[Swift-commit] r7100 - in SwiftApps/Swift-MapRed: . psims
ketan at ci.uchicago.edu
Sun Sep 22 11:18:58 CDT 2013
Author: ketan
Date: 2013-09-22 11:18:57 -0500 (Sun, 22 Sep 2013)
New Revision: 7100
Added:
SwiftApps/Swift-MapRed/psims/
SwiftApps/Swift-MapRed/psims/swiftopt.sh
Log:
Added: SwiftApps/Swift-MapRed/psims/swiftopt.sh
--- SwiftApps/Swift-MapRed/psims/swiftopt.sh (rev 0)
+++ SwiftApps/Swift-MapRed/psims/swiftopt.sh 2013-09-22 16:18:57 UTC (rev 7100)
@@ -0,0 +1,137 @@
+#!/bin/bash
+# Usage: swiftopt.sh [-s sitename] [-p paramfile] [-g gridlist]
+# NOTE: this command expects symlink "swift" in the cur dir to point
+# to relese installed by setup.sh If you want to run with a different
+# swift release, replace symlink "swift" with a link to your swift
+# release dir.
+usage="$0 [-s sitename] [-p paramfile] [-g gridlist]"
+site=$2
+# Function to run Swift
+runswift() {
+ export SWIFT_HEAP_MAX=$ram
+ command="swift -tc.file tc.data -sites.file $site.xml -config cf RunpSIMS.swift "
+ for param in $( awk '{print $1}' paramfile )
+ do
+ command="$command -$param=${!param}"
+ done
+ $command 2>&1 | tee swift.out
+# Default settings
+execsite=local
+paramfile=local
+#ram=4096M
+ram=5120M
+# Process command line arguments
+while [ $# -gt 0 ]; do
+ case $1 in
+ -g) gridlist=$2; shift 2;;
+ -p) paramfile=$2; shift 2;;
+ -s) execsite=$2; shift 2;;
+ *) echo $usage 1>&2
+ exit 1;;
+ esac
+done
+# Create next unique run id and run directory
+rundir=$( echo run??? | sed -e 's/^.*run//' | awk '{ printf("run%03d\n", $1+1)}' )
+# Exit if rundir already exits. Something is funky
+if [ -d $rundir ];
+then
+ echo "$rundir already exists! exiting." >&2
+ exit 2
+else
+ mkdir $rundir
+fi
+# Get optimization parameters
+if [ ! -f $paramfile ];
+then
+ echo "Could not find parameter file $paramfile in params!"
+ exit 1
+fi
+cp $paramfile $rundir/paramfile
+sed -e '/^[[:space:]]*\(#.*\)*$/d' -e 's/#.*//' -e 's/ */=/' -e 's/^/export /' <$paramfile >$rundir/params.psims
+source $rundir/params.psims
+echo Run directory $rundir: site=$execsite paramfile=$paramfile
+# Report an error if configuration files are missing
+if [ ! -f "conf/$execsite.xml" ] && [ ! -f "conf/$execsite.conf" ]; then
+ echo Unable to find requested configuration file for site $execsite
+ exit 1
+fi
+# Use start-coaster-service if site is a .conf file
+if [ -f "conf/$execsite.conf" ]; then
+ USE_SCS=1
+fi
+# Check for missing .cf files
+if [ -f "conf/$execsite.xml" ] && [ ! -f "conf/$execsite.cf" ]; then
+ echo Missing configuration file $execsite.cf
+fi
+cp $gridlist $rundir/gridList.txt
+cp RunpSIMS.swift $rundir
+cp bin/RunpSIMS.sh $rundir
+cat << END > $rundir/restart.sh
+#!/bin/bash
+export SWIFT_HEAP_MAX=5120M
+../bin/regen_gridlist.pl
+start-coaster-service
+time swift -tc.file tc.data -sites.file $site.xml -config cf RunpSIMS.swift -model=$model -scenarios=$scenarios -weather=$weather -refdata=$refdata -bindata=$bindata -bintransfer=$bintransfer -executable=$executable -outtypes=$outtypes -postprocess=$postprocess
+stop-coaster-service
+echo Running CSV extractions.. please wait
+time ../bin/extract_csv.pl
+END
+chmod +x $rundir/restart.sh
+# Echo parameters
+echo Parameters:
+echo
+cat $rundir/params.psims
+echo
+# Do the run
+cd $rundir
+export WORK=$PWD/swiftwork
+export SWIFT_USERHOME=$PWD
+mkdir -p $PWD/swiftwork/workers
+# Use start-coaster-service if the site uses a .conf file
+if [ "$USE_SCS" == "1" ]; then
+ cp ../conf/$execsite.conf coaster-service.conf
+ cp ../conf/$execsite.cf cf
+ sed -i -e "s at _RUNDIR_@$rundir@" coaster-service.conf
+ start-coaster-service
+fi
+# Run gensites
+if [ ! "$USE_SCS" == 1 ]; then
+ gensites -p ../conf/$execsite.cf ../conf/$execsite.xml > $execsite.xml
+fi
+echo "Running with paramter file $paramfile" >> ABOUT
+echo "Running on site $execsite" >> ABOUT
+ runswift "sites.xml"
+ stop-coaster-service
+else
+ runswift "$execsite.xml"
+fi
+# Post Post processing
+echo
+echo Running extractions.. please wait
+NCconcat=$( echo $NCconcat | sed s/:/' '/g )
+time ./$NCconcat
+exit
Property changes on: SwiftApps/Swift-MapRed/psims/swiftopt.sh
___________________________________________________________________
Added: svn:executable
More information about the Swift-commit
