[Swift-commit] r7101 - SwiftApps/Swift-MapRed/psims
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Sun Sep 22 12:08:38 CDT 2013
Author: ketan
Date: 2013-09-22 12:08:38 -0500 (Sun, 22 Sep 2013)
New Revision: 7101
Added:
   SwiftApps/Swift-MapRed/psims/RunpSIMS.sh
   SwiftApps/Swift-MapRed/psims/RunpSIMS.swift
   SwiftApps/Swift-MapRed/psims/cf
   SwiftApps/Swift-MapRed/psims/midway.xml
   SwiftApps/Swift-MapRed/psims/tc.data
Log:
Added: SwiftApps/Swift-MapRed/psims/RunpSIMS.sh
--- SwiftApps/Swift-MapRed/psims/RunpSIMS.sh	                        (rev 0)
+++ SwiftApps/Swift-MapRed/psims/RunpSIMS.sh	2013-09-22 17:08:38 UTC (rev 7101)
@@ -0,0 +1,156 @@
+#!/bin/bash -x
+out=$1
+executable=$2
+outtypes=$3
+postprocess=$4
+tappwth=$5
+tappinp=$6
+tappcamp=$7
+grid1=$8
+grid2=$9
+model=${10}
+shift 10
+# All other arguments beyond this are lists of input files
+#mkdir -p data
+for var in "$@" ; do
+  for file in $var ; do
+#    ln -s $PWD/$file data/$( basename $file )
+    ln -s $PWD/$file $( basename $file )
+done ; done
+# Make all python, perl, and bash scripts executable. If tapps or other stuff in any
+# other language, add suffix here.
+chmod +x *.py *.pl *.sh *.EXE *.exe
+# Run tappcamp application to generate the experiment file from the campaign file.
+# Input campaign file called something like campaign.nc; defines the spatial experiment.
+# This file is a single netcdf file that contains arbitary number of variables
+# that must be changed spatially in the experiment files. The experiment
+# file is model agnostic and always called experiment.json.
+tappcamp="$( echo $tappcamp | sed s/:/' '/g ) --grid1 $grid1 --grid2 $grid2 "
+echo Campaign translator command: $tappcamp
+ls -l experiment.json 1>&2
+#strace -o strace.log
+./$tappcamp
+#ln -s $PWD/experiment.json data/experiment.json
+# Run tappinp application to generate the input files (.XXX and .SOL for DSSAT
+# and .apsim for APSIM) from the experiment.json file
+if [ "$model" == "dssat45" ] ; then suff=".SOL .MZX .RIX .WHX .SBX" ; fi
+if [ "$model" == "apsim75" ] ; then suff=".apsim" ; fi
+if [ "$model" == "cenw" ]    ; then suff=".PJ!" ; fi
+for sf in $suff ; do ls -l *$sf 1>&2 ; done
+tappinp="$( echo $tappinp | sed s/:/' '/g ) "
+echo Input translator command: $tappinp
+./$tappinp                # run the input translator app
+#for sf in $suff ; do     # since tappinp can create multipl files, loop over suffixes
+# for file in $( ls *$sf ) ; do # link the input files to the data directory
+# done ; done
+# Run tappwth application to generate the weather file from the .psims file
+# input files usually of form grid1_grid2.psims.nc and outputs files with
+# generic names like GENERIC.WTH (for DSSAT) and Generic.met (for APSIM).
+if [ "$model" == "dssat45" ] ; then suff=".WTH" ; fi
+if [ "$model" == "apsim75" ] ; then suff=".met" ; fi
+if [ "$model" == "cenw" ]    ; then suff=".CL!" ; fi
+ls -l *$suff 1>&2
+for file in $( ls *.psims.nc ) ; do # build the command line for the weather translator
+  tappwth="$( echo $tappwth | sed s/:/' '/g ) -i $file"
+  echo Weather translator command: $tappwth
+  ./$tappwth                         # run weather translator app
+done
+#for file in $( ls *$suff ) ; do      # link the .wth type files to the data directory
+#done
+ls -l *$suff 1>&2
+################# Run the impact model #################
+#cd data
+executable=$( echo $executable | sed s/:/' '/g )
+   # DSSAT45 #
+ commandToRun="$executable"
+ echo Executable: $commandToRun
+ ./$commandToRun > RESULT.OUT 2>&1
+fi
+   # APSIM75 #
+ tar -xzvf Apsim75.exe.tar.gz  # expand exe & files needed to run (have correct permissions)
+ mv *.xml Model/               # If user adds custom [crop].xml file, overwrites the default
+ mv ./Model/Apsim.xml ./
+ ./paths.sh                    # Sets boost and mono and ld_lib paths for the worker node
+ mono ./Model/ApsimToSim.exe Generic.apsim        # converts .apsim file into N .sim files
+ for file in $( ls *.sim ) ; do
+  commandToRun="$executable $file"
+  echo Executable: $commandToRun                  # run the model on each of the .sim files
+  $commandToRun >> RESULT.out 2>&1
+ done
+fi
+   # CENW40 #
+if [ "$model" == "cenw" ]; then
+ mv CenW.CL! CenW-T.CL!
+  for tt in {0..95..5} ; do
+    let "tlin = ( 129 - $tt )*1461/4"
+    lin=$( printf "%0.f\n" $tlin )
+    tailcom="tail -$lin CenW-T.CL! "
+    $tailcom > CenW.CL!
+    for cap in {1..7} ; do
+      tail -3652 CenW-T.CL! >> CenW.CL!
+    done
+    for hh in {1..9} ; do
+      cp PJHead.TMP CenW.PJ!
+      cat Scene-$hh.PJ! >> CenW.PJ!
+      ./$commandToRun > RESULT-T.OUT 2>&1
+      echo "Scenario $hh planting year $tt" >> RESULT.OUT
+      cat RESULT-T.OUT >> RESULT.OUT
+      rm RESULT-T.OUT
+      if [ $tt -eq 0 -a $hh -eq 1  ] ; then
+       head -105 CenW.DT! > CenW-101.DT!
+       else
+       tail -102 CenW.DT! | head -101 >> CenW-101.DT!
+      fi
+      rm CenW.DT!
+    done
+  done
+fi
+exit_status=$?
+#cd ..
+# Tar and compress output
+mkdir -p output
+for oo in $( echo $outtypes | sed s/,/' '/g ) ; do
+#cp data/
+cp *$oo output
+done
+tar czf $out output
+# Extract data from output files into a single 'psims.nc' file with all variables
+if [ _$postprocess != __ ]; then
+ postprocess=$( echo $postprocess | sed s/:/' '/g )
+ mkdir -p parts
+ mkdir -p parts/$grid1
+ postprocessToRun="$postprocess --grid1 $grid1 --grid2 $grid2 --output parts/$grid1/$grid2.psims.nc"
+ ./$postprocessToRun
+ exit_status=$?
+fi
+exit 0
Property changes on: SwiftApps/Swift-MapRed/psims/RunpSIMS.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/Swift-MapRed/psims/RunpSIMS.swift
--- SwiftApps/Swift-MapRed/psims/RunpSIMS.swift	                        (rev 0)
+++ SwiftApps/Swift-MapRed/psims/RunpSIMS.swift	2013-09-22 17:08:38 UTC (rev 7101)
@@ -0,0 +1,34 @@
+type file;
+app (file tar_out, file part_out, file outlog, file errlog) RunpSIMS (file scenario_in[], file weather_in[], file soils_in[], file common_in[], file binary_in[], file wrapper_file, string grid1, string grid2)
+   bash "-c" @strcat("chmod +x ./RunpSIMS.sh ; ./RunpSIMS.sh ", @tar_out, " ",
+                     @arg("executable"), " ", @arg("outtypes"), " ", @arg("postprocess"), " ",
+                     @arg("tappwth"), " ", @arg("tappinp"), " ", @arg("tappcamp"), " ",
+                     grid1, " ", grid2, " ", @arg("model"), " ",
+                     @scenario_in, " ", @weather_in, " ", @soils_in, " ", @common_in, " ", @binary_in)
+                     stdout=@outlog stderr=@errlog;
+string gridLists[] = readData("gridList.txt");
+foreach g,i in gridLists {
+string gridNames[] = @strsplit(g, "/");
+   // Input files
+   file scenario_input[] <filesys_mapper; location=@arg("campaign"), pattern="*">;
+   file weather_input[] <filesys_mapper; location=@strcat(@arg("weather"), "/", gridLists[i]), pattern="*">;
+   file soils_input[] <filesys_mapper; location=@strcat(@arg("soils"), "/", gridLists[i]), pattern="*">;
+   file common_input[] <filesys_mapper; location=@arg("refdata"), pattern="*">;
+   file binary_input[] <fixed_array_mapper; files=@arg("bintransfer")>;
+   file wrapper_input <single_file_mapper; file="RunpSIMS.sh">;
+   // Output files
+   file stdout_output <single_file_mapper; file=@strcat("logs/", gridLists[i], "o.log")>;
+   file stderr_output <single_file_mapper; file=@strcat("logs/", gridLists[i], "e.log")>;
+   file tar_output <single_file_mapper; file=@strcat("output/", gridLists[i], "output.tar.gz")>;
+   file part_output <single_file_mapper; file=@strcat("parts/", gridLists[i], ".psims.nc")>;
+   (tar_output, part_output, stdout_output, stderr_output) = RunpSIMS(scenario_input, weather_input, soils_input, common_input, binary_input, wrapper_input, gridNames[0], gridNames[1]);
Added: SwiftApps/Swift-MapRed/psims/cf
--- SwiftApps/Swift-MapRed/psims/cf	                        (rev 0)
+++ SwiftApps/Swift-MapRed/psims/cf	2013-09-22 17:08:38 UTC (rev 7101)
@@ -0,0 +1,11 @@
+use.wrapper.staging=false
+wrapperlog.always.transfer=true
+sitedir.keep=false
+execution.retries=0
+lazy.errors=true
+status.mode=provider
+use.provider.staging=false
+provider.staging.pin.swiftfiles=false
+foreach.max.threads=2000
+#app bash=/bin/bash
Added: SwiftApps/Swift-MapRed/psims/midway.xml
--- SwiftApps/Swift-MapRed/psims/midway.xml	                        (rev 0)
+++ SwiftApps/Swift-MapRed/psims/midway.xml	2013-09-22 17:08:38 UTC (rev 7101)
@@ -0,0 +1,19 @@
+<config>
+  <pool handle="midway">
+    <execution provider="coaster" jobmanager="local:slurm"/>
+    <profile namespace="globus" key="jobsPerNode">16</profile>        <!-- Maximum number of RunpSIMS.sh tasks per node -->
+    <profile namespace="globus" key="maxTime">43200</profile>         <!-- Maximum time, in seconds of a coaster block -->
+    <profile namespace="globus" key="maxwalltime">00:30:00</profile>   <!-- Maximum time, in hh:mm:ss of any one RunpSIMS.sh app call -->
+    <profile namespace="globus" key="lowOverallocation">100</profile> <!-- Don't worry too much about these, they should both always be set to 100 -->
+    <profile namespace="globus" key="highOverallocation">100</profile>
+    <profile namespace="globus" key="queue">sandyb</profile>        <!-- Slurm partition to use -->
+    <profile namespace="globus" key="slots">20</profile>              <!-- Maximum number of Slurm jobs -->
+    <!-- <profile namespace="globus" key="nodeGranularity">1</profile> -->     <!-- Request nodes in blocks of nodeGranularity -->
+    <!-- <profile namespace="globus" key="maxNodes">1</profile> -->            <!-- Maximum number of nodes per Slurm job -->
+    <profile namespace="karajan" key="jobThrottle">10</profile>        <!-- Multiply this number by 100 to get the total number of active jobs before Swift starts throttling -->
+    <profile namespace="globus" key="slurm.exclusive">false</profile> <!-- When set to false, it's easier to get nodes, but things may run slower -->
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <filesystem provider="local"/>
+    <workdirectory>/scratch/midway/maheshwari/psims/run003/swiftwork</workdirectory>
+  </pool>
+</config>
Added: SwiftApps/Swift-MapRed/psims/tc.data
--- SwiftApps/Swift-MapRed/psims/tc.data	                        (rev 0)
+++ SwiftApps/Swift-MapRed/psims/tc.data	2013-09-22 17:08:38 UTC (rev 7101)
@@ -0,0 +1 @@
+midway bash /bin/bash null null null
