[Swift-commit] cog r3881
swift at ci.uchicago.edu swift at ci.uchicago.edu
Sat Mar 22 02:05:03 CDT 2014
r3881 | hategan | 2014-03-22 02:00:54 -0500 (Sat, 22 Mar 2014) | 1 line
re-organized some functions a bit and added join(list, delimiter)
Index: modules/karajan/src/org/globus/cog/karajan/analyzer/RootScope.java
--- modules/karajan/src/org/globus/cog/karajan/analyzer/RootScope.java	(revision 3880)
+++ modules/karajan/src/org/globus/cog/karajan/analyzer/RootScope.java	(working copy)
@@ -23,9 +23,9 @@
 import org.globus.cog.karajan.compiled.nodes.SetVarK;
 import org.globus.cog.karajan.compiled.nodes.functions.ChannelArg;
 import org.globus.cog.karajan.compiled.nodes.functions.List;
-import org.globus.cog.karajan.compiled.nodes.functions.Misc;
 import org.globus.cog.karajan.compiled.nodes.functions.Named;
 import org.globus.cog.karajan.compiled.nodes.functions.NumericValue;
+import org.globus.cog.karajan.compiled.nodes.functions.Str;
 import org.globus.cog.karajan.compiled.nodes.functions.Variable;
 import org.globus.cog.karajan.compiled.nodes.user.Function;
 import org.globus.cog.karajan.compiled.nodes.user.Lambda;
@@ -52,7 +52,7 @@
 		addDef("k", "function", new JavaDef(Function.class));
 		addDef("k", "lambda", new JavaDef(Lambda.class));
 		addDef("k", "channel", new JavaDef(ChannelArg.class));
-		addDef("k", "concat", new JavaDef(Misc.Concat.class));
+		addDef("k", "concat", new JavaDef(Str.Concat.class));
 		addVar("#context", context);
 		addVar("#properties", props);
Index: modules/karajan/src/org/globus/cog/karajan/compiled/nodes/functions/Str.java
--- modules/karajan/src/org/globus/cog/karajan/compiled/nodes/functions/Str.java	(revision 0)
+++ modules/karajan/src/org/globus/cog/karajan/compiled/nodes/functions/Str.java	(revision 3881)
@@ -0,0 +1,239 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Mar 21, 2014
+package org.globus.cog.karajan.compiled.nodes.functions;
+import java.util.ArrayList;
+import java.util.Collection;
+import java.util.Iterator;
+import java.util.List;
+import java.util.regex.Pattern;
+import k.rt.Channel;
+import k.rt.ExecutionException;
+import k.rt.Stack;
+import org.globus.cog.karajan.analyzer.ArgRef;
+import org.globus.cog.karajan.analyzer.ChannelRef;
+import org.globus.cog.karajan.analyzer.CompilationException;
+import org.globus.cog.karajan.analyzer.Param;
+import org.globus.cog.karajan.analyzer.Scope;
+import org.globus.cog.karajan.compiled.nodes.Node;
+import org.globus.cog.karajan.parser.WrapperNode;
+import org.globus.cog.karajan.util.TypeUtil;
+public class Str {
+	public static class Concat extends AbstractSingleValuedFunction {
+        private ChannelRef<Object> c_vargs;
+        @Override
+        protected Param[] getParams() {
+            return params("...");
+        @Override
+        public Object function(Stack stack) {
+            StringBuilder sb = new StringBuilder();
+            for (Object o : c_vargs.get(stack)) {
+                sb.append(TypeUtil.toString(o));
+            return sb.toString();
+	public static class Join extends AbstractSingleValuedFunction {
+        @Override
+        @Override
+            Channel<Object> args = c_vargs.get(stack);
+            if (args.size() > 2) {
+                throw new ExecutionException("Too many arguments: " + args.size());
+            if (args.isEmpty()) {
+                throw new ExecutionException("Too few arguments");
+            @SuppressWarnings("unchecked")
+			Collection<Object> items = (Collection<Object>) args.get(0);
+            String delim = " ";
+            if (args.size() == 2) {
+                delim = (String) args.get(1);
+            Iterator<Object> i = items.iterator();
+            while (i.hasNext()) {
+                sb.append(i.next());
+                if (i.hasNext()) {
+                    sb.append(delim);
+    public static class SubString extends AbstractSingleValuedFunction {
+        private ArgRef<String> string;
+        private ArgRef<Number> from;
+        private ArgRef<Number> to;
+        @Override
+            return params("string", "from", optional("to", Integer.MAX_VALUE));
+        @Override
+            int to = this.to.getValue(stack).intValue();
+            String str = string.getValue(stack);
+            if (to == Integer.MAX_VALUE) {
+                return str.substring(from.getValue(stack).intValue());
+            else if (to < 0) {
+                to += str.length() - 1;
+            return str.substring(from.getValue(stack).intValue(), to);
+    public static class Matches extends AbstractSingleValuedFunction {
+        private ArgRef<Object> string;
+        private ArgRef<String> pattern;
+        @Override
+            return params("string", "pattern");
+        @Override
+            Object o = string.getValue(stack);
+            String str;
+            if (o instanceof Exception) {
+                str = ((Exception) o).getMessage();
+            else {
+                str = String.valueOf(o);
+            if (str == null) {
+                return false;
+            else {
+                String pat = pattern.getValue(stack);
+                Pattern p = Pattern.compile(pat, Pattern.DOTALL);
+                return p.matcher(str).matches();
+    public static class Split extends AbstractSingleValuedFunction {
+        private ArgRef<String> separator;
+        @Override
+            return params("string", "separator");
+        @Override
+            String sep = separator.getValue(stack);
+            List<String> list = new ArrayList<String>();
+            int index = -1;
+            int last = 0;
+            do {
+                index = str.indexOf(sep, index + sep.length());
+                if (index > -1) {
+                    if (last < index) {
+                        list.add(str.substring(last, index));
+                    last = index + sep.length();
+            } while (index != -1);
+            list.add(str.substring(last, str.length()));
+            return list;
+    public static class Strip extends AbstractSingleValuedFunction {
+        @Override
+            return params("string");
+        @Override
+            return string.getValue(stack).trim();
+    public static class Chr extends AbstractSingleValuedFunction {
+        private ArgRef<Number> code;
+        @Override
+            return params("code");
+        @Override
+            return (char) code.getValue(stack).intValue();
+    public static class Quote extends AbstractSingleValuedFunction {
+        private ArgRef<String> str;
+        @Override
+            return params("str");
+        @Override
+            return '"' + str.getValue(stack) + '"';
+        public static class ParseNumber extends AbstractSingleValuedFunction {
+        @Override
+        @Override
+        protected Node compileBody(WrapperNode w, Scope argScope, Scope scope)
+                throws CompilationException {
+            if (str.getValue() != null && staticReturn(scope, Double.parseDouble(str.getValue()))) {
+                return null;
+            else {
+                return super.compileBody(w, argScope, scope);
+        @Override
+            String str = this.str.getValue(stack);
+            return Double.parseDouble(str);
Index: modules/karajan/src/org/globus/cog/karajan/compiled/nodes/functions/Misc.java
--- modules/karajan/src/org/globus/cog/karajan/compiled/nodes/functions/Misc.java	(revision 3880)
+++ modules/karajan/src/org/globus/cog/karajan/compiled/nodes/functions/Misc.java	(working copy)
@@ -430,137 +430,7 @@
-	public static class Concat extends AbstractSingleValuedFunction {
-		private ChannelRef<Object> c_vargs;
-		@Override
-		protected Param[] getParams() {
-			return params("...");
-		@Override
-		public Object function(Stack stack) {
-			StringBuilder sb = new StringBuilder();
-			for (Object o : c_vargs.get(stack)) {
-				sb.append(TypeUtil.toString(o));
-			return sb.toString();
-	public static class SubString extends AbstractSingleValuedFunction {
-		private ArgRef<String> string;
-		private ArgRef<Number> from;
-		private ArgRef<Number> to;
-		@Override
-			return params("string", "from", optional("to", Integer.MAX_VALUE));
-		@Override
-			int to = this.to.getValue(stack).intValue();
-			String str = string.getValue(stack);
-			if (to == Integer.MAX_VALUE) {
-				return str.substring(from.getValue(stack).intValue());
-			else if (to < 0) {
-				to += str.length() - 1;
-			return str.substring(from.getValue(stack).intValue(), to);
-	public static class Matches extends AbstractSingleValuedFunction {
-		private ArgRef<Object> string;
-		private ArgRef<String> pattern;
-		@Override
-			return params("string", "pattern");
-		@Override
-			Object o = string.getValue(stack);
-			String str;
-			if (o instanceof Exception) {
-				str = ((Exception) o).getMessage();
-			else {
-				str = String.valueOf(o);
-			if (str == null) {
-				return false;
-			else {
-				String pat = pattern.getValue(stack);
-				Pattern p = Pattern.compile(pat, Pattern.DOTALL);
-				return p.matcher(str).matches();
-	public static class Split extends AbstractSingleValuedFunction {
-		private ArgRef<String> separator;
-		@Override
-			return params("string", "separator");
-		@Override
-			String sep = separator.getValue(stack);
-			List<String> list = new ArrayList<String>();
-			int index = -1;
-			int last = 0;
-			do {
-				index = str.indexOf(sep, index + sep.length());
-				if (index > -1) {
-					if (last < index) {
-						list.add(str.substring(last, index));
-					last = index + sep.length();
-			} while (index != -1);
-			list.add(str.substring(last, str.length()));
-			return list;
-	public static class ParseNumber extends AbstractSingleValuedFunction {
-        private ArgRef<String> str;
-        @Override
-            return params("str");
-        @Override
-		protected Node compileBody(WrapperNode w, Scope argScope, Scope scope)
-				throws CompilationException {
-        	if (str.getValue() != null && staticReturn(scope, Double.parseDouble(str.getValue()))) {
-        		return null;
-        	else {
-        		return super.compileBody(w, argScope, scope);
-		@Override
-            String str = this.str.getValue(stack);
-            return Double.parseDouble(str);
 	public static class Discard extends InternalFunction {
@@ -690,21 +560,7 @@
 			return c1.compareTo(o2);
-	public static class Strip extends AbstractSingleValuedFunction {
-		@Override
-			return params("string");
-		@Override
-			return string.getValue(stack).trim();
 	public static class DotIterator implements Iterator<Object> {
 		private final Iterator<Object>[] its;
 		private boolean next, nextValid;
@@ -853,34 +709,7 @@
-	public static class Chr extends AbstractSingleValuedFunction {
-		private ArgRef<Number> code;
-		@Override
-			return params("code");
-		@Override
-			return (char) code.getValue(stack).intValue();
-	public static class Quote extends AbstractSingleValuedFunction {
-        @Override
-        @Override
-            return '"' + str.getValue(stack) + '"';
 	public static class Stats extends AbstractSingleValuedFunction {
 		private ArgRef<Boolean> asMap;
Index: modules/karajan/resources/sys.k
--- modules/karajan/resources/sys.k	(revision 3880)
+++ modules/karajan/resources/sys.k	(working copy)
@@ -55,13 +55,14 @@
 	export(unique, def("org.globus.cog.karajan.compiled.nodes.functions.Unique"))
 	namespace(str) {
-		export(strip, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Strip"))
-		export(split, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Split"))
-		export(matches, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Matches"))
-		export(chr, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Chr"))
-		export(substring, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$SubString"))
-		export(quote, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Quote"))
-		export(number, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$ParseNumber"))
+		export(strip, def("org.globus.cog.karajan.compiled.nodes.functions.Str$Strip"))
+		export(split, def("org.globus.cog.karajan.compiled.nodes.functions.Str$Split"))
+		export(matches, def("org.globus.cog.karajan.compiled.nodes.functions.Str$Matches"))
+		export(chr, def("org.globus.cog.karajan.compiled.nodes.functions.Str$Chr"))
+		export(substring, def("org.globus.cog.karajan.compiled.nodes.functions.Str$SubString"))
+		export(quote, def("org.globus.cog.karajan.compiled.nodes.functions.Str$Quote"))
+		export(number, def("org.globus.cog.karajan.compiled.nodes.functions.Str$ParseNumber"))
+		export(join, def("org.globus.cog.karajan.compiled.nodes.functions.Str$Join"))
 	export(time, def("org.globus.cog.karajan.compiled.nodes.functions.Time"))
