[Swift-commit] cog r3797
swift at ci.uchicago.edu
Tue Sep 24 21:00:07 CDT 2013
r3797 | hategan | 2013-09-24 20:58:38 -0500 (Tue, 24 Sep 2013) | 1 line
increased local scheduler polling interval when using coasters to 15 seconds
Index: modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterService.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterService.java (revision 3796)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterService.java (working copy)
@@ -11,6 +11,7 @@
import java.io.File;
import java.io.IOException;
+import java.lang.reflect.Method;
import java.net.InetAddress;
import java.net.Socket;
import java.text.DateFormat;
@@ -97,8 +98,30 @@
this.id = id;
setAuthorization(new SelfAuthorization());
initializeLocalService();
+ setPollingIntervals();
+ private void setPollingIntervals() {
+ setPollingInterval("pbs", 15);
+ setPollingInterval("slurm", 15);
+ setPollingInterval("lsf", 15);
+ setPollingInterval("sge", 15);
+ private void setPollingInterval(String p, int t) {
+ try {
+ String clsName = "org.globus.cog.abstraction.impl.scheduler." + p + ".Properties";
+ Class<?> cls = CoasterService.class.getClassLoader().loadClass(clsName);
+ Method getProperties = cls.getMethod("getProperties", (Class<?>[]) null);
+ Object instance = getProperties.invoke(null, (Object[]) null);
+ Method setPollInterval = cls.getMethod("setPollInterval", new Class<?>[] {int.class});
+ setPollInterval.invoke(instance, new Object[] {t});
+ catch (Exception e) {
+ logger.warn("Failed to set polling interval for " + p, e);
private RequestManager newLocalRequestManager() {
RequestManager rm = new ServiceRequestManager();
rm.addHandler("REGISTER", RegistrationHandler.class);
More information about the Swift-commit
