[Swift-commit] r7745 - in trunk: libexec src/org/globus/swift/data src/org/griphyn/vdl/karajan/lib src/org/griphyn/vdl/karajan/lib/swiftscript src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Mar 22 14:52:30 CDT 2014
Author: hategan
Date: 2014-03-22 14:52:28 -0500 (Sat, 22 Mar 2014)
New Revision: 7745
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java
   trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java
Removed:
   trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java
   trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java
   trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java
   trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java
Modified:
   trunk/libexec/swift-int-staging.k
   trunk/libexec/swift-int-wrapper-staging.k
   trunk/libexec/swift-int.k
   trunk/libexec/swift-lib.k
   trunk/libexec/swift.k
   trunk/src/org/globus/swift/data/Query.java
   trunk/src/org/griphyn/vdl/karajan/lib/AppStageins.java
   trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java
   trunk/src/org/griphyn/vdl/karajan/lib/CacheUnlockFiles.java
   trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java
   trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java
   trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java
   trunk/src/org/griphyn/vdl/karajan/lib/JobConstraints.java
   trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java
   trunk/src/org/griphyn/vdl/karajan/lib/Mark.java
   trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java
   trunk/src/org/griphyn/vdl/karajan/lib/SetDatasetValues.java
   trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java
   trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java
   trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
   trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
   trunk/src/org/griphyn/vdl/mapping/DSHandle.java
Log:
cleaned up stagein and stageout code
Modified: trunk/libexec/swift-int-staging.k
--- trunk/libexec/swift-int-staging.k	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/libexec/swift-int-staging.k	2014-03-22 19:52:28 UTC (rev 7745)
@@ -25,11 +25,7 @@
 	initDDir := function() {
 		"{SWIFT:DEBUG_DIR_PREFIX}{SWIFT:SCRIPT_NAME}-{SWIFT:RUN_ID}.d"
-	inFiles := function(stageins) {
-		pathnames(stageins)
 	fileSizes := function(files) {
 		math:sum(
 			for(f, files, file:size(f))
@@ -64,13 +60,10 @@
 	export(execute2,
-		function(progress, tr, stagein, stageout,  restartout
-			replicationGroup, replicationChannel
+		function(progress, tr, stagein, stageout,
+			replicationGroup, replicationChannel,
 			arguments = [], stdin = null, stdout = null, stderr = null, attributes = null) {
-			stagein := list(unique(each(stagein)))
-			stageout := list(unique(each(stageout)))
 			allocateHost(rhost, constraints = jobConstraints(tr, stagein = stagein)) {
 				ddir := initDDir()
@@ -83,7 +76,9 @@
 				wfdir := "{SWIFT:SCRIPT_NAME}-{SWIFT:RUN_ID}"
 				tmpdir := dircat("{wfdir}/jobs/{jobdir}", jobid)
-				cdmfile := cdm:file()
+				cdmfile := cdm:file(),
+				(localFileDirs, remoteFileDirs, inFiles, outFiles) := getStagingInfo(stagein, stageout)
 				try {
 					log(LOG:DEBUG, "JOB_START jobid={jobid} tr={tr}", if (arguments != null, (" arguments=", arguments)),
@@ -101,9 +96,9 @@
 							"-out", if(stdout == null, "stdout.txt", getFieldValue(stdout)),
 							"-err", if(stderr == null, "stderr.txt", getFieldValue(stderr)),
 							"-i", if (stdin != null, getFieldValue(stdin)),
-							"-d", flatten(unique(outFileDirs(stageout))),
-							"-if", flatten(inFiles(stagein)),
-							"-of", flatten(outFiles(stageout)),
+							"-d", str:join(remoteFileDirs, "|"),
+							"-if", str:join(remoteFileNames(inFiles), "|"),
+							"-of", str:join(remoteFileNames(outFiles), "|"),
 							"-k",
 							"-cdmfile", cdmfile,
 							"-status", "provider"
@@ -132,7 +127,7 @@
 							stageIn("{loc}{SWIFT:HOME}/libexec/cdm_lib.sh", "cdm_lib.sh")
-						appStageins(jobid, stagein, stagingMethod)
+						appStageins(jobid, inFiles, stagingMethod)
 						stageOut("wrapper.log", "{stagingMethod}://localhost/{ddir}/{jobid}.info",
 							mode = WRAPPER_TRANSFER_MODE)
@@ -156,7 +151,7 @@
 						stageOut("wrapper.error", "{stagingMethod}://localhost/{ddir}/{jobid}.error",
 							mode = STAGING_MODE:IF_PRESENT)
-						appStageouts(jobid, stageout, stagingMethod)
+						appStageouts(jobid, outFiles, stagingMethod)
 						if (CLEANUP_ENABLED) {
 							task:cleanUp(".")
@@ -164,7 +159,7 @@
-					doRestartLog(restartout)
+					doRestartLog(stageout)
 					log(LOG:DEBUG, "JOB_END jobid={jobid}")
 				else catch(prev) {
Modified: trunk/libexec/swift-int-wrapper-staging.k
--- trunk/libexec/swift-int-wrapper-staging.k	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/libexec/swift-int-wrapper-staging.k	2014-03-22 19:52:28 UTC (rev 7745)
@@ -64,20 +64,6 @@
 		ddir
-	fileDirs := function(stageins, stageouts) {
-		list(
-			unique(
-				inFileDirs(stageins)
-				outFileDirs(stageouts)
 	cleanup := function(dir, host) {
 		log(LOG:INFO, "START dir={dir} host={host}")
 		if(vdl:configProperty("sitedir.keep") == "false") {
@@ -143,13 +129,10 @@
 	export(execute2,
 			allocateHost(rhost, constraints=jobConstraints(tr, stagein = stagein)) {
 				ddir := initDDir()
@@ -173,9 +156,10 @@
 				wrapfile := "{jobdir}/_paramfile"
 				stdout := if (stdout == null, "stdout.txt", getFieldValue(stdout))
-				stderr := if (stderr == null, "stderr.txt", getFieldValue(stderr))
+				stderr := if (stderr == null, "stderr.txt", getFieldValue(stderr)),
-				fileDirs := fileDirs(stagein, stageout)
 				os := siteProfile(rhost, "SYSINFO:OS")
 				scratch := siteProfile(rhost, "scratch")
@@ -186,9 +170,9 @@
 						"\n-out ", stdout,
 						"\n-err ", stderr,
 						"\n-i ", if (stdin != null, getFieldValue(stdin)),
-						"\n-d ", flatten(each(fileDirs)),
-						"\n-if ", flatten(inFiles(stagein)),
-						"\n-of ", flatten(outFiles(stageout)),
+						"\n-d ", str:join(remoteFileDirs, "|"),
+						"\n-if ", str:join(remoteFileNames(inFiles), "|"),
+						"\n-of ", str:join(remoteFileNames(outFiles), "|"),
 						"\n-wt", WRAPPERLOG_ALWAYS_TRANSFER,
 						"\n-sk", SITEDIR_KEEP,
 						"\n-cdmfile ", cdm:file(),
@@ -247,9 +231,9 @@
 								"-out", stdout,
 								"-err", stderr,
-								"-d", flatten(each(fileDirs)),
 								"-wt", WRAPPERLOG_ALWAYS_TRANSFER,
 								"-sk", SITEDIR_KEEP,
 								"-cdmfile", cdm:file(),
@@ -283,7 +267,7 @@
 					setProgress(progress, "Stage out")
-					doRestartlog(restartout)
+					doRestartlog(stageout)
Modified: trunk/libexec/swift-int.k
--- trunk/libexec/swift-int.k	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/libexec/swift-int.k	2014-03-22 19:52:28 UTC (rev 7745)
@@ -111,19 +111,6 @@
 		ddir
-		list(
-			unique(
 	createDirSet := function(jobid, destdir, host, dirs) {
 		 * Ideally this would be done by creating a tree of the directories
@@ -219,7 +206,7 @@
 		cdm:wait()
-	doStagein := function(jobid, files, dir, host) {
+	doStagein := function(jobid, dir, host, files) {
 		log(LOG:INFO, "START jobid={jobid} - Staging in files {files}")
@@ -238,11 +225,7 @@
 		parallelFor(file, files) {
-			provider := provider(file)
-			srchost := hostname(file)
-			srcdir := swift:dirname(file)
-			destdir := dircat(dir, reldirname(file))
-			filename := basename(file)
+			(provider, srchost, destdir, filename, srcdir) := splitFileURL(file, dir)
 			size := file:size("{srcdir}/{filename}", host=srchost, provider=provider)
 			policy := cdm:query(file)
@@ -254,18 +237,12 @@
 		log(LOG:INFO, "END jobid={jobid} - Staging in finished")
-	doStageout := function(jobid, stageouts, dir, host) {
+	doStageout := function(jobid, dir, host, files) {
 		log(LOG:INFO, "START jobid={jobid} - Staging out files")
-		log(LOG:DEBUG, "stageouts: {stageouts}")
+		log(LOG:DEBUG, "stageouts: {files}")
 		done := list(
-			parallelFor(pv, stageouts) {
-				(path, var) := each(pv)
-				file := absFileName(getField(var, path))
-				dhost := hostname(file)
-				rdir := dircat(dir, reldirname(file))
-				bname := basename(file)
-				ldir := swift:dirname(file)
+			parallelFor(file, files) {
+				(provider, dhost, rdir, bname, ldir) := splitFileURL(file, dir)
 				fullLocal := dircat(ldir, bname)
 				fullRemote := dircat(rdir, bname)
@@ -354,13 +331,10 @@
 	export(execute2,
 				ddir := initDDir(),
 				(wfdir, sharedDir) :=
@@ -383,9 +357,10 @@
 				wrapfile := "{ddir}/param-{jobid}"
 				if(wrapperMode == "files") {
@@ -395,9 +370,9 @@
 						"\n-out ", stdout,
 						"\n-err ", stderr,
 						"\n-status ", statusMode,
 						for(a, arguments) {
@@ -410,8 +385,8 @@
 				try {
-					createDirSet(jobid, sharedDir, rhost, fileDirs)
-					doStagein(jobid, stagein, sharedDir, rhost)
+					createDirSet(jobid, sharedDir, rhost, localFileDirs)
+					doStagein(jobid, sharedDir, rhost, inFiles)
 						stageWrapperParams(jobid, jobdir, wrapfile, wfdir, rhost)
@@ -452,9 +427,9 @@
 								"-out", stdout,
 								"-err", stderr,
 								"-status", statusMode,
 								"-a", if (arguments != null, each(arguments))
@@ -486,14 +461,14 @@
-					doStageout(jobid, stageout, sharedDir, rhost)
+					doStageout(jobid, sharedDir, rhost, outFiles)
 					if (configProperty("wrapperlog.always.transfer") == "true") {
 						discard(transferWrapperLog(rhost, wfdir, jobid, jobdir))
-					cacheUnlockFiles(stagein, sharedDir, rhost) {
+					cacheUnlockFiles(inFiles, sharedDir, rhost) {
 						cleanupFiles(cacheFilesToRemove, rhost)
@@ -502,7 +477,7 @@
 				else catch(prev) {
 					if (matches(prev, "^Abort$")) {
 						log(LOG:DEBUG, "JOB_CANCELED jobid={jobid}")
-						cacheUnlockFiles(stagein, sharedDir, rhost, force=false) {
+						cacheUnlockFiles(inFiles, sharedDir, rhost, force=false) {
 						throw(prev)
@@ -517,7 +492,7 @@
 							throw(exception)
Modified: trunk/libexec/swift-lib.k
--- trunk/libexec/swift-lib.k	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/libexec/swift-lib.k	2014-03-22 19:52:28 UTC (rev 7745)
@@ -115,6 +115,7 @@
 	export(hostname, def("org.griphyn.vdl.karajan.lib.PathUtils$HostName"))
 	export(dircat, def("org.griphyn.vdl.karajan.lib.PathUtils$DirCat"))
 	export(pathnames, def("org.griphyn.vdl.karajan.lib.PathUtils$PathNames"))
+	export(splitFileURL, def("org.griphyn.vdl.karajan.lib.PathUtils$SplitFileURL"))
 	export(execute, def("org.griphyn.vdl.karajan.lib.Execute"))
 	export(expandArguments, def("org.griphyn.vdl.karajan.lib.ExpandArguments"))
@@ -125,13 +126,11 @@
 	export(appStageins, def("org.griphyn.vdl.karajan.lib.AppStageins"))
 	export(appStageouts, def("org.griphyn.vdl.karajan.lib.AppStageouts"))
+	export(remoteFileNames, def("org.griphyn.vdl.karajan.lib.RemoteFileNames"))
 	export(isDone, def("org.griphyn.vdl.karajan.lib.IsDone"))
 	export(mark, def("org.griphyn.vdl.karajan.lib.Mark"))
-	export(flatten, def("org.griphyn.vdl.karajan.lib.Flatten"))
 	export(parameterlog, def("org.griphyn.vdl.karajan.lib.Parameterlog"))
-	export(inFileDirs, def("org.griphyn.vdl.karajan.lib.InFileDirs"))
-	export(outFileDirs, def("org.griphyn.vdl.karajan.lib.OutFileDirs"))
-	export(outFiles, def("org.griphyn.vdl.karajan.lib.OutFiles"))
+	export(getStagingInfo, def("org.griphyn.vdl.karajan.lib.GetStagingInfo"))
 	export(doRestartLog, def("org.griphyn.vdl.karajan.lib.DoRestartLog"))
 	export(unwrapClosedList, def("org.griphyn.vdl.karajan.lib.UnwrapClosedList"))
Modified: trunk/libexec/swift.k
--- trunk/libexec/swift.k	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/libexec/swift.k	2014-03-22 19:52:28 UTC (rev 7745)
@@ -178,11 +178,11 @@
 			attributes = null,
 			deperror = false, mdeperror = false,
-			channel(stagein), channel(stageout), channel(restartout)) {
+			channel(stagein), channel(stageout)) {
 			progress := initProgressState()
-			done := isDone(restartout)
+			done := isDone(stageout)
 			derr := try(deperror, false)
 			merr := try(mdeperror, false)
@@ -203,7 +203,7 @@
 												progress,
 												tr, if(arguments != null, arguments = unwrapClosedList(arguments)),
 												stdin=stdin, stdout=stdout, stderr=stderr, attributes=attributes,
-												stagein, stageout, restartout, replicationGroup, replicationChannel
+												stagein, stageout, replicationGroup, replicationChannel
 										else catch(exception) {
@@ -222,7 +222,7 @@
 											progress,
-											stagein, stageout, restartout, null, null
+											stagein, stageout, null, null
@@ -236,7 +236,7 @@
 							setDatasetValues(stageout)
-							mark(restartout, false, mapping=false)
+							mark(stageout, false, mapping=false)
 							log(LOG:INFO, "END_SUCCESS thread=", currentThread(), " tr={tr}")
 							setProgress(progress, "Finished successfully")
@@ -251,7 +251,7 @@
 							to(errors, exception)
 							log(LOG:INFO, exception)
 							echo(exception)
-							mark(restartout, true, mapping=false)
+							mark(stageout, true, mapping=false)
 							graphStuff(tr, stagein, stageout, true, maybe(args=arguments))
@@ -273,7 +273,7 @@
-				mark(restartout, true, mapping=merr)
+				mark(stageout, true, mapping=merr)
Modified: trunk/src/org/globus/swift/data/Query.java
--- trunk/src/org/globus/swift/data/Query.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/globus/swift/data/Query.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -25,6 +25,7 @@
 import org.globus.cog.karajan.compiled.nodes.functions.AbstractSingleValuedFunction;
 import org.globus.cog.karajan.compiled.nodes.functions.NullaryOp;
 import org.globus.swift.data.policy.Policy;
+import org.griphyn.vdl.mapping.AbsFile;
    Karajan-accessible read-queries to CDM functionality.
@@ -36,7 +37,7 @@
        Do CDM policy lookup based on the CDM file.
     public static class Q extends AbstractSingleValuedFunction {
-    	private ArgRef<String> query;
+    	private ArgRef<AbsFile> query;
         @Override
         protected Param[] getParams() {
@@ -45,8 +46,8 @@
         @Override
         public Object function(Stack stack) {
-            String file = query.getValue(stack);
-            Policy policy = Director.lookup(file);
+            AbsFile file = query.getValue(stack);
+            Policy policy = Director.lookup(file.getPath());
             if (logger.isDebugEnabled()) {
                 logger.debug("Director.lookup(): " + file + " -> " + policy);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/AppStageins.java
--- trunk/src/org/griphyn/vdl/karajan/lib/AppStageins.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/AppStageins.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -33,14 +33,13 @@
 import org.globus.cog.karajan.analyzer.Signature;
 import org.globus.cog.karajan.analyzer.VarRef;
 import org.globus.cog.karajan.compiled.nodes.InternalFunction;
-import org.globus.cog.karajan.util.TypeUtil;
 import org.globus.swift.data.Director;
 public class AppStageins extends InternalFunction {
 	private ArgRef<String> jobid;
-	private ArgRef<List<String>> files;
+	private ArgRef<List<AbsFile>> files;
 	private ArgRef<String> stagingMethod;
 	private ChannelRef<List<String>> cr_stagein;
@@ -64,11 +63,10 @@
     protected void runBody(LWThread thr) {
     	Stack stack = thr.getStack();
-    	List<String> files = this.files.getValue(stack);
+    	List<AbsFile> files = this.files.getValue(stack);
     	String stagingMethod = this.stagingMethod.getValue(stack);
         String cwd = this.cwd.getValue(stack);
-        for (Object f : files) {
-            AbsFile file = new AbsFile(TypeUtil.toString(f));
+        for (AbsFile file : files) {
             Policy policy = Director.lookup(file.toString());
             if (policy != Policy.DEFAULT) {
                 logger.debug("will not stage in (CDM): " + file);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java
--- trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -34,12 +34,10 @@
 import org.griphyn.vdl.karajan.Pair;
-import org.griphyn.vdl.mapping.DSHandle;
-import org.griphyn.vdl.mapping.Path;
 public class AppStageouts extends InternalFunction {
-    private ArgRef<List<List<Object>>> files;
     private ChannelRef<List<String>> cr_stageout;
@@ -61,14 +59,11 @@
         try {
-            List<List<Object>> files = this.files.getValue(stack);
-            for (List<Object> pv : files) {
-                Path p = (Path) pv.get(0);
-                DSHandle handle = (DSHandle) pv.get(1);
-                AbsFile file = new AbsFile(SwiftFunction.filename(handle.getField(p))[0]);
                 String protocol = file.getProtocol();
                 if (protocol.equals("file")) {
                     protocol = stagingMethod;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/CacheUnlockFiles.java
--- trunk/src/org/griphyn/vdl/karajan/lib/CacheUnlockFiles.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/CacheUnlockFiles.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -21,6 +21,7 @@
 package org.griphyn.vdl.karajan.lib;
 import java.util.ArrayList;
+import java.util.Collection;
 import java.util.List;
 import k.rt.Stack;
@@ -39,7 +40,7 @@
 public class CacheUnlockFiles extends CacheFunction {
-    private ArgRef<List<?>> file;
+    private ArgRef<Collection<AbsFile>> files;
     private ArgRef<String> dir;
     private ArgRef<BoundContact> host;
     private ArgRef<Boolean> force;
@@ -49,7 +50,7 @@
     @Override
     protected Signature getSignature() {
-        return new Signature(params("file", "dir", "host", optional("force", Boolean.TRUE), block("body")));
+        return new Signature(params("files", "dir", "host", optional("force", Boolean.TRUE), block("body")));
 	@Override
@@ -77,7 +78,7 @@
     public void remove(Stack stack) {
-        List<?> pairs = this.file.getValue(stack);
+        Collection<AbsFile> files = this.files.getValue(stack);
         String dir = this.dir.getValue(stack);
         Object host = this.host.getValue(stack);
         VDLFileCache cache = getCache(stack);
@@ -85,10 +86,9 @@
         boolean force = this.force.getValue(stack);
-        for (Object o : pairs) {
-            String file = (String) o;
-            File f = new File(PathUtils.remotePathName(new AbsFile(file).getPath()), dir, host, 0);
-            CacheReturn cr = cache.unlockEntry(f, force);
+        for (AbsFile f : files) {
+            File cf = new File(PathUtils.remotePathName(f.getPath()), dir, host, 0);
+            CacheReturn cr = cache.unlockEntry(cf, force);
             rem.addAll(cr.remove);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java
--- trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/DoRestartLog.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -33,30 +33,29 @@
 public class DoRestartLog extends InternalFunction {
-    private ArgRef<List<List<Object>>> restartouts;
+    private ArgRef<List<DSHandle>> stageouts;
     private ChannelRef<Object> cr_vargs;
     private ChannelRef<Object> cr_restartLog;
     @Override
-        return new Signature(params("restartouts"), returns(channel("...", DYNAMIC), channel("restartLog", DYNAMIC)));
+        return new Signature(params("stageouts"), returns(channel("...", DYNAMIC), channel("restartLog", DYNAMIC)));
     @Override
-        Collection<List<Object>> files = restartouts.getValue(stack);
+        Collection<DSHandle> files = stageouts.getValue(stack);
         Channel<Object> ret = cr_vargs.get(stack);
         Channel<Object> log = cr_restartLog.get(stack);
         try {
-                LogVar.logVar(log, handle, p);
+            for (DSHandle file : files) {
+                for (DSHandle leaf : file.getLeaves()) {
+                    LogVar.logVar(log, leaf);
         catch (Exception e) {
Deleted: trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Flatten.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -1,65 +0,0 @@
- * Copyright 2012 University of Chicago
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- * See the License for the specific language governing permissions and
- * limitations under the License.
- * Created on Jul 18, 2010
-package org.griphyn.vdl.karajan.lib;
-import java.util.List;
-import k.rt.Channel;
-import k.rt.Stack;
-import org.globus.cog.karajan.analyzer.ChannelRef;
-import org.globus.cog.karajan.analyzer.Signature;
-public class Flatten extends SwiftFunction {
-	private ChannelRef<?> c_vargs;
-    @Override
-    protected Signature getSignature() {
-        return new Signature(params("..."));
-    @Override
-    public Object function(Stack stack) {
-        Channel<?> v = c_vargs.get(stack);
-        if (v.isEmpty()) {
-            return "";
-        else {
-            StringBuilder sb = new StringBuilder();
-            flatten(sb, v.getAll());
-            sb.deleteCharAt(sb.length() - 1);
-            return sb.toString();
-    private void flatten(StringBuilder sb, List<?> l) {
-        for (Object o : l) {
-            if (o instanceof List) {
-                flatten(sb, (List<?>) o);
-            else {
-                sb.append(TypeUtil.toString(o));
-                sb.append('|');
Added: trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -0,0 +1,103 @@
+ * Copyright 2012 University of Chicago
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an "AS IS" BASIS,
+ * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+ * Created on Jul 18, 2010
+package org.griphyn.vdl.karajan.lib;
+import java.util.ArrayList;
+import java.util.HashSet;
+import java.util.List;
+import java.util.Set;
+import k.rt.Channel;
+import k.rt.ExecutionException;
+import k.rt.Stack;
+import org.globus.cog.karajan.analyzer.ArgRef;
+import org.globus.cog.karajan.analyzer.ChannelRef;
+import org.globus.cog.karajan.analyzer.Signature;
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.HandleOpenException;
+import org.griphyn.vdl.type.Type;
+public class GetStagingInfo extends SwiftFunction {
+    private ArgRef<List<DSHandle>> stageins;
+    private ChannelRef<Object> cr_vargs;
+    @Override
+    protected Signature getSignature() {
+        return new Signature(params("stageins", "stageouts"), returns(channel("...", 4)));
+    @Override
+    public Object function(Stack stack) {
+        Collection<DSHandle> fi = stageins.getValue(stack);
+        Collection<DSHandle> fo = stageouts.getValue(stack);
+        Channel<Object> ret = cr_vargs.get(stack);
+        Set<String> localDirNames = new HashSet<String>();
+        Set<String> remoteDirNames = new HashSet<String>();
+        List<AbsFile> inFiles = new ArrayList<AbsFile>();
+        List<AbsFile> outFiles = new ArrayList<AbsFile>();
+        try {
+            addPaths(localDirNames, remoteDirNames, inFiles, fi);
+            addPaths(localDirNames, remoteDirNames, outFiles, fo);
+        catch (HandleOpenException e) {
+        	throw new ExecutionException(e.getMessage(), e);
+        ret.add(localDirNames);
+        ret.add(remoteDirNames);
+        ret.add(inFiles);
+        ret.add(outFiles);
+        return null;
+    private void addPaths(Set<String> ldirs, Set<String> rdirs, List<AbsFile> files, Collection<DSHandle> vars) throws HandleOpenException {
+    	for (DSHandle file : vars) {
+            	Type t = leaf.getType();
+                String fname = SwiftFunction.argList(SwiftFunction.filename(leaf), true);
+                AbsFile f = new AbsFile(fname);
+                String dir = f.getDirectory();
+                if (dir != null) {
+                    ldirs.add(dir);
+                    rdirs.add(remoteDir(f, dir));
+                files.add(f);
+    private String remoteDir(AbsFile f, String dir) {
+        if ("file".equals(f.getProtocol())) {
+            return PathUtils.remotePathName(dir);
+        else {
+            // also prepend host name to the path
+            return f.getHost() + "/" + PathUtils.remotePathName(dir);
Deleted: trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java
--- trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -1,65 +0,0 @@
-import k.rt.Stack;
-import k.thr.LWThread;
-import org.globus.cog.karajan.analyzer.ArgRef;
-import org.globus.cog.karajan.compiled.nodes.InternalFunction;
-import org.griphyn.vdl.mapping.AbsFile;
-public class InFileDirs extends InternalFunction {
-    private ArgRef<List<String>> stageins;
-    private ChannelRef<Object> cr_vargs;
-    @Override
-        return new Signature(params("stageins"), returns(channel("...", DYNAMIC)));
-    @Override
-    protected void runBody(LWThread thr) {
-        Stack stack = thr.getStack();
-        List<String> files = stageins.getValue(stack);
-        Channel<Object> ret = cr_vargs.get(stack);
-        for (String path : files) {
-        	AbsFile af = new AbsFile(path);
-        	String dir = af.getDirectory();
-        	if (dir != null) {
-            	if ("file".equals(af.getProtocol())) {
-                    ret.add(PathUtils.remotePathName(dir));
-            	else {
-            	    // also prepend host name to the path
-            	    ret.add(af.getHost() + "/" + PathUtils.remotePathName(dir));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -20,8 +20,6 @@
 import k.rt.Context;
 import k.rt.Stack;
@@ -30,10 +28,10 @@
 public class IsDone extends SwiftFunction {
-    private ArgRef<Iterable<List<Object>>> stageout;
+    private ArgRef<Iterable<DSHandle>> stageout;
     private VarRef<Context> context;
@@ -50,12 +48,22 @@
     @Override
-        Iterable<List<Object>> files = stageout.getValue(stack);
-            if (!IsLogged.isLogged(context.getValue(stack), handle, p)) {
-                return Boolean.FALSE;
+        Iterable<DSHandle> files = stageout.getValue(stack);
+            if (file.isRestartable()) {
+                try {
+                        if (!IsLogged.isLogged(context.getValue(stack), leaf)) {
+                            return Boolean.FALSE;
+                    if (logger.isDebugEnabled()) {
+                        logger.debug("Handle open caught in isDone for " + file + ". Assuming false.");
         if (!files.iterator().hasNext()) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -24,7 +24,6 @@
 import java.util.Map;
-import k.rt.ExecutionException;
 import k.rt.Stack;
@@ -33,19 +32,18 @@
 import org.globus.cog.karajan.compiled.nodes.restartLog.LogEntry;
 import org.globus.cog.karajan.compiled.nodes.restartLog.RestartLog;
+import org.griphyn.vdl.mapping.PhysicalFormat;
+import org.griphyn.vdl.type.Types;
 public class IsLogged extends SwiftFunction {
 	private ArgRef<DSHandle> var;
-	private ArgRef<Object> path;
 	@Override
-        return new Signature(params("var", "path"));
+        return new Signature(params("var"));
 	@Override
@@ -57,25 +55,32 @@
 	@Override
 		DSHandle var = this.var.getValue(stack);
-		Path path;
-		Object p = this.path.getValue(stack);
-		if (p instanceof Path) {
-			path = (Path) p;
-		else {
-			path = Path.parse(TypeUtil.toString(p));
-		return Boolean.valueOf(isLogged(context.getValue(stack), var, path));
+		return Boolean.valueOf(isLogged(context.getValue(stack), var));
-	public static boolean isLogged(Context ctx, DSHandle var, Path path) throws ExecutionException {
+	public static boolean isLogged(Context ctx, DSHandle var) {
 		@SuppressWarnings("unchecked")
         Map<LogEntry, Object> logData = (Map<LogEntry, Object>) ctx.getAttribute(RestartLog.LOG_DATA);
 		if (logData.isEmpty()) {
 		    return false;
-	    path = var.getPathFromRoot().append(path);
-        LogEntry entry = LogEntry.build(LogVar.getLogId(var, path));
+		if (var.getType().equals(Types.EXTERNAL)) {
+		    return isLogged(logData, LogVar.getLogId(var));
+        else {
+            PhysicalFormat pf = var.map();
+            if (pf == null) {
+                throw new IllegalArgumentException(var + " could not be mapped");
+            else {
+                return isLogged(logData, pf.toString());
+    private static boolean isLogged(Map<LogEntry, Object> logData, String str) {
+        LogEntry entry = LogEntry.build(str);
         boolean found = false;
         synchronized (logData) {
             List<?> files = (List<?>) logData.get(entry);
@@ -84,5 +89,5 @@
         return found;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/JobConstraints.java
--- trunk/src/org/griphyn/vdl/karajan/lib/JobConstraints.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/JobConstraints.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -32,11 +32,12 @@
 import org.globus.cog.karajan.scheduler.TaskConstraints;
 import org.griphyn.vdl.karajan.lib.cache.CacheMapAdapter;
 import org.griphyn.vdl.util.FQN;
 public class JobConstraints extends CacheFunction {
     private ArgRef<String> tr;
-    private ArgRef<Collection<String>> stagein;
+    private ArgRef<Collection<DSHandle>> stagein;
 	@Override
@@ -51,39 +52,36 @@
 		String tr = this.tr.getValue(stack);
 		String[] filenames = null;
-		Collection<String> c = this.stagein.getValue(stack);
-		if (c != null) {
-			filenames = c.toArray(STRING_ARRAY);
+		Collection<DSHandle> stageins = this.stagein.getValue(stack);
 		SwiftTaskConstraints tc = new SwiftTaskConstraints(tr, new FQN(tr));
-		if (filenames != null) {
-		    tc.setFilenames(filenames);
+		if (stageins != null) {
+		    tc.setStageins(stageins);
 		    tc.setFilecache(new CacheMapAdapter(getCache(stack)));
 		cr_vargs.append(stack, tc);
 	private static final List<String> NAMES1 = Arrays.asList("tr", "trfqn");
-	private static final List<String> NAMES2 = Arrays.asList("tr", "trfqn", "filenames", "filecache");
+	private static final List<String> NAMES2 = Arrays.asList("tr", "trfqn", "stageins", "filecache");
 	private static class SwiftTaskConstraints implements TaskConstraints {
 	    private final String tr;
 	    private final FQN trfqn;
-	    private String[] filenames;
+	    private Collection<DSHandle> stageins;
 	    private CacheMapAdapter filecache;
 	    public SwiftTaskConstraints(String tr, FQN trfqn) {
 	        this.tr = tr;
 	        this.trfqn = trfqn;
-        public String[] getFilenames() {
-            return filenames;
+        public Collection<DSHandle> getStageins() {
+            return stageins;
-        public void setFilenames(String[] filenames) {
-            this.filenames = filenames;
+        public void setStageins(Collection<DSHandle> stageins) {
+            this.stageins = stageins;
         public CacheMapAdapter getFilecache() {
@@ -103,8 +101,8 @@
             else if ("trfqn".equals(name)) {
                 return trfqn;
-            else if ("filenames".equals(name)) {
-                return filenames;
+            else if ("stageins".equals(name)) {
+                return stageins;
             else if ("filecache".equals(name)) {
                 return filecache;
@@ -116,7 +114,7 @@
         @Override
         public Collection<String> getConstraintNames() {
-            if (filenames == null) {
+            if (stageins == null) {
                 return NAMES1;
             else {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java
--- trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/LogVar.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -28,53 +28,46 @@
 import org.globus.cog.karajan.analyzer.VariableNotFoundException;
 import org.griphyn.vdl.mapping.RootHandle;
 public class LogVar extends SwiftFunction {
     private ChannelRef<Object> cr_restartlog;
 	@Override
-        return new Signature(params("var", "path"), returns(channel("restartlog", 1)));
+        return new Signature(params("var"), returns(channel("restartlog", 1)));
     @Override
-		Path path;
-            path = (Path) p;
-        else {
-        logVar(cr_restartlog.get(stack), var, path);
+        logVar(cr_restartlog.get(stack), var);
 		return null;
-	public static void logVar(Channel<Object> log, DSHandle var, Path path) throws VariableNotFoundException {
-        String annotation;
-        PhysicalFormat pf = var.map(path);
-        if (pf != null) {
-            annotation = "" + pf;
-        else {
-            annotation = "unmapped";
-        log.add(getLogId(var, path) + "!" + annotation);
-	public static String getLogId(DSHandle var, Path path) {
-		RootHandle root = var.getRoot();
-		LWThread thr = root.getThread();
-		return thr.getQualifiedName() + ":" + root.getName() +
-		    "." + path.stringForm();
+	public static void logVar(Channel<Object> log, DSHandle var) throws VariableNotFoundException {
+	        log.add(getLogId(var));
+	    else {
+            if (pf == null) {
+            else {
+                log.add(pf.toString());
+	public static String getLogId(DSHandle var) {
+        RootHandle root = var.getRoot();
+        LWThread thr = root.getThread();
+        return thr.getQualifiedName() + ":" + root.getName() +
+            "." + var.getPathFromRoot().stringForm();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Mark.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Mark.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Mark.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -20,7 +20,7 @@
@@ -28,13 +28,13 @@
+import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.mapping.DataDependentException;
 import org.griphyn.vdl.mapping.MappingDependentException;
 public class Mark extends SwiftFunction {
-    private ArgRef<Channel<List<Object>>> restarts;
+    private ArgRef<Channel<AbstractDataNode>> restarts;
     private ArgRef<Boolean> err;
     private ArgRef<Boolean> mapping;
@@ -48,19 +48,19 @@
         try {
             if (err.getValue(stack)) {
                 boolean mapping = this.mapping.getValue(stack);
-                Channel<List<Object>> files = this.restarts.getValue(stack);
-                    Path p = parsePath(pv.get(0));
-                    DSHandle leaf = handle.getField(p);
-                    synchronized (leaf) {
-                        if (mapping) {
-                            leaf.setValue(new MappingDependentException(leaf, null));
+                Channel<AbstractDataNode> files = this.restarts.getValue(stack);
+                for (AbstractDataNode dn : files) {
+                    Collection<DSHandle> leaves = dn.getLeaves();
+                    for (DSHandle leaf : leaves) {
+                        synchronized (leaf) {
+                            if (mapping) {
+                                leaf.setValue(new MappingDependentException(leaf, null));
+                            else {
+                                leaf.setValue(new DataDependentException(leaf, null));
+                            leaf.closeShallow();
-                        else {
-                            leaf.setValue(new DataDependentException(leaf, null));
-                        leaf.closeShallow();
Deleted: trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java
--- trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -1,74 +0,0 @@
-import k.rt.Stack;
-public class OutFileDirs extends SwiftFunction {
-	private ArgRef<List<List<Object>>> stageouts;
-    @Override
-        return new Signature(params("stageouts"), returns(channel("...", DYNAMIC)));
-    @Override
-        List<List<Object>> files = stageouts.getValue(stack);
-        try {
-                String fname = SwiftFunction.filename(leaf)[0];
-                AbsFile af = new AbsFile(fname);
-                    else {
-        catch (Exception e) {
-            throw new ExecutionException(this, e);
-        return null;
Deleted: trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java
--- trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/OutFiles.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -1,62 +0,0 @@
-import k.rt.Stack;
-public class OutFiles extends SwiftFunction {
-    @Override
-    @Override
-        List<List<Object>> files = this.stageouts.getValue(stack);
-        try {
-                String fname = argList(SwiftFunction.filename(leaf), true);
-                ret.add(fname);
-        return null;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java
--- trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -20,10 +20,14 @@
 import k.rt.Stack;
+import k.thr.LWThread;
 import org.globus.cog.karajan.analyzer.Param;
 import org.globus.swift.catalog.types.Os;
@@ -61,6 +65,10 @@
         @Override
             String dir = new AbsFile(path.getValue(stack)).getDirectory();
+            return function(dir);
+        public static String function(String dir) {
             if (dir != null) {
                 return remotePathName(dir);
@@ -73,7 +81,8 @@
     private static final char EOL = '\0';
      * Replace leading slash if present with "__root__" and replace
-     * parent dir references with "__parent__"
+     * parent dir references with "__parent__".
     public static String remotePathName(String dir) {
@@ -272,6 +281,10 @@
             String path = this.path.getValue(stack);
             boolean windows = this.os.getValue(stack).equals(Os.WINDOWS);
+            return function(dir, path, windows);
+        public static String function(String dir, String path, boolean windows) {
             if (dir.equals("")) {
                 return windowsify(path, windows);
@@ -310,4 +323,51 @@
             return l.toArray(new String[0]);
+     * (provider, dhost, rdir, bname, ldir) = splitFileURL(file, dir)
+     * Implements this functionality that used to be in swift-int.k:
+     * provider := provider(file)
+     * dhost := hostname(file)
+     * rdir := dircat(dir, reldirname(file))
+     * bname := basename(file)
+     * ldir := swift:dirname(file)
+    public static class SplitFileURL extends SwiftFunction {
+       private ArgRef<AbsFile> file;
+       private ArgRef<String> dir;
+        @Override
+            return new Signature(params("file", "dir"), returns(channel("...", DYNAMIC)));
+        @Override
+        public void runBody(LWThread thr) {
+            super.runBody(thr);
+        @Override
+            AbsFile f = this.file.getValue(stack);
+            String dir = this.dir.getValue(stack);
+            ret.add(f.getProtocol());
+            ret.add(f.getHost());
+            String fdir = f.getDirectory();
+            ret.add(DirCat.function(dir, RelDirName.function(fdir), false));
+            ret.add(f.getName());
+            ret.add(fdir == null ? "" : fdir);
+            return null;
Added: trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java
--- trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -0,0 +1,55 @@
+ * Created on Jan 5, 2007
+import k.rt.Stack;
+public class RemoteFileNames extends SwiftFunction {
+    @Override
+        return new Signature(params("files"));
+    @Override
+        List<String> ret = new ArrayList<String>();
+            String path = null;
+                ret.add(PathUtils.remotePathName(f.getPath()));
+            else {
+                ret.add(PathUtils.remotePathName(f.getHost() + "/" + f.getPath()));
+        return ret;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SetDatasetValues.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetDatasetValues.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetDatasetValues.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -30,10 +30,9 @@
 public class SetDatasetValues extends SwiftFunction {
     @Override
@@ -42,13 +41,12 @@
     @Override
-        Collection<List<Object>> files = this.stageouts.getValue(stack);
+        Collection<DSHandle> files = this.stageouts.getValue(stack);
         try {
-                leaf.setValue(AbstractDataNode.FILE_VALUE);
+                    leaf.setValue(AbstractDataNode.FILE_VALUE);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -85,10 +85,7 @@
                     deperr = true;
-                k.rt.Channel<Object> stagein = cr_stagein.get(stack);
-                for (Path p : fp) {
-                    stagein.add(filename(var.getField(p))[0]);
+                cr_stagein.append(stack, var);
             catch (ConditionalYield f) {
                 if (tracer.isEnabled()) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -20,11 +20,6 @@
-import java.util.ArrayList;
-import java.util.Collection;
 import k.rt.Stack;
 import org.apache.log4j.Logger;
@@ -33,32 +28,23 @@
+import org.griphyn.vdl.mapping.Mapper;
 public class Stageout extends SwiftFunction {
     public static final Logger logger = Logger.getLogger(Stageout.class);
     private ArgRef<AbstractDataNode> var;
     private ChannelRef<Object> cr_stageout;
-    private ChannelRef<Object> cr_restartout;
     private VarRef<Boolean> r_deperror;
     private VarRef<Boolean> r_mdeperror;
     @Override
         return new Signature(params("var"), returns("deperror", "mdeperror",
-            channel("stageout", DYNAMIC), channel("restartout", DYNAMIC)));
+            channel("stageout", DYNAMIC)));
-    private List<?> list(Path p, DSHandle var) {
-        ArrayList<Object> l = new ArrayList<Object>(2);
-        l.add(p);
-        l.add(var);
-        return l;
     @Override
         AbstractDataNode var = this.var.getValue(stack);
@@ -69,16 +55,16 @@
         // if these arrays had their sizes closed, which could lead to
         // race conditions (e.g. if this array's mapper had some parameter
         // dependencies that weren't closed at the time the app was started).
-        if (var.getType().isArray()) {
-            var.waitFor(this);
         try {
+             if (var.getType().isArray()) {
+                Mapper m = var.getMapper();
+                if (m.isStatic()) {
+                    var.waitFor(this);
             if (!var.isPrimitive()) {
-                retPaths(cr_stageout.get(stack), var);
+                cr_stageout.append(stack, var);
-            if (var.isRestartable()) {
-                retPaths(cr_restartout.get(stack), var);
         catch (MappingDependentException e) {
             logger.debug(e);
@@ -93,16 +79,4 @@
         return null;
-    private void retPaths(k.rt.Channel<Object> channel, DSHandle var) throws ExecutionException {
-        try {
-            Collection<Path> fp = var.getFringePaths();
-                channel.add(list(p, var));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -277,7 +277,7 @@
 	 * true, then each input string will be passed through the relativize
 	 * function.
-	public String argList(String[] s, boolean relative) {
+	public static String argList(String[] s, boolean relative) {
 		StringBuffer sb = new StringBuffer();
 		for (int i = 0; i < s.length; i++) {
 			if (relative) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -172,7 +172,13 @@
         @Override
         	AbstractDataNode dn = file.getValue(stack);
-            String filename = SwiftFunction.unwrap(this, dn);
+        	String filename;
+        	if (dn.getType().equals(Types.STRING)) {
+        	    filename = SwiftFunction.unwrap(this, dn);
+        	else {
+        	    filename = SwiftFunction.filename(dn)[0];
             AbsFile file = new AbsFile(filename);
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -459,6 +459,46 @@
+    public Collection<DSHandle> getLeaves() throws HandleOpenException {
+        Type t = getType();
+        if (t.isPrimitive()) {
+            return Collections.emptyList();
+        if (!t.isComposite()) {
+            return Collections.singletonList((DSHandle) this);
+        List<DSHandle> list = new ArrayList<DSHandle>();
+        getLeaves(list);
+        return list;
+    public void getLeaves(List<DSHandle> list) throws HandleOpenException {
+        checkMappingException();
+        if (getType().getBaseType() != null) {
+            list.add(this);
+        else {
+            for (Field field : getType().getFields()) {
+                AbstractDataNode child;
+                String name = (String) field.getId();
+                try {
+                    child = (AbstractDataNode) this.getField(name);
+                catch (NoSuchFieldException e) {
+                    throw new RuntimeException("Inconsistency between type declaration and " +
+                        "handle for field '" + name + "'");
+                Type type = child.getType();
+                if (!type.isPrimitive() && !child.isArray() && type.getFields().size() == 0) {
+                    list.add(child);
+                else {
+                    child.getLeaves(list);
     public void closeShallow() {
         synchronized(this) {
Modified: trunk/src/org/griphyn/vdl/mapping/DSHandle.java
--- trunk/src/org/griphyn/vdl/mapping/DSHandle.java	2014-03-19 21:11:38 UTC (rev 7744)
+++ trunk/src/org/griphyn/vdl/mapping/DSHandle.java	2014-03-22 19:52:28 UTC (rev 7745)
@@ -91,6 +91,8 @@
     public void closeDeep();
     public Collection<Path> getFringePaths() throws HandleOpenException;
+    public Collection<DSHandle> getLeaves() throws HandleOpenException;
     public Map<Comparable<?>, DSHandle> getArrayValue();
