2     1     ****   -0.5100
+      6 N3          2.3530    1.9770    5.3760 N.2     1     ****   -0.6130
+      7 C4          3.0430    1.9500    6.4790 C.2     1     ****    0.5090
+      8 N4          4.3840    2.3150    6.6090 N.am    1     ****   -0.4960
+      9 C5          5.1680    2.7650    5.5430 C.2     1     ****    0.7470
+     10 O1          6.3450    3.0910    5.6300 O.2     1     ****   -0.6130
+     11 H1          1.7300    2.3520    2.6840 H       1     ****    0.3380
+     12 H2          4.8220    2.2540    7.5220 H       1     ****    0.3400
+     13 H3          5.5980    3.5110    2.5470 H       1     ****    0.0610
+     14 H4          2.5940    1.6230    7.4300 H       1     ****    0.0580
+@<TRIPOS>BOND
+     1  2 1 1
+     2  3 2 ar
+     3  4 3 1
+     4  5 1 2
+     5  5 4 1
+     6  6 3 1
+     7  7 6 2
+     8  8 7 1
+     9  9 2 1
+    10  9 8 1
+    11 10 9 2
+    12 11 4 1
+    13 12 8 1
+    14 13 1 1
+    15 14 7 1
+1     ****    1
+@<TRIPOS>MOLECULE
+ZINC00001052
+15 16 1 0 0
+SMALL
+USER_CHARGES
+@<TRIPOS>ATOM
+      1 C1         -1.3080   11.4590    8.4860 C.ar    1     ****   -0.1310
+      2 C2         -0.7330   10.7580    7.4510 C.ar    1     ****    0.0220
+      3 C3          0.6090   10.4520    7.4070 C.ar    1     ****    0.0410
+      4 C4          1.4680   10.8370    8.4130 C.ar    1     ****   -0.0630
+      5 C5          0.9220   11.5540    9.4880 C.ar    1     ****   -0.0370
+      6 C6         -0.4590   11.8640    9.5250 C.ar    1     ****    0.0500
+      7 CL1        -1.1710   12.7460   10.8320 Cl      1     ****   -0.0550
+      8 BR1         2.1150   12.0800   10.8730 Br      1     ****   -0.0460
+      9 O1          0.9540    9.7410    6.2680 O.3     1     ****   -0.2850
+     10 C7         -0.2750    9.6230    5.5970 C.2     1     ****    0.8200
+     11 O2         -0.3990    9.0470    4.5240 O.2     1     ****   -0.5620
+     12 N1         -1.2880   10.2370    6.3140 N.am    1     ****   -0.4680
+     13 H1         -2.2620   10.2910    6.0470 H       1     ****    0.3690
+     14 H2         -2.3690   11.6850    8.4920 H       1     ****    0.1660
+     15 H3          2.5220   10.5880    8.3640 H       1     ****    0.1780
+@<TRIPOS>BOND
+     1  2 1 ar
+     2  3 2 ar
+     3  4 3 ar
+     4  5 4 ar
+     5  6 1 ar
+     6  6 5 ar
+     7  7 6 1
+     8  8 5 1
+     9  9 3 1
+    10 10 9 1
+    11 11 10 2
+    12 12 2 1
+    13 12 10 1
+    14 13 12 1
+    15 14 1 1
+    16 15 4 1
+1     ****    1
+@<TRIPOS>MOLECULE
+ZINC00001098
+17 18 1 0 0
+SMALL
+USER_CHARGES
+@<TRIPOS>ATOM
+      1 C1          4.1940   -9.7900   -0.3090 C.ar    1     ****   -0.1630
+      2 C2          2.9600  -10.1280   -0.8700 C.ar    1     ****   -0.0690
+      3 C3          2.0120   -9.1380   -1.1240 C.ar    1     ****   -0.1500
+      4 C4          2.3100   -7.8120   -0.8140 C.ar    1     ****    0.1520
+      5 C5          3.5340   -7.4680   -0.2560 C.ar    1     ****   -0.2140
+      6 C6          4.4850   -8.4590    0.0000 C.ar    1     ****   -0.0370
+      7 C7          3.8060   -6.0590    0.0550 C.2     1     ****    0.7320
+      8 O1          4.8710   -5.7080    0.5480 O.2     1     ****   -0.5880
+      9 N1          2.7780   -5.1860   -0.2490 N.am    1     ****   -0.5980
+     10 C8          1.5480   -5.5030   -0.8050 C.2     1     ****    0.8330
+     11 O2          0.6880   -4.6580   -1.0440 O.2     1     ****   -0.5760
+     12 O3          1.3230   -6.8540   -1.0890 O.3     1     ****   -0.3040
+     13 H1          2.9400   -4.2060   -0.0430 H       1     ****    0.3590
+     14 H2          4.9300  -10.5650   -0.1120 H       1     ****    0.1480
+     15 H3          2.7390  -11.1650   -1.1080 H       1     ****    0.1460
+     16 H4          1.0540   -9.4030   -1.5600 H       1     ****    0.1650
+     17 H5          5.4500   -8.2140    0.4350 H       1     ****    0.1650
+@<TRIPOS>BOND
+     1  2 1 ar
+     2  3 2 ar
+     3  4 3 ar
+     4  5 4 ar
+     5  6 1 ar
+     6  6 5 ar
+     7  7 5 1
+     8  8 7 2
+     9  9 7 1
+    10 10 9 1
+    11 11 10 2
+    12 12 4 1
+    13 12 10 1
+    14 13 9 1
+    15 14 1 1
+    16 15 2 1
+    17 16 3 1
+    18 17 6 1
+1     ****    1
+@<TRIPOS>MOLECULE
+ZINC00001139
+15 16 1 0 0
+SMALL
+USER_CHARGES
+@<TRIPOS>ATOM
+      1 C1         -0.1040   -2.6070   -2.3630 C.ar    1     ****   -0.1290
+      2 C2         -0.3610   -1.3290   -2.8700 C.ar    1     ****   -0.0850
+      3 C3          0.6550   -0.4010   -2.7910 C.ar    1     ****    0.0430
+      4 C4          1.8760   -0.7180   -2.2340 C.ar    1     ****    0.0090
+      5 C5          2.1680   -1.9620   -1.7240 C.ar    1     ****   -0.1270
+      6 C6          1.1500   -2.9160   -1.7960 C.ar    1     ****    0.0280
+      7 CL1         1.4300   -4.5010   -1.1810 Cl      1     ****   -0.0810
+      8 N1          2.6420    0.4140   -2.3130 N.am    1     ****   -0.4700
+      9 C7          1.8770    1.3980   -2.9150 C.2     1     ****    0.8190
+     10 O1          2.2340    2.5450   -3.1510 O.2     1     ****   -0.5700
+     11 O2          0.5980    0.9110   -3.2350 O.3     1     ****   -0.2880
+     12 H1          3.5950    0.5120   -1.9890 H       1     ****    0.3670
+     13 H2         -0.8860   -3.3620   -2.4110 H       1     ****    0.1570
+     14 H3         -1.3220   -1.0830   -3.3080 H       1     ****    0.1650
+     15 H4          3.1360   -2.1850   -1.2910 H       1     ****    0.1610
+@<TRIPOS>BOND
+     1  2 1 ar
+     2  3 2 ar
+     3  4 3 ar
+     4  5 4 ar
+     5  6 1 ar
+     6  6 5 ar
+     7  7 6 1
+     8  8 4 1
+     9  9 8 1
+    10 10 9 2
+    11 11 3 1
+    12 11 9 1
+    13 12 8 1
+    14 13 1 1
+    15 14 2 1
+    16 15 5 1
+1     ****    1
+@<TRIPOS>MOLECULE
+ZINC00001555
+15 16 1 0 0
+SMALL
+USER_CHARGES
+@<TRIPOS>ATOM
+      1 C1          5.4870   -9.2570   -0.6580 C.2     1     ****   -0.2790
+      2 C2          4.4380  -10.1910   -0.4020 C.2     1     ****    0.2980
+      3 N1          3.4440   -9.6860    0.3530 N.2     1     ****   -0.4850
+      4 N2          3.8800   -8.4480    0.5600 N.pl3   1     ****    0.0470
+      5 C3          5.0660   -8.1380   -0.0040 C.2     1     ****    0.0270
+      6 N3          5.3890   -6.8720    0.2780 N.pl3   1     ****   -0.6390
+      7 C4          4.3430   -6.2560    1.1040 C.3     1     ****    0.1310
+      8 C5          3.2780   -7.3630    1.3040 C.3     1     ****    0.0350
+      9 H1          6.2190   -6.3680   -0.0110 H       1     ****    0.3830
+     10 H2          6.3920   -9.4020   -1.2280 H       1     ****    0.1700
+     11 H3          4.3650  -11.2160   -0.7380 H       1     ****    0.0410
+     12 H4          4.7540   -5.9300    2.0640 H       1     ****    0.0770
+     13 H5          3.9130   -5.3870    0.5940 H       1     ****    0.0510
+     14 H6          2.3160   -7.1130    0.8520 H       1     ****    0.0700
+     15 H7          3.1720   -7.6650    2.3490 H       1     ****    0.0710
+@<TRIPOS>BOND
+     1  2 1 1
+     2  3 2 2
+     3  4 3 1
+     4  5 1 2
+     5  5 4 1
+     6  6 5 1
+     7  7 6 1
+     8  8 4 1
+     9  8 7 1
+    10  9 6 1
+    11 10 1 1
+    12 11 2 1
+    13 12 7 1
+    14 13 7 1
+    15 14 8 1
+    16 15 8 1
+1     ****    1
+@<TRIPOS>MOLECULE
+ZINC00001621
+18 18 1 0 0
+SMALL
+USER_CHARGES
+@<TRIPOS>ATOM
+      1 C1          2.5530   -8.4700   -1.2990 C.3     1     ****    0.0260
+      2 C2          2.4040   -7.0140   -1.7710 C.3     1     ****    0.0260
+      3 C3          2.1300   -6.0530   -0.6010 C.3     1     ****    0.0260
+      4 C4          3.1760   -6.1930    0.5180 C.3     1     ****    0.0260
+      5 C5          3.3260   -7.6490    0.9900 C.3     1     ****    0.0260
+      6 C6          3.6000   -8.6100   -0.1800 C.3     1     ****    0.0260
+      7 CL1         3.6150  -10.3120    0.4250 Cl      1     ****   -0.1310
+      8 CL2         4.6700   -7.7600    2.1910 Cl      1     ****   -0.1310
+      9 CL3         2.7110   -5.1480    1.9160 Cl      1     ****   -0.1310
+     10 CL4         2.1150   -4.3510   -1.2070 Cl      1     ****   -0.1310
+     11 CL5         1.0600   -6.9020   -2.9730 Cl      1     ****   -0.1310
+     12 CL6         3.0190   -9.5150   -2.6970 Cl      1     ****   -0.1310
+     13 H1          1.5840   -8.8450   -0.9460 H       1     ****    0.1050
+     14 H2          3.3140   -6.7020   -2.2990 H       1     ****    0.1050
+     15 H3          1.1280   -6.2430   -0.1950 H       1     ****    0.1050
+     16 H4          4.1460   -5.8180    0.1640 H       1     ****    0.1050
+     17 H5          2.4160   -7.9610    1.5170 H       1     ****    0.1050
+     18 H6          4.6010   -8.4200   -0.5870 H       1     ****    0.1050
+@<TRIPOS>BOND
+     1  2 1 1
+     2  3 2 1
+     3  4 3 1
+     4  5 4 1
+     5  6 1 1
+     6  6 5 1
+     7  7 6 1
+     8  8 5 1
+     9  9 4 1
+    10 10 3 1
+    11 11 2 1
+    12 12 1 1
+    13 13 1 1
+    14 14 2 1
+    15 15 3 1
+    16 16 4 1
+    17 17 5 1
+    18 18 6 1
+1     ****    1
+@<TRIPOS>MOLECULE
+ZINC00001738
+36 40 1 0 0
+SMALL
+USER_CHARGES
+@<TRIPOS>ATOM
+      1 C1          3.1890    2.7110   -8.8140 C.ar    1     ****   -0.1180
+      2 C2          2.0970    1.8720   -9.0140 C.ar    1     ****   -0.1260
+      3 C3          1.1090    1.7690   -8.0350 C.ar    1     ****   -0.1190
+      4 C4          1.1990    2.5090   -6.8450 C.ar    1     ****   -0.1040
+      5 C5          2.3030    3.3570   -6.6440 C.ar    1     ****   -0.0620
+      6 C6          3.2940    3.4470   -7.6350 C.ar    1     ****   -0.1230
+      7 C7          2.4660    4.1560   -5.3740 C.3     1     ****    0.0160
+      8 C8          1.2560    4.1640   -4.5040 C.2     1     ****   -0.0140
+      9 C9          0.9380    4.9130   -3.3860 C.2     1     ****   -0.2180
+     10 C10        -0.3470    4.5110   -2.9500 C.2     1     ****   -0.2100
+     11 C11        -0.7890    3.5240   -3.8000 C.2     1     ****   -0.0680
+     12 N1          0.1940    3.3230   -4.7360 N.pl3   1     ****   -0.0590
+     13 C12         0.1190    2.3420   -5.8090 C.3     1     ****    0.0830
+     14 C13        -1.0120    5.0810   -1.8030 C.2     1     ****    0.6180
+     15 O1         -2.1220    4.7300   -1.4270 O.2     1     ****   -0.5450
+     16 C14        -0.2390    6.1460   -1.0930 C.ar    1     ****   -0.1220
+     17 C15        -0.8160    6.7510    0.0300 C.ar    1     ****   -0.0930
+     18 C16        -0.1250    7.7490    0.7190 C.ar    1     ****   -0.1210
+     19 C17         1.1420    8.1470    0.2940 C.ar    1     ****   -0.1210
+     20 C18         1.7280    7.5510   -0.8240 C.ar    1     ****   -0.0930
+     21 C19         1.0450    6.5490   -1.5240 C.ar    1     ****   -0.1210
+     22 C20         1.7090    5.9360   -2.7160 C.2     1     ****    0.6200
+     23 O2          2.8230    6.2870   -3.0800 O.2     1     ****   -0.5540
+     24 H1          3.9600    2.7900   -9.5740 H       1     ****    0.1380
+     25 H2          2.0150    1.2950   -9.9310 H       1     ****    0.1380
+     26 H3          0.2660    1.1030   -8.2030 H       1     ****    0.1340
+     27 H4          4.1550    4.0940   -7.4880 H       1     ****    0.1410
+     28 H5          3.3080    3.7430   -4.8060 H       1     ****    0.0880
+     29 H6          2.7110    5.1910   -5.6430 H       1     ****    0.0970
+     30 H7         -1.7070    2.9510   -3.8170 H       1     ****    0.1870
+     31 H8         -0.8680    2.4560   -6.2720 H       1     ****    0.0700
+     32 H9          0.1990    1.3550   -5.3390 H       1     ****    0.0680
+     33 H10        -1.8020    6.4590    0.3820 H       1     ****    0.1590
+     34 H11        -0.5760    8.2170    1.5900 H       1     ****    0.1380
+     35 H12         1.6750    8.9240    0.8340 H       1     ****    0.1380
+     36 H13         2.7160    7.8800   -1.1340 H       1     ****    0.1580
+@<TRIPOS>BOND
+     1  2 1 ar
+     2  3 2 ar
+     3  4 3 ar
+     4  5 4 ar
+     5  6 1 ar
+     6  6 5 ar
+     7  7 5 1
+     8  8 7 1
+     9  9 8 2
+    10 10 9 ar
+    11 11 10 2
+    12 12 8 ar
+    13 12 11 1
+    14 13 4 1
+    15 13 12 1
+    16 14 10 1
+    17 15 14 2
+    18 16 14 1
+    19 17 16 ar
+    20 18 17 ar
+    21 19 18 ar
+    22 20 19 ar
+    23 21 16 ar
+    24 21 20 ar
+    25 22 9 1
+    26 22 21 1
+    27 23 22 2
+    28 24 1 1
+    29 25 2 1
+    30 26 3 1
+    31 27 6 1
+    32 28 7 1
+    33 29 7 1
+    34 30 11 1
+    35 31 13 1
+    36 32 13 1
+    37 33 17 1
+    38 34 18 1
+    39 35 19 1
+    40 36 20 1
+1     ****    1
+@<TRIPOS>MOLECULE
+ZINC00001905
+20 21 1 0 0
+SMALL
+USER_CHARGES
+@<TRIPOS>ATOM
+      1 C1          5.3580   -6.8050   -1.2660 C.3     1     ****   -0.0850
+      2 C2          4.9700   -7.5910   -0.0110 C.3     1     ****   -0.0850
+      3 C3          5.2600   -9.0860   -0.1020 C.3     1     ****   -0.1060
+      4 C4          4.2310   -9.8390   -0.8690 C.2     1     ****    0.3910
+      5 N1          3.7930  -11.0560   -0.6110 N.2     1     ****   -0.3830
+      6 N2          2.8500  -11.3370   -1.5690 N.2     1     ****   -0.0510
+      7 N3          2.7040  -10.3210   -2.4060 N.2     1     ****   -0.1980
+      8 N4          3.5710   -9.3870   -1.9800 N.pl3   1     ****   -0.0740
+      9 C5          3.6620   -8.1190   -2.6660 C.3     1     ****    0.0520
+     10 C6          5.0410   -7.4720   -2.6060 C.3     1     ****   -0.0980
+     11 H1          6.4350   -6.5960   -1.2370 H       1     ****    0.0500
+     12 H2          4.8610   -5.8280   -1.2230 H       1     ****    0.0480
+     13 H3          5.5290   -7.1700    0.8340 H       1     ****    0.0560
+     14 H4          3.9080   -7.4240    0.2140 H       1     ****    0.0530
+     15 H5          6.2510   -9.2660   -0.5320 H       1     ****    0.0720
+     16 H6          5.2820   -9.4940    0.9170 H       1     ****    0.0860
+     17 H7          3.4100   -8.3100   -3.7160 H       1     ****    0.0820
+     18 H8          2.8900   -7.4640   -2.2480 H       1     ****    0.0650
+     19 H9          5.1090   -6.7050   -3.3870 H       1     ****    0.0620
+     20 H10         5.8150   -8.2140   -2.8390 H       1     ****    0.0610
+@<TRIPOS>BOND
+     1  2 1 1
+     2  3 2 1
+     3  4 3 1
+     4  5 4 2
+     5  6 5 1
+     6  7 6 2
+     7  8 4 1
+     8  8 7 1
+     9  9 8 1
+    10 10 1 1
+    11 10 9 1
+    12 11 1 1
+    13 12 1 1
+    14 13 2 1
+    15 14 2 1
+    16 15 3 1
+    17 16 3 1
+    18 17 9 1
+    19 18 9 1
+    20 19 10 1
+    21 20 10 1
+1     ****    1
+########## Name        : 1VRT.lig
+########## Description : AM1BCC_CHARGES =  -0.0002 ORIGINAL_CHARGES =  -0.0000
+@<TRIPOS>MOLECULE
+1VRT.lig
+34    37    1     0     0
+SMALL
+USER_CHARGES
+@<TRIPOS>ATOM
+1     N1       4.0540  -36.9310   22.2210 N.ar    1  LIG  -0.6650  -0.6200
+2     C1       4.9660  -36.2380   22.9390 C.ar    1  LIG   0.3947   0.1600
+3     H1       6.0082  -36.2811   22.6707 H       1  LIG   0.0281   0.1500
+4     C2       4.6240  -35.4500   24.0360 C.ar    1  LIG  -0.2334  -0.1500
+5     H2       5.3884  -34.9151   24.5740 H       1  LIG   0.1480   0.1500
+6     C3       3.3050  -35.3690   24.4150 C.ar    1  LIG  -0.0698  -0.1435
+7     C4       2.3460  -36.0770   23.6860 C.ar    1  LIG  -0.0398   0.1170
+8     N2       0.9890  -36.0280   24.1030 N.am    1  LIG  -0.4596  -0.5470
+9     H3       0.7643  -35.9928   25.0860 H       1  LIG   0.3311   0.3700
+10    C5      -0.1450  -36.0180   23.4080 C.2     1  LIG   0.7361   0.5438
+11    C6      -0.1190  -36.0770   21.8860 C.ar    1  LIG  -0.2550   0.0862
+12    C7      -1.1230  -35.3990   21.1890 C.ar    1  LIG  -0.0321  -0.1500
+13    H4      -1.7552  -34.6955   21.7041 H       1  LIG   0.1623   0.1500
+14    C8      -1.2960  -35.6300   19.8690 C.ar    1  LIG  -0.2723  -0.1500
+15    H5      -2.0662  -35.1073   19.3273 H       1  LIG   0.1522   0.1500
+16    C9      -0.4670  -36.5450   19.2400 C.ar    1  LIG   0.4373   0.1600
+17    H6      -0.5947  -36.7554   18.1915 H       1  LIG   0.0280   0.1500
+18    N3       0.5220  -37.2120   19.8740 N.ar    1  LIG  -0.6893  -0.6200
+19    C10      0.7040  -36.9790   21.1800 C.ar    1  LIG   0.6480   0.4100
+20    N4       1.7670  -37.6730   21.8260 N.pl3   1  LIG  -0.6924  -0.3690
+21    C11      2.7540  -36.8570   22.5840 C.ar    1  LIG   0.5805   0.4100
+22    C12      2.9040  -34.5090   25.6010 C.3     1  LIG  -0.0620   0.1435
+23    H7       2.2235  -33.7630   25.2820 H       1  LIG   0.0570   0.0000
+24    H8       2.4436  -35.1154   26.3371 H       1  LIG   0.0495   0.0000
+25    H9       3.7654  -34.0491   26.0108 H       1  LIG   0.0519   0.0000
+26    O1      -1.2400  -35.9060   23.9770 O.2     1  LIG  -0.6361  -0.5700
+27    C13      2.3440  -38.7570   21.0360 C.3     1  LIG   0.1354   0.0690
+28    H10      3.1238  -38.3754   20.4296 H       1  LIG   0.0981   0.1000
+29    C14      2.9380  -39.8900   21.8010 C.3     1  LIG  -0.1181  -0.2000
+30    H11      3.8890  -40.1268   21.3997 H       1  LIG   0.0732   0.1000
+31    H12      3.0430  -39.6129   22.8177 H       1  LIG   0.0789   0.1000
+32    C15      1.6390  -40.0610   21.0880 C.3     1  LIG  -0.1196  -0.2000
+33    H13      0.6832  -39.9283   21.5242 H       1  LIG   0.0807   0.1000
+34    H14      1.5292  -40.4423   20.1061 H       1  LIG   0.0733   0.1000
+@<TRIPOS>BOND
+1     2     1     ar
+2     3     2     1
+3     4     2     ar
+4     5     4     1
+5     6     4     ar
+6     7     6     ar
+7     8     7     1
+8     9     8     1
+9     10    8     1
+10    11    10    1
+11    12    11    ar
+12    13    12    1
+13    14    12    ar
+14    15    14    1
+15    16    14    ar
+16    17    16    1
+17    18    16    ar
+18    19    11    ar
+19    19    18    ar
+20    20    19    1
+21    21    1     ar
+22    21    7     ar
+23    21    20    1
+24    22    6     1
+25    23    22    1
+26    24    22    1
+27    25    22    1
+28    26    10    2
+29    27    20    1
+30    28    27    1
+31    29    27    1
+32    30    29    1
+33    31    29    1
+34    32    27    1
+35    32    29    1
+36    33    32    1
+37    34    32    1
+1   LIG    1
Modified: SwiftApps/subjobs/rosetta/rosetta.swift
--- SwiftApps/subjobs/rosetta/rosetta.swift	2014-10-09 18:03:59 UTC (rev 8269)
+++ SwiftApps/subjobs/rosetta/rosetta.swift	2014-10-09 22:30:29 UTC (rev 8270)
@@ -12,8 +12,8 @@
 foreach pdb,i in pdb_files {
-   file rosetta_output <single_file_mapper; file=strcat("logs/h0scale.", i, ".out")>;
-   file rosetta_error <single_file_mapper; file=strcat("logs/h0scale.", i, ".err")>;
+   file rosetta_output <single_file_mapper; file=strcat("logs/rosetta.", i, ".out")>;
+   file rosetta_error <single_file_mapper; file=strcat("logs/rosetta.", i, ".err")>;
    file scorefile <single_file_mapper; file=strcat("score.",i, ".sc")>;
    (scorefile, rosetta_output, rosetta_error) = rosetta(pdb, 2);
    //logs[i] = rosetta_output;
